cheezusweezel
Enthusiast
- 5.012
Entwickler-Thread: Forum TegraOwners
Kernel mit vielen Individualisierungsmöglichkeiten: oc/uc/, ov/uv, governeurs & schedulers, GPU & Ladespannung, plus TOUCH-Recovery & BLN-Support.
Thor Touch Recovery Galaxy Note v1.9:
backup/restore efs partition
backup/restore modem partition
install from internal/external memory
backup to internal/external memory
custom power menu
custom wipe menu
mount to usb mounts internal/external memory
recovery at boot shows real kernel version
touch buttons at the bottom
touch gesture control(swipe up/down - moving || swipe left/right - back/enter)
mounting as mass storage works
hw buttons light up
Thor Kernel Galaxy Note (Custom JB based on CM10 ONLY):
i/o scheduler tweaks
usb tweaks
cpu oc(from 100mhz to 1.7ghz) and uV+oV
gpu oc(default 4 step freq table 100/160/267/400mhz)
wifi updates/tweaks
many many many many many driver updates/tweaks
fixed tvout(works only with hw decoded files)
memory optimizations
cpu optimizations
mtp/ptp/mass storage modes work
fully custom kernel does not have mmc bug
epen offset change support
bln support
drivers for xbox/ps3/wiimote controller
usb cdrom drive support(still needs manual mount)
HFS and HFS+ support
NFS support
nfs and cifs support
charging current sysfs control(usable in voltage control app)
tegrak 2nd core control interface
linaro optimized
CHANGELOG
v0.37
- CM10.2 Testkernel
v0.36.13-2
- 2nd attempt to fix recovery again...
v0.36.13
- tweak kernel
- fix signal issue
- new off charge animation
v0.36.12
- update to linux 3.0.79
- tweak sched
- optimize kernel asm functions
- add touch wake and touch wake script for controlling the feature(/system/etc/init.d/99touchwake)
(touch wake if enabled will wake the device if the device was not put to sleep using power button)
- memory management tweaks
- networking tweaks
- backport async IO from 3.6.x branch
- enable async IO
- update row iosched
- tweak deadline iosched
- improve IO latency
- improve system behavior when under heavy load
- update dynamic file sync
- an attempt to fix the recovery
v0.36.11
- update to linux 3.0.76
- smp updates
- memory tweaks
- sched tweaks
- switch zram to google snappy compression
- fix mmc memory leak
- updates to ext4
- this test kernel comes with stock cm10.1 ramdisk and recovery
v0.36.9
- memory tweaks
- more linaro optimizations
- update to upstream kernel 3.0.71
- tweak staging drivers
- tweak pegasusq
- update mali and tweak it
- tweak random generation
- tweak sched
- tweak mmc driver
- /2 hopefully fixed modem driver
- /3 modem should be fixed
- /4 bln should be fixed
v0.35
- update to 3.0.64
- update to linaro compiler to 01.13
- disable ANDROID_PMEM as per cm kernel
- lower FIMC1 MEMSIZE from 32644 to 15360 as per cm kernel
- might be possible to run mr1 version on cm10 roms
- added frandom module /system/lib/modules/opt/frandom/
DOWNLOAD v0.37 für CM10.2:
https://dl.dropboxusercontent.com/u...y Note/Kernel/thor-kernel-jb-v0.37-01-mr2.zip
v0.36.13-2 CM10.1: Multiupload.nl - upload your files to multiple file hosting sites!
Mirror: thor-kernel-jb-v0.36.13-2-reborn-mr1.zip
md5: B57BCDB46C2CC9083141914E19663174
Tweaker-App (Lautstärke erhöhen): xxTweaker-0.4.0_beta1.apk
DOWNLOAD v0.18 FINAL CM9: https://mega.co.nz/#!9kJlhYhI!UyjWRjLcTf4uhIaQ2NTQaTZA6ggRDlmfZR286ZtW-M8
md5: 296ee242c16eb12070736de735036c21
warning: Don't blame me if your phone goes out with a "Bang!" from Extreme or Burn versions
cpu temp is exported to "/sys/devices/platform/s5p-tmu/curr_temp
! Bitte keine Direktlinks oder Mirror im Forum erstellen, der Entwickler möchte die Übersicht behalten, DANKE !
INSTALLATION: Flash über CWM-R & bitte immer CACHE & DALVIK formatieren, bei einem Versionssprung !!!
