[AOSP-ROM][KK][4.4.4] *21.10.15* SlimSaber - n7000
  • 291 Antworten
SlimSaber-n7000-4.4.4-20140812.zip
Changes:
* Synced with weekly 7.2.1
* Disabled mobile data while setting up the phone for the first time
The goal is to avoid mobile data cost if you don't have flat rate before you get chance to disable mobile data
* Add audio.r_submix.default for casting
A hack to support mirroring on Chromecast
* InCallUI: fix blue call button background on some devices
* Updates on chromium openssl
* Updates on frameworks/base
* See changelog for the rest of changes
SlimSaber-n7000-4.4.4-20140820.zip
SlimKernel-n7000-4.4.4-20140819.zip (No changes, it is just latest kernel)
Changes:
  • Synced with weekly 7.4
  • Compiled with latest SaberMod 4.8.4 and 4.9.2 20130814
  • Lockscreen notifications
    Settings - Security
  • Show/hide network speed arrow icons
    Settings - Interface - Statusbar
  • Extended configurable overflow menu button
    Settings - Navigation - Hardware buttons
  • PerformanceControl: Rework time in stats
  • libcore: Fix parsing of fractional seconds
  • See changelog for the rest of changes
SlimSaber-n7000-4.4.4-20140824.zip
Changes:
  • Rebased framework telephony
  • Reverted back the ring delay to default
  • Lockscreen notifications: Privacy mode
  • Soft reboot option in reboot menu
  • Bunch of updates in frameworks base
crashed bei euch die ROM auch sehr häufig wenn ihr SwiftKey als Tastatur verwendet?
Ja,
liegt aber offenbar an Swiftkey..
schade :sad:, mit der android tastatur schreibt es sich einfach nicht so zügig
SlimSaber-n7000-4.4.4-20140901.zip
Changes:
  • Telephony - Reset the audio stream volume to fix low in-call volume bug
  • Applied OpenGL optimization to increase performance up to 2x
  • Removed soft-reboot menu
    This could cause serious mounting issue and someone even had an unexplained battery drain after having a soft-reboot
  • Updated NovaLauncher
  • Some APN updates
Außerdem kommen die Builds für das n7000 jetzt zeitgleich mit den builds für das I9100 da sie eigentlich identisch sind. Es wird also keine Testphase mehr vor Veröffentlichung geben ;)
i think i'll release the build without giving testers additional effort for testing rom.
if the build is fine on i9100, then it should be 99% fine for n7000. this can be proven till now...
of course, if there are crucial changes that could cause bootloop, i'll let testers test it first.
so, i'd like to say a big thanks to testers for their effort till now.
Hey Leute, ich nutze das ROM jetzt seit der Vor-Vor-letzen Build. Habe damals nach Fullwipe geflasht und zwischenzeitlich zwei Updates gemacht. Jetzt ist die aktuellste drauf.
Leider habe ich das Problem (war auch bei der vorherigen Version schon so), dass sich das Note nicht mit jedem WLAN verbinden kann. Auch WLANs die zufür funktioniert haben können jetzt nicht mehr verbunden werden. Die Funkverbindung wirds aufgebaut aber es kann keine IP_Adresse zugewiesen werden, alternativ bricht der Verbindungsaufbau ab. Es betrifft sowohl verschlüsselte als auch offene WLANS, jedoch nicht alle.
Kann das jemand bestätigen oder ist es ein Individual-Fehler?
(außerdem bekomme ich keine pptp-VPN-Verbindung zustande aber das verifiziere ich erst noch).
SlimSaber-n7000-4.4.4-20140909.zip
Changes:
  • Compiled with updated SM toolchain 4.8.4/4.9.2 20140831
  • Lockscreen blurred see through (Settings - Security - See through)
  • Lockscreen Wallpaper (Accessible via launcher wallpaper selector and Settings - Display - Wallpaper - Lock screen)
  • PerformanceTool: Add wakelock fragment (Settings - Advanced options - Performance - Swipe from left to right - Wakelocks)
  • Added back Slim DashClock
  • Added ADB over network QuickSettings Tile
  • SlimRecents: Move options and new feature card/text color (Settings - Interface - Recent app panel)
  • SlimRecents: Fix recent panel defaulting to white on clean flash
  • Double-tap gesture: Code improvement
Mein note crashed seit den letzten 2 updates andauernd wenn ich in whatsapp etwas schreibe. Ca alle 20-30min hab ich einen freeze. fullwipe hat auch nichts gebracht. jemand ne idee?
Werde wohl wieder zurück auf die asylum wechseln. Die Rom läuft einfach zu unzuverlässig.
Habe ich aber auch ab und zu, egal ob unter CM oder SlimSaber, ich glaube daher nicht, dass es an der ROM liegt sondern WhatsApp..
SlimSaber-n7000-4.4.4-20140912.zip
Changes:
* Toolchain: Compiled rom and kernel with latest SM 4.8.4 20140910
* Core: Fix high cpu load under some situations
* Core: Introduce checks for integer overflow during division
* Settings: Move heads up to its own preferencescreen
* Settings: Heads Up background color && transparency
* Bunch of fixes in frameworks/base
Almost forgot to announce it :p
bin jetzt mal auf die Dirty Unicorns gewechselt, mal gespannt ob die besser läuft.
hab die dirty unicorns jetzt seit 3 tagen ohne crashes am laufen. endlich wieder glücklich mit meinem note.
gibt es irgendwo eine idiotensichere anleitung um die app partition zu vergrößern?
Wenn andere hier gravierende Probleme mit der SlimSaber auf Ihrem Note hätten wäre hier, besonders aber im xda-Forum einiges los, was allerdings nicht der Fall ist, das Problem muss demnach also anders gelagert sein denke ich ;)
Wie dem auch sei, es gibt wieder eine neue Build:
SlimSaber-n7000-4.4.4-20140916.zip
Changes:
  • Settings: Add AGPS parameter settings in Location
    If you change the default AGPS setting, don't forget to save it. Press menu and choose save.
  • SlimCenter: Fix SlimOTA not working on some non-english environment
  • Bluetooth: Some updates from AOSP
  • Bionic: Revert "DNS: make the same ip type DNS query as the interface address type"
    Some users reported this breaks VPN connections
  • frameworks/base: Revert "ContentProvider: Avoid duplicate initialization of AsyncTask"
    This change could lead to a soft-reboot. See here
  • Some updates on 2D graphic library
hatte einfach extreme probleme mit swiftkey und whatsapp. Evtl wars ja auch einfach nur bad luck.
Servus,
habe derzeit das letzte Weekly vom Slimkat drauf (24.09.2014). Kann ich das SlimSaber einfach drüber bügeln oder muss ich den Weg wie im ersten Post gehen? Also CWM drauf, alles wipen und System Partition manuell löschen? Derzeit habe ich TWRP drauf.
Grüße und Danke...
bauner
bauner
bauner
bauner
Talinsei
bauner
bauner
bauner
