[KERNEL] [ICS] [13-06-12] franco.Kernel [Version r6]
  • 392 Antworten
cheezusweezel
cheezusweezel
Enthusiast
5.012
Stock XXLPY/LPF only - confirmed and working. Should not boot on AOSP/CM9 roms.
This is what my kernel is made off:
* Initramfs with the usual stuff (root, CWM support, recovery etc) based on CF-Root LPY
* Partitions properly mounted in the ramdisk to take the most out from the device
* VM values tweaked up for maximum performance/battery
* Conservative tweaked and made the default governor
* I/O boosted - I/O dirty writeback system backported from 3.2
* CFS scheduler tweaked for maximum interactivity
* CFS Autogroup enabled
* Deadline I/O scheduler by default
* TCP Westwood+ congestion scheduler by default as its more suitable for this kind of devices
* Kernel stripped of debug shit - the only debugs that stayed were: logcat, printk and kallysms (for Voodoo Louder support)
* CRC32 library that is used by a lot of internal kernel mechanics completely patched up to the latest version
* The usual Franco's magic
* SLUB memory allocator
* Wi-Fi power management - echo 1 > /sys/module/dhd/parameters/wifi_pm (this is only available with wifi is turned on. This boosts wifi signal and its specially useful for screen_off streaming, but it might waste a little extra battery)
* Lots more to be seen on my repository
Changelog:
r6:
* All governors removed but one - pegasusq from Samsung
* Merged gokhanmoral work on this cpufreq driver - all credits to him. Also cleaned up a defined but unused function
* fsync() calls reintroduced to match stock behavior. The device actually runs faster/smoother with this enabled - also safer for data integrity (this has nothing to do with superbrick bug)
* Disable mali-400 tracking debug
* Merged two stability hotplug patches from mainline Linux kernel
* Added two modules to userpsace where one can see how many times the CPU was hotplugged in and hotplugged out: cat /sys/module/stand_hotplug/parameters/ cpu_up_nr and cat /sys/module/stand_hotplug/parameters/ cpu_down_nr
* Removed overclocking at all - it was causing heat and stability issues. If you want OC use Tegrak app
* Some config cleaning
DOWNLOAD: Index of /franciscofranco/Galaxy Note
FTP-Mirror: http://www.partystoned.de/Android-H...Franco Kernel/ICS Kernel/franco.Kernel-r6.zip
! Empfohlen ist der Flash über CWM-Recovery, im Idealfall DIREKT nach der Nutzung des jBroid-Cleaning-Scripts, ebenfalls in CWM-R !
Falls es Probleme nach einem Flash über MobileOdin gab, bitte immer auch den Weg über CWM-R ausprobieren.
r4:
* Some Wi-Fi driver fixes (might help fixing those obtaining IP derps)
* Tons of warnings fixed for a more stable kernel - don't we all want a clean compilation?
* Compiled with special compiler flags for some extra bits of performance
* Fixed a section mismatch - this warnings are one of the worse kind and can possibly lead to big problems. This one is fixed
r3:
* Removed MMC_CAP_ERASE - workaround to fix the superbrick bug - thanks Entropy512 for all the research and shared knowledge with us for this god damn bug
* Re-activated dynamic hotplug - the system seems to run smoother with this option and according to Entropy it gives us lower idle drain specially while the system is holding a wakelock
r2
* Initramfs fixed - recovery works, CWM works etc
r1
* Based on Samsung update3 for ICS kernel 3.0.15 - it contains the hardbrick bug so flash at your own rish or just extract the zImage and to /data/local, fire up adb shell and type this: dd if=/data/local/zImage of=/dev/block/mmcblk0p5 bs=4096 and then reboot
* Contains all the features wrote above plus some small shits available on my git
* App will be updated in the next 12 hours with a full ICS layout plus tons of useful features. The current version won't load this new kernel version for ICS so don't bother checking it. I'll announce when the new app update is up
F.A.Q:
1. My device rebooted or crashed, how can I help?
A: Get me /proc/last_kmsg or logcat.
2. Battery sucks, my device is not entering deep sleep. FIX PLOX!
A: Fix it yourself, it's an app waking your device up not the kernel's problem. Also make sure you let your device settle for at least 2 charging cycles. Typically apps like Facebook and Google Maps can cause problems since they wake it up pretty much all the time
3. Signal is dropping since I flashed the kernel, amg u sucks!
A: The kernel has nothing to do with gsm/cmda signal. Make sure you have the latest radios
4. Do I need to wipe anything when flashing this kernel?
A: No.
5. Does this kernel has X or Y mod?
A: Learn to read, everything you need to know is in the features list, changelog or public repo.
6. Don't use 3rd party init.d scripts!!!
  • jBroid_Kernel_Cleaning_Script_Ed-1.zip
Reaktionen: fragi, prototyp01, myrinh und 8 andere
Bleib da mal dran .. klingt richtig gut ;)
Reaktionen: majemaco
Der neue Franco ist da.
Bin leider am weg zur Arbeit und keine Zeit für mehr Infos.
Reaktionen: cheezusweezel und Reddy
Habs getan. Drauf ist er auf der goa. Jetzt mal sehen. Download ist auf xda. Fred kannst du ihn hier bereit stellen?
Saludos
Bootanimation funzt nicht.
My note is like hell
Good Morning Vietnammmmmmmmmmmmmmmm!
Hände weg clockwork geht irgendwie nicht!!! - vielleicht lags an mir aber auf xda hat geade noch jemand das prob gemeldet.
muss gerade ueber odin pc ran. CWM und clockwork und mobil odin wollen nicht mehr. shit. Buenas Dias mi Mundo
so nochmal von vorne mit odin pc und kk9 - dann rooten mit CF-Root Flasher mit abyss Kernel z-image - und dann mein letztes Backup. kotz.
Uebung macht den meister und privates Note - geiles Flash Risiko :))
so habs wieder nach 20 min ;-) und jetzt geh ich wieder schlafen - sleepless on Gran Canaria
Reaktionen: 149217, Reddy und Criz89
Du Verrückter... ;)
Werde mich mal einlesen.
Reaktionen: pakino
Vorsicht! Franco warnt in seinem XDA-Thread, dass der Brick-Fehler auch in seinem Kernel vorhanden ist. Also Vorsicht!!!!
Grüße
Reaktionen: Reddy
!!! Hatte die gleichen Probleme wie Pakino, dazu hing das Note nach einem Reboot beim SAMSUNG-Logo fest !!!
BITTE NICHT FLASHEN, den Link sparen wir uns auch besser erstmal ...
Reaktionen: pakino, Reddy und trahzebuck
Hab es leider am Weg in die Arbeit geflasht:crying:
Samsung Schriftzug und aus:scared:
Und noch sooooo lang bis zu meinem PC mit Odin.
Wieder was gelernt! Nichts auf die schnelle ohne genaues lesen Flashen.
Bin nur erleichtert das lt. Pakino die Herstellung möglich ist.
Reaktionen: pakino
Danke das Ihr getestet habt!!! Ich währ sonst jetzt voll drin :(
Finde es aber auch bissel Verantwortungslos den Kernel ins Netz zu stellen,
ohne genaue Tests selbst durchzuführen.
Nicht Jeder User weiss sich da zu helfen ...
Man muss ja nicht flashen ... ist mir auch klar,
aber so viel Leichtsinn sollte da nicht bei sein.
Meine persönliche Meinung
Reaktionen: frank e. und pakino
@cezzuswezzel oder so ähnlich, sorry zu früh.
Was ein Name
Du bist ja noch verrückter. Lol.
Saludos y buenos Dias
Ich bin Note - geil
Bei Franco hat es bestimmt geklappt, warum bzw. wie auch immer... ;)
Wiederherstellung ist kein Problem. Wie immer per OdinPC z.B. die pre-rooted LC1 flashen, CF-Kernel drüber und gut. Die LPY wäre natürlich auch möglich, ist aber eben "nur" einteilig.
@pakino, wie Jesus und Wiesel, nur in ENGLISCH und geschrieben wie Käse, LOL.
Reaktionen: pakino
keine sorge du unhold :ohmy:, es geht. Aber reddy hat absolut recht, vor ein paar monaten hatte ich noch einen schreianfall bekommen und mir das hoesschen voll gemacht.
Also Warnung an Alle die noch blutige Anfaenger sind. Flashen nur nach Ruecksprache mit ihrem Arzt oder Apotheker oder hier bei diesem verrueckten Haufen. :thumbsup:
Der ursprüngliche Beitrag von 09:16 Uhr wurde um 09:28 Uhr ergänzt:
chezzlewezzle nach snoop dog lol ;)
geht noch einfacher und zwar zimage vom ICS nur mit dem root flasher vom pc aus. Hat irgendjemand in xda so gemacht
Aber welcome back alive :D:D
@XDA
This is what I did.
1. Extract your original zimage (if you still have.)
2. Copy zimage to the zimage directory of the InitialRootFlasher
3. Plug your note to the USB. (Let the drivers loaded)
4. Run already-rooted.bat
Wait until the note reboots!
You will be back!
Reaktionen: 149217 und Reddy
War nur ein bisschen unentspannt als kein Recovery Mode möglich war.
Nachdem ich in den DL Mode gekommen bin, war ich guter Dinge und nachdem ich deinen Post gelesen hab, wieder voll entspannt:tongue:
Der frühe Flasher fängt den Wurm (oder Bug?):blushing:
Bin guter Dinge das Franco einen Fix hinbekommt:D
Hab den kernel nicht wirklich getestet aber angeblich soll er schneller sein und einen guten ersten eindruck hinterlassen. Bei mir war das erste prob das ich den bootsound gehoert habe aber keine ani. Darauf wollte ich gleich zurueck und nun hab ich diesen wurm halt geschluckt. :blink:
ich mag keine wuermer und kriechtiere. kann ja auch nicht fliegen sondern nur am Note rumbasteln :lol:
Reaktionen: 149217
@pakino .. wir waren eh auf den schönsten Kernel .... "Emalie"
da kommt kein Franco mit ... oder wie die alle heissen ;)
Reaktionen: pakino
@ Reddy
Ich weiss, aber diese verdammte Suche nach Perfektion, diese Angst was gutes zu versäumen, dieses Verlangen einmal dem Rest der Comunity was berichten zu können.:D
Irgendwie sorgen unser Note und dieses tolle Forum dafür das man mit einem gefährlichen Virus infiziert wird: FLASHERITIS:tongue:
Heilungschanchen: GERING
In diesem Sinne schönen Tag und happy flashing:thumbsup:
Reaktionen: hara74, pakino und Reddy
Iss doch auch ok @Didi ....
an mir ist doch der Virus auch nich vorbei gegangen ;) So Gründen wir jetzt praktisch
die AF - Fraktion ... (Anonyme Flasher)
aber nur wenn der Kernel Bug-frei iss :D
Reaktionen: pakino
vollkommen recht. :D Genauer gesagt heisst die Kerneline Emely - Paula.
Und die wird rennen das jeder Benchmarktest versagt.
Tanzt Salsa jetzt schon vom Feinsten mit cubanisch-deutschen Blut und 30 Wochen. :thumbsup: Noch 10 Wochen mehr :love:
Reddy , du hast den Nagel aber sowas getroffen. Und Ja Chezzel Wezzel ich bin verueckt. Mehr als du weisst :lol:
Reaktionen: blackzorro24 und Reddy
Was soll das für ein Kernel sein ?
  • Gesperrt
  • shogunes
frank_m
frank_m
bangsti
Goggle
MichelFell
MichelFell
