![Sliderxxl](/data/avatars/s/128/128854.jpg,q1569149551.pagespeed.ce.crSqg_8dUs.jpg)
Sliderxxl
Hier der Link zu dem orignial Threat:
[Kernel][ICS]Driving Always For User Quality (4/24/2012) - xda-developers
Here we go - What I believe is the first custom kernel built from source for GT-N7000 ICS.
Driving Always For User Quality - DAFUQ!!!!
This is built by applying some small fixes to the GT-I9100 update4 source base so that the stylus and charger drivers build properly.
Source code is at: https://github.com/Entropy512/kernel...py_kernel_main
Initramfs git is at: https://github.com/Entropy512/initra...commits/master
It has been tested so far with Criskelo's ZCLP6-based release, but should work with most other N7000 ICS releases. No bootloader flashing is required. HOWEVER, you must install the Mali and EGL libs from the Galaxy S II in order to boot an open-source update4 kernel.
These libs are included in the CWM-flashable ZIP here. HOWEVER, since there are MAJOR bugs in the eMMC driver of the ICS kernel leaks for this device, it is strongly recommended to flash the .tar version of the kernel in Odin (or extract it and flash it with heimdall) first. Then flash the ZIP including the EGL/mali/gralloc drivers.
Features:
See my I777 ICS kernel thread for now - it's built off of the same source base
Downloadlinks im original Threat vom Creator
Features:
