![DjSonix](/data/avatars/s/121/121616.jpg,q1569149551.pagespeed.ce.wIYQyG3u5y.jpg)
DjSonix
Stamm-User
- 720
Dies ist ein offizieller leak von miui.com, der emmc bug ist auch in dieser rom noch vorhanden, kann aber behoben werden indem man
den HydraCore v4 kernel nachflasht [ thanks to @g.lewarne ]
DO NOT WIPE DATA , USING THE KERNEL THAT COMES WITH THE ROM
Short Video
Courtesy of my good friend @androidindian
MIUI Galaxy Note
Der ursprüngliche Beitrag von 20:49 Uhr wurde um 20:49 Uhr ergänzt:
DOWNLOAD LINKS
- ROM: Click here for the complete Rom Mirror > Miui_GalaxyNote_2.9.7_4.0_feat_HYDRACORE_v4-3b_STD_EN
- Latest HydraCore Kernel [ thanks to @g.lewarne ] : Click here for the Latest Hydracore Supersafe Kernel
Enjoy!INSTALLATION STEPS
1. Download the above files into your /sdcard
2. Enter Recovery CWM
3. Flash Latest HydraCore Kernel [ thanks to @g.lewarne ]
4. Reboot Recovery
5. Wipe all [ yes all !! ]
6. Flash ROM + Flash Latest HydraCore Kernel , yes AGAIN ! [ THIS IS THE MOST IMPORTANT STEP to have a SAFE KERNEL ]
7. Reboot System
when 1st boot , goto to permission manager and enable it !, or else you will have some troubles with root
Short Video
MIUI Galaxy Note
!!!Extra's!!!
Multilanguage Package:
Here's a small language update for the ROM (small...took 7 hours for me to do this stuff haha) It contains English, Chinese, Polish, Dutch, Italian, Korean, Spanish, Danish, Russian, Arabic, Ukrainian, German, Hebrew, Hungarian, Slovak, Czech, Greek and Turkish. The lockscreen is also updated so there should not be any Chinese symbols on it. (language files are taken taken from S3's official 2.9.7 apks and then implemented into GNote's apks") I'm sure there English still haunts in some applications even if the UI language was something else (I could not get framework-miui-res.apk to work. It decompiled OK and even recompiled OK, but the phone just stuck at bootscreen after modifying it. Don't know why, maybe someone more skilled could take a look and try to implement the language files into it. All other apks seemed to work ok after adding language files to them. I didn't have time to test this thoroughly, but please feel free to do so and report all possible errors. If you're already on 2.9.7, I'm pretty sure that this one will install on top of it without any wiping. Just install it in CWM and that's it (in theory anyway...I had to do several clean installs while I was testing it, so can't be 100% sure) Oh, and it's also zipaligned, don't know if it makes any difference but at least it sounds good.Download: Dev-Host - Miui_GalaxyNote_2.9.7_4.0_feat_HYDRACORE_v4-3b_STD_ML.zip - The Ultimate Free File Hosting / File Sharing Service ps. And as you know, miuandroid.com still hasn't published an official version of MIUI for GNote, so this is still beta and should be treated as such
