[KERNEL] [01-11-12 [TW-AOKP-CM9-CM10-PA-MIUI] HydraCore v7.0 [One Kernel for all]
  • 1.083 Antworten
cheezusweezel
cheezusweezel
Enthusiast
5.012
Entwickler-Thread: http://forum.xda-developers.com/showthread.php?t=1749863
General Features:
- Built from latest samsung Note sources
- Multiboot InitramFS for all rom types
- Patches for full functionality for all rom types
- Supports Touchwiz ICS, AOKP, AOSP, CM9 , CM10, JellyBean, ParanoidAndroid, MIUI roms
- OC/UV version and a Standard frequencies/voltages version
- Full root
- Magical elves and wizardry**
Kernel-Features:
- Noop scheduler default
- Tweaked OnDemand governor default
- Lots of IO tweaks
- Lots of kernel scheduler tweaks
- Adjusted all cpu voltage tables (OC kernel only)
- Realtime cpu temperature, board temperature readouts and VoltGroup information in settings>about>kernel version
- Optimised VM memory setting
- Optimised Global block readahead
- CIFS support with UTF8
- Voltages and frequencies now in userspace for Voltage Coltrol app / AOKP direct support
- lots, and lots of other tweaks (see full source)
CWM Features:
- External SD cards mount properly within cwm for USB Mass Storage mode / PC connection
- Select between .dep and .tar backups. TAR backups recommended!
- Fully working
Known Issues:
DOWNLOADS
OC-Version, overclocked & undervolted (1600Mhz)
v7.0 CWM Zip - http://hecubus.com/xda/kernel/HydraCore/GL_HYDRACORE_v7_OC.zip
Mirror: https://www.hidrive.strato.com/lnk/qMOR4iGm
(remember this is an overclocked kernel so it wont work for everyone - if you get no boot reboot to download mode and flash the ODIN version of the STANDARD kernel below)
Standard nicht übertaktet, also 1400Mhz
v7.0 CWM Zip - http://hecubus.com/xda/kernel/HydraCore/GL_HYDRACORE_v7_STD.zip
Mirror: https://www.hidrive.strato.com/lnk/KeOxYDpU
This will work on all phones, even those incapable of running the universal version
HydraCore Test-Versionen: test
Hydracore-FTP-Server: Downloadübersicht der Versionen (danke an Fredi bzw. Phoenyx)
INSTALLATION:
Kernel Installation
Install either through CWM or PC/Mobile ODIN in the usual manner. Wiping Cache and Dalvik Cache is unnecessary and wont make any difference. Flash only with 25% or more charge on the phone
Installation routine for the rom of your choice
- Either flash HydraCore or have a kernel installed with CWM
- Download your ROM of choice, follow any specific rom installation instructions (in the ROM thread OP) and flash with CWM
- Flash HydraCore in CWM or with Mobile / PC Odin
Changelog
v7.0 Hydra Core
- Based off official CM10 kernel source, with MALI R3P0 drivers
- Included mali driver files for TW roms in ZIP kernels only
- Increased free memory for all roms, around 873mb available for the android system
- Fixed TW button lights
- Fixed TW vibration intensity
- Fixed AOSP user selectable vibration intensity
- Removed all non-standard cpu governors
v5.3 HydraCore
- Dropped new source while i investigate camera
- Fixed video camera
- Fixed Microphone
- All other fixes and improvements from 5.1
v5.1 HydraCore
- Updated to latest Note 2 N7100 official kernel source, 3.0.31
- Bluetooth fixes for non TW roms
- USB fixes for non TW roms
- lots of things i cannot remember!
v4.3b HydraCore
- Fixed ROOT
v4.3 HydraCore
- USB driver changes (again!)
- Some performance improvements in initramFS
- JellyBean initialisation file changes
v4.2 HydraCore
- Fixed TW camera
- VFS Cache Pressure increased to 30
v4.1b
- Fixed 1080p video playback for non TW roms
- Some minor memory tweak changes (vfs cache pressure 100 > 15)
- SWAP support
v4.0
- Reverted to kernel 3.0.15 for patch compatability and some fixes
- Completely fixed all bootanimation problems with non TW roms (uses roms own bootanimation binary now) - will fix never ending bootanimations, bootloops and long delays
- Fixed bootsound on TW roms
- Changes to initramfs, cleanup
- VM settings changed
- Some USB driver changes for better compatability
- Reverted to MDNIE from speedmod k3-9
- stuff i have forgotten
v3.5
- Rebuilt from scratch
- Addressed lag problems
- Voltage Control apps / AOKP built in "performance" tab now fully working
- Android logger built in (not a module any more)
- Fixed Button lights in non TW roms
- Removed all undervolting from STD kernel - now completely stock frequencies and voltages
- OC kernel min GPU now set to 267mhz @ 925mv (barely more than old kernels @ 160mhz)
- Re added all standard kernel debugging for full application support (logging is not used by the kernel but is available for apps, particurlarly debugfs)
- Updates to hardcore's k3-11 MDNIE settings
- SLQB allocator
Source:
full kernel source & initramfs is downloadable from this tar package - Dev-Host - kernel.rar - The Ultimate Free File Hosting / File Sharing Service
Credits and thanks:
Samsung
Hardcore
Funky81
Francisco
DONATIONS
Donations are gratefully accepted but never requested!
you can make donations to me HERE
Reaktionen: syscrh, Bastizpunkt, maximus78 und 23 andere
Ja läuft bei mir ohne probleme.
Bitte die Buildnummer übersehen ist original die chrack v6 nur mit einigen tweaks von mir für den Hausgebrauch.:D
Reaktionen: 149217, Reddy, mystery007 und eine weitere Person
Gut, danke für die Rückmeldung !!!
BTW: Du hast noch immer das LP4-Modem aktiv ? Ich bin wieder auf LR1, mit D1 in Frankfurt. Wobei die Unterschiede "außer Haus" minimal sind.
Reaktionen: 149217
Ja das lp4 modem geht bei mir am besten. Drei netz.
Gebe euch später Bescheid zwecks Akku aber bis jetzt bin ich zufrieden damit also ein Test lohnt sich.
Reaktionen: 149217, Sam-Sung, Reddy und eine weitere Person
Läuft der auch mit dem Rocket V7 Rom?
Müsste ja aber :rolleyes:
How to flash? Mobile Odin? CWM?
Gesendet von meinem GT-N7000 mit Tapatalk
je nachdem wie es vorliegt!! ;)
wenn Zip, dann im CWM
wenn Tar oder Image, dann MOP
und Modems gehen alle Universel untereinander in dem ROM´s
Reaktionen: 149217 und Sam-Sung
bin am testen. bis jetzt alles ok 200 -1400 pegasuz ondemand perfomance conservative sind die Gov"s
in dem Moment wo ich gerade schreibe und ich es in die Hand nehmen will, ist es aus oder SOD, somit absturz. Bin auf chrack (edit LOL nicht die Droge). Es geht aber gerade wieder an
Habe auch gerade geflasht und werde mal mit Chracks xsmall testen:cool2:
Geflashed, und soweit alles gut.
Läuft sehr flott, alles öffnet sich super schnell.
Steht jetzt auf interactive + cfq
Batterie muß sich noch zeigen.
Bin aber bis jetzt sehr zufrieden :D
gesendet mit G-Note
Reaktionen: 149217
Ich bin bis jetzt auch super zufrieden und läuft mit der chrack rom herrlich Smooth.
Gov: pegasusq
Sheduler: deadline
Mal schauen was noch kommt.
Ich habe den Kernel auch mal geflasht. Lief sauber, das CWM 5.8 funktioniert auch im Gegensatz zum Goku soweit gut (Backup habe ich noch nicht getestet).
Der Kernel ist sehr schnell, aber gefühlt weniger smooth beim Scrollen als Goku oder auch als CF Root LQ3. Habe ihn aber auch nicht lange drauf gehabt, da ich am Wochenende unterwegs bin und das Note als Navi brauche (bin deshalb zur Sicherheit wieder auf CF Root LQ3 zurück).
Bin auf die final gespannt.
Viele Grüße
Lars
Sent from my Note from some place in the world!
So nachdem ich endlich mal munter geworden bin flash ich mir auch mal diesen kernel.
Wenn fred mal so positiv schreibt kann er ja nur gut sein:D:thumbup:
@manupot
Alle Angaben ohne Gewähr:D
@cheezusweezel
@Fred
Mirror erlaubt und/oder gewünscht?
Läuft bis jetzt super bei mir.:smile:
Mirror ist von meiner seite erwünscht. Danke:thumbup:
Bitteschön:scared:
Wuala Mirror
Jetzt gibt´s real Life für mich, Grillen bei und mit Freunden:D
Schönen Nachmittag allen Flashern:flapper:
Reaktionen: lassiter34
Könnte jemand mal md5 posten?
Check mit Fastsum
BB765DD6E78962968F576F905769DA98 *gl_notecore_beta_4.zip
Danke Unhold31 für den Mirror wird später auf meiner Seite eingepflegt muss aber noch mein RC Car putzen da er heute auf der Strecke sehr leiden musste.
Reaktionen: 149217 und fragi
Passt. Besten Dank. Dann flashe ich den auch mal ;)
Wie gesagt bei mir ohne Probleme aber kann bei jeden anders sein.
Läuft momentan ab besten.
AA1973
Goggle
Goggle
Goggle
MichelFell
MichelFell
  • Gesperrt
  • shogunes
frank_m
frank_m
