ClassicRom V3 -ICS 4.0.4 XXLRK -28.07.2012
  • 138 Antworten
bangsti
Gast
Info zur Rom
Entwickler: grgsiocl
Land: India
Sprache: Multilanguage
Letztes Update: 28.07.2012
XDA Forum (englisch)
Download
Rapidshare
Wuala
Galaxyrom Mirror
Changelog Classic Rom V3
Based on Latest FW N7000XXLRK
Modem: LRK
Kernel: GL_Notecore_V8.1 Standard
Deodexed, Zipalingned, Superuser, Busybox, Optimised Pngs
Full Stock Theme with S3 Icons by default
Init.d folder added but no scripts and also no tweaks in build.prop added to maintain best market compatibility and as close to stock
15 toggles mod added with 8 toggle switch, Sense mod included, Noise reduction by default, No ascending Ringtone, No autoconvert to MMS, No sms in call log, Native Call Recording, Battery Percentage, CRT-OFF Enabled, and Screen Rotation In all directions mods included!
Added S3 Media, S3 music Player, S3 Task Manager, S3 Weather Widget & S3 Launcher (No wallpaper scrolling)
New Lockscreen and Default Wallpaper designed by Visual Designer Mr. Nagendra Chary
Flashing Instructions
Make a full wipe from any Safe Kernel and then Flash the Classic_ROM_V3.zip
[CREDITS
first to my wife followed by my loving daughter
attachment.php
Criskelo (I used his scripts for flashing)
attachment.php
Robiee(Inspiration)
attachment.php
Chainfire, Eybee, Crash, Maxicet, Wanam, Chrack, thering, Pvillasuso....
attachment.php
Prasad Naidu (for testing)​
Themes und Updates
Classic Rom v3 Green Theme Initial Version with
New sammy keyboard i(Themed partially)
New bootanimation
ClassicROMV3_Gree_Theme.zip
QuickPanel Settings für ClassicRom V3
OPTION 1: ONLY 15 TOGGLES B&W + MODDED TWLAUNCHER
MiniDarkTheme B&W Slim LRK
OPTION 2: ONLY 15 TOGGLES GREEN + MODDED TWLAUNCHER
MiniDarkTheme Green Slim LRK
OPTION 3(BIGGER): ALSO MAIN S3 APP ICONS (CONTACTS, PHONE, CAMERA, EMAIL...)
MiniDarkTheme FullPack LRK
Phone Sip
Classic_V3_Smoothness_Tweak.zip
Statusbar Image
Sensation_Mini_Theme.zip
Blue_Axt9ime.zip
NATIVE SIP WITH CALL RECORDING
  • Native SIP enabled!
  • German Phone.apk
  • Noise reduction by default
  • No Ascending Ringtone
Flash Via Recovery
Classic_V3_SIP.zip
(Thanks to eybee for the simple trick which i missed out): Tongue:
Reaktionen: hara74, Robby57, hagbardceline und 3 andere
Hört sich gut an, gleich mal testen.
Reaktionen: AA1973
Bin seit gestern auf der Rom, und muss sagen,
dass ich begeistert bin.
Läuft sehr flüssig und stabil. Keine FC oder andere Fehler bis dahin.
Gefühlt nochmal schneller als vorher.
Und Akku scheint auch etwas besser geworden zu sein.
Die Mods funktionieren ebenfalls sehr gut.
Ich brauch nur noch nen gutes Theme dafür ;)
gesendet mit G-Note
Reaktionen: kamelbullentreiber, 149217, Reddy und 2 andere
Product Code: GT-N7000ZBADBTLatest firmware: N7000XXLRG/N7000DBTLRG/N7000XXLRB/N7000XXLRGModified: 04/07/2012 16:00:07UPDATE
what is new? (Source: Sammobiles)-*POPup PLAY watch movies when you mailing…. (Galaxy SIII)- Restart button is green.- Some icons changed.- Faster.- Signature unlock.
Entweder bin ich blind oder zu blöd aber ich finde keinen download link.
Hmmmm
Da war ich wohl beides :rolleyes:
Edit
Ist da jetzt schon der neue cfroot keine drinnen oder muss ich ihn separat flashen?
Hast du die Rom ganz normal wie jede andere custom Rom installiert?
Ich würde es so machen wie es in der Rom Anleitung steht.
Abyss 4.2 flashen
Ins recovery zurück booten
Full wipe durchführen
Rom flashen
Superuser aktualisieren
Und hoffen das alles geht
Reaktionen: alexanderperi00
also drin ist der LQ3,
hab den neuen von CF LRG drüber geflashed, damit funtioniert auch BT wieder
und ich habe es laut OP gemacht:
- cwm, flash Abyss Redpill
- reboot recovery
- wipe data, cache und dalvik
- flash the Rom
- reboot
und dann nacheinander die Mods geflashed, jedesmal ein reboot dazwischen.
Reaktionen: pakino und cheezusweezel
Hast du den cf kernel direkt nach dem Rom flash drüber gemacht also sprich ohne einen reboot dazwischen?
Hallo die Flasher
Hab diese ROMM gestern Abend geflasht (wie jedes Customrom über Recovery mit Abyss und Fullwipe), alles problemlos. Auch wiederherstellen der Apps mit TB. Danach den Mod geflasht und Hänger beim Samsung Logo.
Nachdem ich heute mein Note brauche wieder mein Sicherheitsrom zurückgespielt. Werde aber sicher noch einen Probelauf starten.
Ein Manko aus meiner Sicht ist das es nur das "kleine" Shutdownmenü hat.
Nö, den gab´s erst später am Abend ;)
Reaktionen: manupot
Falls noch jemand das neue Modem (LRB) dazu flashen will: CWM.zip Link
EDIT: bin ich doof, das sollte ja integriert sein ! ;)
Reaktionen: manupot
das Shutdown Menü kommt bestimmt noch :cool2:
ebenfalls die fehlenden Icons in der togglebar wie Lock, recent apps und search, hatte nämlich schon mal den Dev gefragt,
ich vermisse die ebenfalls :rolleyes:
Das Rom läuft wirklich sehr gut. Bin nach dem original LRG auch mal darauf gewechselt.
Bisher keinerlei Probleme, sehr flüssig und schnell mit CF Root Kernel LRG.
Ich hoffe, es machen sich bald ein paar Themer ans Werk und wir bekommen ein schönes ICS oder Black Theme.
Viele Grüße
Lars
Sent from my Note from some place in the world!
Reaktionen: pakino
Ich kann auch nur positives berichten.
Läuft gefühlt gleich schnell wie die kingdroid 4.4
Also bis jetzt kein einziges problem festgestellt.
Reaktionen: mystery007 und pakino
Geht das nicht auch ohne FullWipe? Wenn man ein Sansung-Stock-Update von 3.2 auf 4.0.3 oder von 4.0.3 auf 4.0.4 flasht, braucht man doch auch kein FullWipe.
Kannst es ja mal probieren.
Wenn's net klappt oder Bugs auftauchen kannst du immer noch nen full wipe machen ;)
gesendet mit G-Note
Hat Jemand die 3 MOD's schon mal probiert??
ich bin gerade am runter laden ....
Cpt. Future
  • bejo
cheezusweezel
cheezusweezel
Rastanius
Patriarch
