grgsiocl
- Product Code: GT-N7000ZBAINU,Latest firmware: N7000DDLR6/N7000ODDLR2/N7000DDLR1/N7000DDLR6, Modified: 30/07/2012 16:35:00
- Deodexed, Zipaligned, Optimised Pngs, Rooted, Busybox, Superuser Installed!
- Database Optimisations
- SystemUI themed like Galaxy S3 - Screenshots Attached!
- S3 Apps Added : Music Player, Task Manager, Modded S3 Launcher, S3 Weather Widget
- 15 toggle mod (Thanks to Criskelo), Battery Percentage Mod, Screen Rotates in all Directions, CRT OFF enabled, Native SIP enabled, No sms in call log, MMS auto convert mod, Native Call Recording, No Ascending ringtone!
- Kernel : NoteCore v12.5 - STD[/B] (Thanks to @g.lewarne) - Battery life is really good with this kernel and ROM combination! (Visit Here:
Flash the Classic_ROM_V4 with the safe kernel. Recommended to do a full wipe, though the flashable zip is non-wipe!
[URL="http://sourceforge.net/projects/classicrom/files/Classic_ROM_V4.zip/download?use_mirror=garr"]Sourceforge][KERNEL~TW~10/08/12] NoteCore v12.5 OC/UV 1600mhz + Standard, "Kernel Kitchen" - xda-developers
https://rapidshare.com/files/4274367191/Classic_ROM_V4.zip
Der ursprüngliche Beitrag von 18:54 Uhr wurde um 19:04 Uhr ergänzt:
I just realised that, i have not included one lib file, hence call recording will be broken! I will upload the fix in a while...other than that, ROM is smooth and super stable
Der ursprüngliche Beitrag von 19:04 Uhr wurde um 19:22 Uhr ergänzt:
TO get best battery life!
Instructions to get best battery life!
Since we are all flasholics, it is suggested to follow the instructions to obtain the best battery life!
1. After flashing the ROM ,Reboot,
2. Go to recovery, Wipe battery stats from recovery going to advance!
3.. Switch off the phone and charge it till 100%, dont remove the charger
4.. Once the phone shows 100 %, reboot and charge till 100% or notifications comes up!
5. After 100% , still charge the phone for atleast 15 minutes and then unplug the charger
6. Atleast do this for two charge cycles!
screenshots attached here!xda-developers - View Single Post - [ROM][11-08][4.0.4][ICS][DDLR6]<<CLASSIC ROM v4>>- SMOOTH & STABLE
GREEN THEME FOR CLASSIC ROM V4
http://forum.xda-developers.com/showpost.php?p=30103451&postcount=835
