[AOSP-ROM][KK][4.4.4] *21.10.15* SlimSaber - n7000
  • 291 Antworten
SlimSaber-n7000-4.4.2-20140528.zip
Changes:
* Reverted compiler flags to the old one
* Reverted some upstream kernel commits
* Reverted cpu boost
* Reverted "UNOFFICIAL Builds are for Developers and Testers!"
* Launcher: Add hotword detection
* InCallUI: Pulse Torch On Incoming Call (configurable in phone settings)
* InCallUI: Add transparency to Glowpad background (configurable in phone settings)
* See changelog for the rest of changes
SlimSaber-n7000-4.4.2-20140531.zip
Changes:
  • Fix broken exfat
    Hopefully this will fix zero byte on folders and files
  • InCallUI: Fix stretched contact picture
  • More shake sensitivity adjustments
  • Reduce log verbosity: Don't spam logcat
  • Don't read configs on every touch event for double tap to sleep
  • Cache some information that are often accessed
  • See changelog for the rest of changes
btw, i'm planning to move to afh for file hosting...
EDIT 02.06.: Neue Gapps online!
ich habe auch noch ein N7000 im Einsatz. Wie sieht es denn mit diesem ROM und der Screen-On-Time aus. Wieviel bekommt ihr da so im Durchschnitt mit dem Standardakku (2.500 mAh) hin?
Grüsse
Micha924
SlimSaber-n7000-4.4.2-20140603
Changes:
  • Using memory optimization flag. Credit to AOSPAL
  • SlimRecents: Option to show topmost task
    Options can be found in settings accessibility
  • Launcher3: Hotword: More ding-dong fixes
  • App2SD: Moving applications to an external volume
    Due this feature is still disabled on our device, moving app is now completely impossible. Don't use this build if you really need to move apps.
SlimSaber-n7000-4.4.2-20140604.zip
Changes:
  • Enable moving app to external storage feature
  • Fix memory leak in MTP database
  • Media: Handle errors due to threading race
Reaktionen: Jrp Defy
SlimSaber-n7000-4.4.3-20140607.zip
Changes:
  • Compiled with SaberMod 4.8.4
    Thanks to @Nico60 for the prebuilt toolchain.
  • Updated to Android 4.4.3
    Thanks to @kufikugel for his great work merging 4.4.3. I also spent 5+ hours for merging 4.4.3 until I found out SlimRoms github is already updated with 4.4.3.
  • Kernel: Memset fixes.
  • Applied latest OpenSSL patches
  • See changelog for rest of changes
There is still some works left for TRDS...so don't expect perfection on first 4.4.3 release.
SlimSaber-n7000-4.4.3-20140609.zip
Changes:
  • frameworks/av: A bunch of updates
  • Dialer: update TRDS for new 4.4.3 Dialer
  • PerformanceControl: Added ability to disable logging
    Settings -> Advanced settings -> Performance -> Advanced settings -> Disable logging
  • Edify scipt: Added some information and SlimSaber ASCII logo
Auch die neuen Gapps für 4.4.3 sind online:
Downloads - Addons4.4
Reaktionen: Jrp Defy und plauzeee
SlimSaber-n7000-4.4.3-20140611.zip
Changes:
  • InCallUI: TRDS updates
  • PerformanceControl: Fixed force-highend-gfx option is still showing up on highend device
  • Some bug or memory leak fixes in frameworks/av, frameworks/base and bluetooth driver
Thanks for testers!
Reaktionen: plauzeee
SlimSaber-n7000-4.4.3-20140614.zip
Changes:
  • GPS: Latest location mode changes has been reverted
  • Kernel: Enable zzmoove governor
  • PerformanceControl: Fix sometimes governor is set to performance
  • PerformanceControl: Fix max/min cpu speed not initialize correctly
  • PerformanceControl: Enable governor settings and restrict to zzmoove only
    The governor setting will only be available for zzmoove. Only profile_number change will be persisted, other gov settings will be changed based on the chosen profile template.
    See FAQ how to set it
  • Patch chromium with latest OpenSSL patch
  • Media scanner: Include latest AOSP changes
Edit: Neue Gapps 5.9 von heute online
SlimSaber-n7000-4.4.3-20140616.zip
Changes:
  • Synced with weekly 5.9
  • TWRP: Updated to 2.7.1.0
  • Kernel: Compiled using latest SaberMod 4.8.4
  • Kernel: Added ARM compile flags
  • frameworks/av: A bunch of fixes including audio source buffer overflow fix
  • frameworks/base: Some AOSP updates
Btw.: Sorry für die ganzen aufeinanderfolgenden Posts aber anscheinend wird diese ROM hier auf dem Note nicht so oft genutzt bzw. es gibt keinerlei Fragen/Probleme, auch gut :thumbup:
Reaktionen: nursoda und plauzeee
Danke für die Posts! Ich lese das hier regelmäßig, blieb aber erst mal beim reinen Slim. Werde SlimSaber nun mal testen.
Reaktionen: j1gga84
War am Anfang auch auf der reinen SlimBean bzw. SlimKat, bin dann aber, noch zu 4.3.1 Zeiten auf die SlimSaber gewechselt und bereue den Wechsel keineswegs. Fusionjack ist echt ein sehr erfahrener Developer und außerdem kommen hier auch viel öfters (wichtige) Updates, meist noch vor den jeweiligen Weeklies von SlimKat :thumbup:
Achso, dachte schon es gäbe eine Saber-Variante.
Nein, die gab es noch nie ;)
Auch im xda Forum wird im Eröffnungspost auf die Slim minimal Gapps verwiesen :thumbup:
Wow, SlimSaber ist deutlich slimmer als Slim (kein Nova, kein cLock), bin aber sehr zufrieden bisher. Mal sehen was der Dauertest ergibt.
Einziges Problem was ich bisher habe ist, dass ich mit Slim über Bluetooth vom Autoradio aus die Musikwiedergabe starten und stoppen konnte, er jetzt zwar startet aber nicht mehr stoppt. Diese Phänomen hatte ich auf manchen ROMs, komisch.
Könnte mir jemand helfen habe versucht die Rom auf zuspielen aber irgendwie kommt immer ein Fehler. E:signature verfication failed
Gerät lässt sich nicht mehr hochfahren nur noch dauerschleife das N7000 Logo und ins Recovery komm ich.
Welchen Kernel habt ihr ? (link?)
Bei mir läuft ein raw r5: http://forum.xda-developers.com/showthread.php?t=2397000.
Von welcher ROM/Version kommst du denn? Mit welchem CWM/TWRP? Welche Version hast gerade du installiert?
Habe eben auf die heutige nighty aktualisiert und beta Gapps draufgeworfen - bisher einwandfrei.
Ich komme vom dem Original zustand...
Also hatte noch nie ne CWM drauf ..( TWRP ?)
wenn ich mich erinner hab ich die raw r5 auch versucht kommt auch der fehler. oder habe ich was Falsch gemacht ?
Hab als 1.Recovery drauf gemacht und dann im recovery ,,Wipe data" danach apply update from external storage und dann vergeblich versucht versiedene kernel zu installieren..
Wow, von Original zu SlimSaber, das dürfte ne Umstellung werden.
Du kennst diese Seite? Und hast das dort im ersten Beitrag verlinkte FAQ gelesen?
https://www.android-hilfe.de/forum/...elle-bei-root-und-flash-problemen.392680.html
Ich folgte zuletzt der Flash-Anleitung auf der SlimKat-Webseite, da hatte ich aber schon eine aktuelle Recovery drauf
Welche Recovery (version) hast du geflasht? Womit? Sieht es so aus als ob die stabil läuft? Die Recovery ist beim Note ja immer Teil der ROM...
bauner
bauner
bauner
bauner
Talinsei
bauner
bauner
bauner
