[21.07.14][OFFICIAL][4.4.4]SlimKat-N7000 [Build 6.6]
  • 539 Antworten
fresh from SlimNet:
NOTE: AIO GAPPS WERE UPDATED AGAIN DUE OF AN KEYBOARD ERROR. REDOWNLOAD IF YOU HAVE ALREADY INSTALLED THEM AND JUST FLASH THEM DIRTY OVER.
die Weekly für N7000 steht aber leider derzeit noch aus! Komisch!!!! N9100 u 9300 sind schon da! Hat wohl wer gepennt!:tongue:
Reaktionen: MichelFell und hara74
Wo kann man eigentlich recents auf links stellen? Laut Changelog findet man die Funktion in den Einstellungen. Ich finde es allerdings nicht
Na, hat ja doch noch geklapt! :drool:
Hier isse, die Weekly
und hier das Changelog:
2014-03-17 | n7100: fix drain after call [Javier Ferrer]2014-03-17 | OMAP4-common: Update RIL header to v9 [2/2] (HEAD, m/kk4.4, github/kk4.4) [Andrew Jiang]2014-03-15 | P3100: Update PRODUCT_BUILD_PROP_OVERRIDES (HEAD, m/kk4.4, github/kk4.4) [Andreas B]2014-03-15 | P3110: Update PRODUCT_BUILD_PROP_OVERRIDES (HEAD, m/kk4.4, github/kk4.4) [Andreas B]2014-03-15 | P5100: Update PRODUCT_BUILD_PROP_OVERRIDES (HEAD, m/kk4.4, github/kk4.4) [Andreas B]2014-03-15 | P5110: Update PRODUCT_BUILD_PROP_OVERRIDES (HEAD, m/kk4.4, github/kk4.4) [Andreas B]2014-03-12 | Switch to Linaro 4.8 (HEAD, m/kk4.4, github/kk4.4) [Josue Rivera]2014-03-14 | rhine: Fix invalid input_boost value (HEAD, m/kk4.4, github/kk4.4) [Steve Kondik]2014-03-16 | Fix bug in PAN code where no new PAN connections can be made. (HEAD, m/kk4.4, github/kk4.4) [Sharvil Nanavati]2014-03-09 | Changes to also make .so for libxml2. (HEAD, m/kk4.4, github/kk4.4) [Dante Russo]2014-03-09 | pcm: add support for pcm_ioctl() api (HEAD, m/kk4.4, github/kk4.4) [Shiv Maliyappanahalli]
2014-03-17 | n7100: audio: hal update [UtkarshGupta]
2014-03-16 | VolumePanel: Don't force navigation bar [David96]
2014-03-16 | Tethering: fix NPE when retrieving active interfaces [Dirk Rettschlag]
2014-03-16 | SystemUI: Update Ringer tile code. [Kiril Mikos]
2014-03-16 | SystemUI: Set Status bar opaque during drawer pulldown on tablets only [blackhand1001]
2014-03-16 | SystemUI: Notification Reminder - Update Reminder [Jubakuba]
2014-03-16 | Settings: SlimRecents scaling + lefty mode (3/3) [Lars Greiss]
2014-03-16 | Service: Keep services needing restart. [Liangcai Li]
2014-03-16 | Revert "services: don't clear wallpaper when SystemUI" [Lars Greiss]
2014-03-16 | remove unnecessary switchUser call [Jianzheng Zhou]
2014-03-16 | Prevent a duplicated registration of Observers [muzbit.kim]
2014-03-16 | NULL previous background bitmap upon changing wallpaper [jshe32X]
2014-03-16 | Null pointer exception in FileRotator.java [Mikael Gullstrand]
2014-03-16 | NsdService does not clean up after exiting clients [Dave Platt]
2014-03-16 | Gallery2: Handled seek to previous frame in case of video trim [Suresh Choudhary]2014-03-14 | MMS: Disable Android 4.2 specific hack regarding keyboard behavior. [Dan]
2014-03-16 | Frameworks: SlimRecents make it RTL/LTR aware + scaling + lefty mode (1/3) [Lars Greiss]
2014-03-16 | Frameworks: SlimPie only preload recent on button press down [Lars Greiss]
2014-03-16 | Frameworks: More Keyguard Colors (1/2) [Jubakuba]
2014-03-16 | frameworks: including build.prop property "ro.config.vc_music_vol_steps" to control music steps amount (like it is with "ro.config.vc_call_vol_steps" and call volume steps) [gwindlord]
2014-03-16 | frameworks/base: Day and week on data usage (1/2) [dagix5]
2014-03-16 | Frameworks: add favorite mode [Lars Greiss]
2014-03-16 | Framework: Notify User Interaction on Unlock [Jubakuba]
2014-03-16 | Fix to memory leak leaving WallpaperCropActivity. [Daniel 2 Olofsson]
2014-03-16 | Fix progress of VolumePanel never refresh [Eiichi,Ohnishi]
2014-03-16 | Don't recreate keyguard for MCC/MNC changes. [Danny Baumann]
2014-03-16 | Don't let apps disable the SIM PIN entry screen. [Danny Baumann]
2014-03-16 | Clean up overlays [arcardinal]
2014-03-16 | Cardslib: make it RTL/LTR aware (2/3) [Lars Greiss]
2014-03-16 | Cardslib: Add partial onLongClickListener ability [Lars Greiss]
2014-03-16 | Camera: Ensure background edition complete on back Key [Suman Mukherjee]
2014-03-16 | Avoid race condition that gets PanService stuck in STATE_DISCONNECTED. [Sharvil Nanavati]2014-03-16 | Handle DownloadManager expceptions (HEAD, m/kk4.4, github/kk4.4) [Filip Matusiak]
2014-03-16 | Add people lookup settings keys [Xiao-Long Chen]
2014-03-16 | add gps gid to system_server [Kevin Tang]
2014-03-16 | A couple of fixes [KĂ©vin PETIT]
2014-03-15 | xen-blkfront: handle backend CLOSED without CLOSING [David Vrabel]
2014-03-15 | x86, x32: Correct invalid use of user timespec in the kernel [PaX Team]
2014-03-15 | x86, hweight: Fix BUG when booting with CONFIG_GCOV_PROFILE_ALL=y [Peter Oberparleiter]
2014-03-15 | word-at-a-time: make the interfaces truly generic [faux123]
2014-03-15 | virtio-blk: Use block layer provided spinlock [Asias He]
2014-03-15 | usb-storage: restrict bcdDevice range for Super Top in Cypress ATACB [Alan Stern]
2014-03-15 | usb-storage: enable multi-LUN scanning when needed [Alan Stern]
2014-03-15 | usb-storage: add unusual-devs entry for BlackBerry 9000 [Alan Stern]
2014-03-15 | usb: option: blacklist ZTE MF667 net interface [Raymond Wanyoike]
2014-03-15 | usb: option: add new zte 3g modem pids to option driver [ĺĽ ĺ�›]
2014-03-15 | USB: ftdi_sio: add Tagsys RFID Reader IDs [Ulrich Hahn]
2014-03-15 | usb: ftdi_sio: add Mindstorms EV3 console adapter [Bjørn Mork]
2014-03-15 | usb: core: get config and string descriptors for unauthorized devices [Thomas Pugliese]
2014-03-15 | turbostat: Use GCC's CPUID functions to support PIC [Josh Triplett]
2014-03-15 | tty/serial: at91: Handle shutdown more safely [Marek Roszko]
2014-03-15 | tty: n_gsm: Fix for modems with brk in modem status control [Lars Poeschel]
2014-03-15 | timekeeping: Avoid possible deadlock from clock_was_set_delayed [John Stultz]
2014-03-15 | time: Fix overflow when HZ is smaller than 60 [Mikulas Patocka]
2014-03-15 | target/iscsi: Fix network portal creation race [Andy Grover]
2014-03-15 | target/file: Use O_DSYNC by default for FILEIO backends [Nicholas Bellinger]
2014-03-15 | target/file: Re-enable optional fd_buffered_io=1 operation [Nicholas Bellinger]
2014-03-15 | sunrpc: Fix infinite loop in RPC state machine [Weston Andros Adamson]
2014-03-15 | staging: vt6656: [BUG] BBvUpdatePreEDThreshold Always set sensitivity on bScanning [Malcolm Priestley]
2014-03-15 | staging: r8712u: Set device type to wlan [Larry Finger]
2014-03-15 | staging:iio:ad799x fix error_free_irq which was freeing an irq that may not have been requested [Hartmut Knaack]
2014-03-15 | spi: Fix crash with double message finalisation on error handling [Geert Uytterhoeven]
2014-03-15 | spidev: fix hang when transfer_one_message fails [Daniel Santos]
2014-03-15 | slub: Fix calculation of cpu slabs [Li Zefan]
2014-03-15 | serial: add support for 200 v3 series Titan card [Yegor Yefremov]
2014-03-15 | SELinux: Fix memory leak upon loading policy [Tetsuo Handa]
2014-03-15 | SELinux: Fix kernel BUG on empty security contexts. [Stephen Smalley]
2014-03-15 | SCSI: bfa: Chinook quad port 16G FC HBA claim issue [Vijaya Mohan Guvva]
2014-03-15 | sched: Unthrottle rt runqueues in __disable_runtime() [Peter Boonstoppel]
2014-03-15 | sched,rt: fix isolated CPUs leaving root_task_group indefinitely throttled [Mike Galbraith]
2014-03-15 | sched/rt: Avoid updating RT entry timeout twice within one tick period [Ying Xue]
2014-03-15 | sched/nohz: Fix rq->cpu_load calculations some more [Peter Zijlstra]
2014-03-15 | sched/nohz: Fix rq->cpu_load[] calculations [Peter Zijlstra]
2014-03-15 | s390: fix kernel crash due to linkage stack instructions [Martin Schwidefsky]
2014-03-15 | s390/dump: Fix dump memory detection [Michael Holzheu]
2014-03-15 | rtc-cmos: Add an alarm disable quirk [Borislav Petkov]
2014-03-15 | ring-buffer: Fix first commit on sub-buffer having non-zero delta [Steven Rostedt (Red Hat)]
2014-03-15 | Revert "ARM: disable ALIGNMENT_TRAP if HAVE_EFFICIENT_UNALIGNED_ACCESS" [Paul Reioux]
2014-03-15 | raw: test against runtime value of max_raw_minors [Paul Bolle]
2014-03-15 | radeon/pm: Guard access to rdev->pm.power_state array [Michel Dänzer]
2014-03-15 | powerpc: Make sure "cache" directory is removed when offlining cpu [Paul Mackerras]
2014-03-15 | power: max17040: Fix NULL pointer dereference when there is no platform_data [Krzysztof Kozlowski]
2014-03-15 | PM / Hibernate: Hibernate/thaw fixes/improvements [Bojan Smojver]
2014-03-15 | PCI: Enable ARI if dev and upstream bridge support it; disable otherwise [Yijing Wang]
2014-03-15 | parport: parport_pc: remove double PCI ID for NetMos [Sebastian Andrzej Siewior]
2014-03-15 | ore: Fix wrong math in allocation of per device BIO [Boaz Harrosh]
2014-03-15 | NFSv4: OPEN must handle the NFS4ERR_IO return code correctly [Trond Myklebust]
2014-03-15 | nfs: tear down caches in nfs_init_writepagecache when allocation fails [Jeff Layton]
2014-03-15 | nfs4.1: properly handle ENOTSUP in SECINFO_NO_NAME [Weston Andros Adamson]
2014-03-15 | net,via-rhine: Fix tx_timeout handling [Richard Weinberger]
2014-03-15 | net: avoid reference counter overflows on fib_rules in multicast forwarding [Hannes Frederic Sowa]
2014-03-15 | mtd: mxc_nand: remove duplicated ecc_stats counting [Michael Grzeschik]
2014-03-15 | msm: sony: Enable KSM [Ethan Chen]
2014-03-15 | msm: camera: Update sensor mount angle and position [Suresh Vankadara]
2014-03-15 | msm: camera2: Add support to propagate frame drop [Shuzhen Wang]
2014-03-15 | Modpost: fixed USB alias generation for ranges including 0x9 and 0xA [Jan Moskyto Matejka]
2014-03-15 | mm: setup pageblock_order before it's used by sparsemem [Xishi Qiu]
2014-03-15 | mm: __set_page_dirty uses spin_lock_irqsave instead of spin_lock_irq [KOSAKI Motohiro]
2014-03-15 | mm: __set_page_dirty_nobuffers() uses spin_lock_irqsave() instead of spin_lock_irq() [KOSAKI Motohiro]
2014-03-15 | mm/page_alloc.c: remove pageblock_default_order() [Andrew Morton]
2014-03-15 | mm: hugetlbfs: fix hugetlbfs optimization [Andrea Arcangeli]
2014-03-15 | mmc: atmel-mci: fix timeout errors in SDIO mode when using DMA [Ludovic Desroches]
2014-03-15 | md/raid5: fix long-standing problem with bitmap handling on write failure. [NeilBrown]
2014-03-15 | md/raid5: Fix CPU hotplug callback registration [Oleg Nesterov]
2014-03-15 | mac80211: fix fragmentation code, particularly for encryption [Johannes Berg]
2014-03-15 | lockd: send correct lock when granting a delayed lock. [NeilBrown]
2014-03-15 | Linux 3.4.82 [Greg Kroah-Hartman]
2014-03-15 | Linux 3.4.81 [Greg Kroah-Hartman]
2014-03-15 | Linux 3.4.80 [Greg Kroah-Hartman]
2014-03-15 | Linux 3.4.79 [Greg Kroah-Hartman]
2014-03-15 | lib/vsprintf.c: kptr_restrict: fix pK-error in SysRq show-all-timers(Q) [Dan Rosenberg]
2014-03-15 | lib: Sparc's strncpy_from_user is generic enough, move under lib/ [Paul Reioux]
2014-03-15 | lib/lzo: Update LZO compression to current upstream version [faux123]
2014-03-15 | lib/lzo: Rename lzo1x_decompress.c to lzo1x_decompress_safe.c [Markus F.X.J. Oberhumer]
2014-03-15 | lib/lzo: Optimize code for CPUs with inefficient unaligned access [Markus F.X.J. Oberhumer]
2014-03-15 | lib: Fix generic strnlen_user for 32-bit big-endian machines [Paul Mackerras]
2014-03-15 | lib: add generic strnlen_user() function [Linus Torvalds]
2014-03-15 | KVM: x86: Fix potential divide by 0 in lapic (CVE-2013-6367) [Andy Honig]
2014-03-15 | KVM: return an error code in kvm_vm_ioctl_register_coalesced_mmio() [Dan Carpenter]
2014-03-15 | KVM: Fix buffer overflow in kvm_set_irq() [Avi Kivity]
2014-03-15 | kernel: Move REPEAT_BYTE definition into linux/kernel.h [faux123]
2014-03-15 | intel-iommu: fix off-by-one in pagetable freeing [Alex Williamson]
2014-03-15 | Input: synaptics - handle out of bounds values from the hardware [Seth Forshee]
2014-03-15 | inet_diag: fix inet_diag_dump_icsk() timewait socket state logic [Neal Cardwell]
2014-03-15 | IB/qib: Fix QP check when looping back to/from QP1 [Ira Weiny]
2014-03-15 | IB/qib: Convert qib_user_sdma_pin_pages() to use get_user_pages_fast() [Jan Kara]
2014-03-15 | IB/qib: Add missing serdes init sequence [Mike Marciniszyn]
2014-03-15 | hpfs: deadlock and race in directory lseek() [Al Viro]
2014-03-15 | hp_accel: Add a new PnP ID HPQ6007 for new HP laptops [Takashi Iwai]
2014-03-15 | genirq: Add missing irq_to_desc export for CONFIG_SPARSE_IRQ=n [Paul Gortmaker]
2014-03-15 | ftrace: Synchronize setting function_trace_op with ftrace_trace_function [Steven Rostedt]
2014-03-15 | ftrace: Have function graph only trace based on global_ops filters [Steven Rostedt]
2014-03-15 | ftrace: Fix synchronization location disabling and freeing ftrace_ops [Steven Rostedt]
2014-03-15 | fs/file.c:fdtable: avoid triggering OOMs from alloc_fdmem [Eric W. Biederman]
2014-03-15 | ext4: protect group inode free counting with group lock [Tao Ma]
2014-03-15 | e752x_edac: Fix pci_dev usage count [Aristeu Rozanski]
2014-03-15 | drm/radeon: warn users when hw_i2c is enabled (v2) [Alex Deucher]
2014-03-15 | drm/radeon: skip colorbuffer checking if COLOR_INFO.FORMAT is set to INVALID [Marek Olšák]
2014-03-15 | drm/radeon: set the full cache bit for fences on r7xx+ [Alex Deucher]
2014-03-15 | drm/radeon/DCE4+: clear bios scratch dpms bit (v2) [Alex Deucher]
2014-03-15 | drm/i915: kick any firmware framebuffers before claiming the gtt [Daniel Vetter]
2014-03-15 | dm: wait until embedded kobject is released before destroying a device [Mikulas Patocka]
2014-03-15 | dm sysfs: fix a module unload race [Mikulas Patocka]
2014-03-15 | dm space map common: make sure new space is used during extend [Joe Thornber]
2014-03-15 | decompress_unlzo: fix compilation error [faux123]
2014-03-15 | Bump for camera changes [Josue Rivera]
2014-03-15 | Bump for 3.4.81 [arcardinal]
2014-03-15 | Bump for 3.4.80 [arcardinal]
2014-03-15 | Bump for 3.4.79 [arcardinal]
2014-03-15 | Btrfs: handle EAGAIN case properly in btrfs_drop_snapshot() [Wang Shilong]
2014-03-15 | bnx2x: fix DMA unmapping of TSO split BDs [Michal Schmidt]
2014-03-15 | block: add cond_resched() to potentially long running ioctl discard loop [Jens Axboe]
2014-03-15 | b43: fix the wrong assignment of status.freq in b43_rx() [ZHAO Gang]
2014-03-15 | audit: correct a type mismatch in audit_syscall_exit() [AKASHI Takahiro]
2014-03-15 | ASoC: adau1701: Fix ADAU1701_SEROCTL_WORD_LEN_16 constant [Lars-Peter Clausen]
2014-03-15 | arm: vfpmodule: Fix warning procfs vfp_bounce reporting failed [myfluxi]
2014-03-15 | ARM: use generic strnlen_user and strncpy_from_user functions [Paul Reioux]
2014-03-15 | ARM: only allow kernel mode neon with AEABI [Russell King]
2014-03-15 | ARM: mutex: use generic atomic_dec-based implementation for ARMv6+ [Will Deacon]
2014-03-15 | ARM: move VFP init to an earlier boot stage [Paul Reioux]
2014-03-15 | ARM: mm: update __v7_setup() to the new LoUIS cache maintenance API [Santosh Shilimkar]
2014-03-15 | ARM: mm: rename jump labels in v7_flush_dcache_all function [Lorenzo Pieralisi]
2014-03-15 | ARM: kernel: update __cpu_disable to use cache LoUIS maintenance API [Lorenzo Pieralisi]
2014-03-15 | ARM: fault: assume no context when IRQs are disabled during data abort. [JP Abgrall]
2014-03-15 | ARM: disable ALIGNMENT_TRAP if HAVE_EFFICIENT_UNALIGNED_ACCESS [Paul Reioux]
2014-03-15 | ARM: dcache: select DCACHE_WORD_ACCESS for little-endian ARMv6+ CPUs [Will Deacon]
2014-03-15 | ARM: crypto: add NEON accelerated XOR implementation [Ard Biesheuvel]
2014-03-15 | ARM: be strict about FP exceptions in kernel mode [Paul Reioux]
2014-03-15 | ARM: at91: smc: bug fix in sam9_smc_cs_read() [Jean-Jacques Hiblot]
2014-03-15 | ARM: add support for kernel mode NEON [Paul Reioux]
2014-03-15 | ARM: 7835/2: fix modular build of xor_blocks() with NEON enabled [Ard Biesheuvel]
2014-03-15 | ARM: 7593/1: nommu: do not enable DCACHE_WORD_ACCESS when !CONFIG_MMU [faux123]
2014-03-15 | ARM: 7592/1: nommu: prevent generation of kernel unaligned memory accesses [Will Deacon]
2014-03-15 | ARM: 7583/1: decompressor: Enable unaligned memory access for v6 and above [Dave Martin]
2014-03-15 | ARM: 7493/1: use generic unaligned.h [faux123]
2014-03-15 | ARM: 7492/1: add strstr declaration for decompressors [Rob Herring]
2014-03-15 | ARM: 7467/1: mutex: use generic xchg-based implementation for ARMv6+ [Will Deacon]
2014-03-15 | arch/arm/kernel/armksyms: fix merge derp [faux123]
2014-03-15 | arch/arm/Kconfig: enable unaligned capability for ARM [faux123]
2014-03-15 | amami : add cm_rhine_amami_row_defconfig [Shane Francis]
2014-03-15 | ALSA: rme9652: fix a missing comma in channel_map_9636_ds[] [Takashi Iwai]
2014-03-15 | ALSA: Enable CONFIG_ZONE_DMA for smaller PCI DMA masks [Takashi Iwai]
2014-03-15 | ACPI / init: Flag use of ACPI and ACPI idioms for power supplies to regulator API [Mark Brown]
2014-03-14 | Revert "msm: clock-8974: Reduce PLL lock time" [Giulio Cervera]
2014-03-14 | Makefile: fix build with gcc 4.8 [Androguide]
2014-03-14 | Fix F/C in TTS settings [Shuhrat Dehkanov]
2014-03-14 | Bump version # [Josue Rivera]
2014-03-14 | Bump for CM update [Josue Rivera]
2014-03-13 | take account of RotationVector's new extra parameter [Balint Ureczky]
2014-03-13 | Round off when calculate next step in Seekbar [Marcus Danielsson]
2014-03-13 | NFC: getNdefMessage() should throw exception if no tag in field. [Mathias Jeppsson]
2014-03-13 | Mms: process stops after sharing a video through Messaging [Bin Yang]2014-03-16 | Settings: More Lockscreen Colors (2/2) (HEAD, m/kk4.4, github/kk4.4) [Jubakuba]
2014-03-13 | Hang off call by power button while screen is on [shower]
2014-03-12 | PM / devfreq: Fix out of bounds access of transition table array [Saravana Kannan]
2014-03-12 | msm: pm: print active clocks before entering into pc [Anil kumar mamidala]
2014-03-12 | msm: pm: bug in pc debug counters logic [Anil kumar mamidala]
2014-03-12 | msm: mdss: synchronize wfd driver iommu mmap/munmap with mdss [Pawan Kumar]
2014-03-12 | msm: mdss: optimize MDP pipes cleanup [Adrian Salido-Moreno]
2014-03-12 | msm: mdss: Decimation and BWC cannot be enabled together [Sree Sesha Aravind Vadrevu]
2014-03-12 | msm: mdss: add bus bandwidth request enable/disable during get/free buffer [Pawan Kumar]
2014-03-12 | msm: lpm_levels: return new idle level to cpuidle framework [Anil kumar mamidala]
2014-03-12 | msm: lpm_levels: remove rpm handshake in l2_gdhs mode [Anil kumar mamidala]
2014-03-12 | ion: system_heap: only use low gfp flags for order-0 pages [Mitchel Humpherys]
2014-03-12 | ARM: dts: msm: lower LDO 11 minimum voltage constraint for msm8974 [David Collins]
2014-03-11 | wcnss: pil-pronto: Add register dump to bite handler [Sameer Thalappil]
2014-03-11 | wcnss: Enable/disable WCNSS register dump on WCNSS bite [Sameer Thalappil]
2014-03-11 | wcnss: Add API to expose the IRIS XO mode set [Sameer Thalappil]
2014-03-11 | switch: hds_max1462x: revert & Fix unbalanced IRQ [houst0nn]
2014-03-11 | Perf: Fix counts across power collapse [Sheetal Sahasrabudhe]
2014-03-11 | Perf: Add cortex A7 perf support [Neil Leeder]
2014-03-11 | msm: subsystem_restart: Move device tree parsing code into the framework [Seemanta Dutta]
2014-03-11 | msm: socinfo: Add support for MSM8974PRO AA/AB/AC [Stepan Moskovchenko]
2014-03-11 | msm: smem: split out shared memory initialization functionality [Jeff Hugo]
2014-03-11 | msm: smem: Add non-locking smem-get function [Eric Holmberg]
2014-03-11 | msm: smem: Add NAND Device Item [Eric Holmberg]
2014-03-11 | msm: smem: add mpu based security support [Jeff Hugo]
2014-03-11 | msm: smd: add support for secondary channel table [Jeff Hugo]
2014-03-11 | msm: scm-pas: Remove cpu_is_* checks [Deepak Katragadda]
2014-03-11 | msm: scm-pas: Flush the metadata buffer [Vikram Mulukutla]
2014-03-11 | msm: pm: send notification only for SPC and PC [Venkat Devarasetty]
2014-03-11 | msm: pm-8x60: Use generic clk apis during power collapse [Mahesh Sivasubramanian]
2014-03-11 | msm: pil-venus: Move the GDSC control out of PIL driver [Tianyi Gou]
2014-03-11 | msm: pil-venus: Decrease the proxy time out value [Tianyi Gou]
2014-03-11 | msm: pil: Unregister modem notifer on failure to create kobj [Deepak Katragadda]
2014-03-11 | msm: pil-q6v5-mss: Set the force stop bit and wait for ack when necessary [Seemanta Dutta]
2014-03-11 | msm: pil-q6v5-mss: Perform proxy voting/unvoting at mba bootup [Seemanta Dutta]
2014-03-11 | msm: pil-q6v5-mss: Initialize the stop ack completion variable [Seemanta Dutta]
2014-03-11 | msm: pil-q6v5-mss: Get smem reason buffer without taking remote spinlock [Seemanta Dutta]
2014-03-11 | msm: pil-q6v5-mss: Factor out PIL code into a separate library. [Seemanta Dutta]
2014-03-11 | msm: pil-q6v5-mss: Do not generate redundant smem ramdump [Seemanta Dutta]
2014-03-11 | msm: pil-q6v5-mss: Correct kzalloc return path checking [Vikram Mulukutla]
2014-03-11 | msm: pil-q6v5-lpass: Remove disabling watchdog irq multiple times [Deepak Katragadda]
2014-03-11 | msm: pil: Proxy unvote after pil_shutdown() when using IRQs [Seemanta Dutta]
2014-03-11 | msm: pil: Move device tree parsing code into the framework [Seemanta Dutta]
2014-03-11 | msm: peripheral_loader: Use the new request_firmware_direct API [Vikram Mulukutla]
2014-03-11 | msm: peripheral-loader: Print firmware start and end addresses [Patrick Daly]
2014-03-11 | msm: peripheral-loader: Log clk-ready IRQ to help with debugging [Deepak Katragadda]
2014-03-11 | msm: peripheral-loader: Fix double irq enable [Patrick Daly]
2014-03-11 | msm: msm_bus: send correct value to bw division function [Alok Chauhan]
2014-03-11 | msm: msm_bus: Fix the type error causing bandwidth overflow [Alok Chauhan]
2014-03-11 | msm: msm_bus: Don't touch ID array in case of invalid IDs [Gagan Mac]
2014-03-11 | msm: msm_bus: Correct the return value from register-client [Gagan Mac]
2014-03-11 | msm: msm_bus: Changes for QOS computation at BIMC [Girish Mahadevan]
2014-03-11 | msm: msm_bus: Change priority overrides based on master configuration [Sagar Dharia]
2014-03-11 | msm: msm_bus: Add checks during bus client unregistration [Gagan Mac]
2014-03-11 | msm: idle-v7: Separate PC termination for hotplug [Mahesh Sivasubramanian]
2014-03-11 | msm: idle-v7: flush non secure L1 cache lines for l2 GDHS LPM mode [Murali Nalajala]
2014-03-11 | msm: idle-v7: Add support to pass tz flag when core is hotplugged [Priyanka Mathur]
2014-03-11 | msm: hsic_sysmon: Support multiple instances [Jack Pham]
2014-03-11 | msm: gdsc: Make enable/disable function clock controls symmetric [Matt Wagantall]
2014-03-11 | msm: clock-krait: Read CONFIG_CTL value and the vco mask from DT [Vikram Mulukutla]
2014-03-11 | msm: clock-krait: Clock ops library for Krait subsystem clocks [Saravana Kannan]
2014-03-11 | msm: clock-krait: Always configure low performance level krait clock tree [Saravana Kannan]
2014-03-11 | msm: clock-krait-8974: Run force reinit sequence for all CPUs [Saravana Kannan]
2014-03-11 | msm: clock-krait-8974: Fall back to safest PVS when table not found [Junjie Wu]
2014-03-11 | msm: clock-krait-8974: Add support for 8974 Krait clocks [Saravana Kannan]
2014-03-11 | msm: clock-generic: Update the rate field on mux parent change. [Saravana Kannan]
2014-03-11 | msm: clock-generic: Return best parent_rate from div_round_rate [Patrick Daly]
2014-03-11 | msm: clock-generic: Reorganize divider clock parameters [Patrick Daly]
2014-03-11 | msm: clock-generic: Refactor round rate code [Saravana Kannan]
2014-03-11 | msm: clock-generic: Move mux_reg_ops to clock-local2 [Vikram Mulukutla]
2014-03-11 | msm: clock-generic: Make ops options for div_clk [Saravana Kannan]
2014-03-11 | msm: clock-generic: Introduce an ext_clk clock type [Vikram Mulukutla]
2014-03-11 | msm: clock-generic: Handle round rate return values greater than LONG_MAX [Saravana Kannan]
2014-03-11 | msm: clock-generic: Fix race condition between mux set rate and en/dis [Saravana Kannan]
2014-03-11 | msm: clock-generic: Allow separate enable/mux-select registers [Vikram Mulukutla]
2014-03-11 | msm: clock-generic: Add support for recursive set parent to mux_clk [Saravana Kannan]
2014-03-11 | msm: clock-generic: Add get_rate op for ext clocks [Vikram Mulukutla]
2014-03-11 | msm: clock-generic: Add a get_rate op for slave dividers [Vikram Mulukutla]
2014-03-11 | msm: clock-generic: Add a combined mux_div clock [Patrick Daly]
2014-03-11 | msm: clock-dummy: Rate-setable independent dummy clocks [Junjie Wu]
2014-03-11 | msm: clock: Add pre_set_rate and post_set_rate ops [Saravana Kannan]
2014-03-11 | msm: clock: Add is_better_rate() helper function [Saravana Kannan]
2014-03-11 | msm: clock-8974: Add an active-only GPLL0 clock [Vikram Mulukutla]
2014-03-11 | msm: clock-8610: Switch camera muxes to generic mux implementation [Vikram Mulukutla]
2014-03-11 | msm: 8x10 BKE settings patch [Saurabh Saxena]
2014-03-11 | mmc: block: Fix error path of mmc_blk_alloc_req() [Sahitya Tummala]
2014-03-11 | galbi: smem: split out shared memory initialization functionality [Ricardo Cerqueira]
2014-03-11 | frameworks/base: translation - RU [gwindlord]
2014-03-11 | common: make cpaccess module code writeable [Neil Leeder]
2014-03-11 | clock-krait-8974: Increase PVS bin efuse field to a 4-bit field [Saravana Kannan]
2014-03-11 | arm: tracing: disable tracing for the timer clock functions [Pushkar Joshi]
2014-03-11 | ARM: sched_clock: Load cycle count after epoch stabilizes [Stephen Boyd]
2014-03-11 | ARM: move signal handlers into a vdso-like page [Russell King]
2014-03-11 | arm: mm: Define set_memory_* functions for ARM [Laura Abbott]
2014-03-11 | arm: mm: Add export symbol for set_memory_* functions [Laura Abbott]
2014-03-11 | ARM: Fix the world famous typo with is_gate_vma() [Russell King]
2014-03-11 | ARM: fix nommu builds with 48be69a02 (ARM: move signal handlers into a vdso-like page) [Russell King]
2014-03-11 | ARM: Fix FIQ code on VIVT CPUs [Russell King]
2014-03-11 | ARM: fix a cockup in 48be69a02 (ARM: move signal handlers into a vdso-like page) [Russell King]
2014-03-11 | ARM: dts: msm: add perf-events support for msm8226 [Neil Leeder]
2014-03-11 | ARM: dts: msm8610: Fix priorities of Krait on 8610 [Gagan Mac]
2014-03-11 | ARM/dt: 8610: Correct MMSS NoC - BIMC gateway node [Gagan Mac]
2014-03-11 | arm/dt: 8610: Add coreisght support for bus devices [Gagan Mac]
2014-03-11 | arm: Add definitions for pte_mkexec/pte_mknexec [Laura Abbott]
2014-03-11 | ARM: 7880/1: Clear the IT state independent of the Thumb-2 mode [T.J. Purtell]
2014-03-11 | ARM: 7819/1: fiq: Cast the first argument of flush_icache_range() [Fabio Estevam]
2014-03-11 | ARM: 7565/1: sched: stop sched_clock() during suspend [Felipe Balbi 2]
2014-03-11 | ARM: 7486/1: sched_clock: update epoch_cyc on resume [Colin Cross]
2014-03-10 | xen-blkfront: handle backend CLOSED without CLOSING [David Vrabel]
2014-03-10 | x86, x32: Correct invalid use of user timespec in the kernel [PaX Team]
2014-03-10 | x86, hweight: Fix BUG when booting with CONFIG_GCOV_PROFILE_ALL=y [Peter Oberparleiter]
2014-03-10 | virtio-blk: Use block layer provided spinlock [Asias He]
2014-03-10 | usb: xhci: Check for XHCI_PLAT in xhci_cleanup_msix() [Jack Pham]
2014-03-10 | usb-storage: restrict bcdDevice range for Super Top in Cypress ATACB [Alan Stern]
2014-03-10 | usb-storage: enable multi-LUN scanning when needed [Alan Stern]
2014-03-10 | usb-storage: add unusual-devs entry for BlackBerry 9000 [Alan Stern]
2014-03-10 | USB: serial: add support for iBall 3.5G connect usb modem [Rahul Bedarkar]
2014-03-10 | usb: option: blacklist ZTE MF667 net interface [Raymond Wanyoike]
2014-03-10 | usb: option: add new zte 3g modem pids to option driver [ĺĽ ĺ�›]
2014-03-10 | USB: Nokia 502 is an unusual device [Mikhail Zolotaryov]
2014-03-10 | USB: ftdi_sio: add Tagsys RFID Reader IDs [Ulrich Hahn]
2014-03-10 | usb: ftdi_sio: add Mindstorms EV3 console adapter [Bjørn Mork]
2014-03-10 | USB: cypress_m8: fix ring-indicator detection and reporting [Johan Hovold]
2014-03-10 | usb: core: get config and string descriptors for unauthorized devices [Thomas Pugliese]
2014-03-10 | turbostat: Use GCC's CPUID functions to support PIC [Josh Triplett]
2014-03-10 | tty/serial: at91: Handle shutdown more safely [Marek Roszko]
2014-03-10 | tty: n_gsm: Fix for modems with brk in modem status control [Lars Poeschel]
2014-03-10 | timekeeping: Avoid possible deadlock from clock_was_set_delayed [John Stultz]
2014-03-10 | time: Fix overflow when HZ is smaller than 60 [Mikulas Patocka]
2014-03-10 | target/iscsi: Fix network portal creation race [Andy Grover]
2014-03-10 | target/file: Use O_DSYNC by default for FILEIO backends [Nicholas Bellinger]
2014-03-10 | target/file: Re-enable optional fd_buffered_io=1 operation [Nicholas Bellinger]
2014-03-10 | Switch to CM's power hal [Josue Rivera]2014-03-16 | Update device.mk to target vzw-g2.mk (HEAD, m/kk4.4, github/kk4.4) [arcardinal]2014-03-17 | galaxys2-common: Update RIL header to v9 [2/2] (HEAD, m/kk4.4, github/kk4.4) [Andrew Jiang]2014-03-16 | i9300: audio: fix battery drain after phone call [Javier Ferrer]2014-03-17 | n7100: audio: update hal (HEAD, m/kk4.4, github/kk4.4) [UtkarshGupta]
2014-03-10 | sunrpc: Fix infinite loop in RPC state machine [Weston Andros Adamson]
2014-03-10 | staging: vt6656: [BUG] BBvUpdatePreEDThreshold Always set sensitivity on bScanning [Malcolm Priestley]
2014-03-10 | staging: r8712u: Set device type to wlan [Larry Finger]
2014-03-10 | staging:iio:ad799x fix error_free_irq which was freeing an irq that may not have been requested [Hartmut Knaack]
2014-03-10 | spi: Fix crash with double message finalisation on error handling [Geert Uytterhoeven]
2014-03-10 | spidev: fix hang when transfer_one_message fails [Daniel Santos]
2014-03-10 | slub: Fix calculation of cpu slabs [Li Zefan]
2014-03-10 | serial: add support for 200 v3 series Titan card [Yegor Yefremov]
2014-03-10 | SELinux: Fix memory leak upon loading policy [Tetsuo Handa]
2014-03-10 | SELinux: Fix kernel BUG on empty security contexts. [Stephen Smalley]
2014-03-10 | SCSI: bfa: Chinook quad port 16G FC HBA claim issue [Vijaya Mohan Guvva]
2014-03-10 | sched: Unthrottle rt runqueues in __disable_runtime() [Peter Boonstoppel]
2014-03-10 | sched,rt: fix isolated CPUs leaving root_task_group indefinitely throttled [Mike Galbraith]
2014-03-10 | sched/rt: Avoid updating RT entry timeout twice within one tick period [Ying Xue]
2014-03-10 | sched/nohz: Fix rq->cpu_load calculations some more [Peter Zijlstra]
2014-03-10 | sched/nohz: Fix rq->cpu_load[] calculations [Peter Zijlstra]
2014-03-10 | s390: fix kernel crash due to linkage stack instructions [Martin Schwidefsky]
2014-03-10 | s390/dump: Fix dump memory detection [Michael Holzheu]
2014-03-10 | rtlwifi: Set the link state [Larry Finger]
2014-03-10 | rtlwifi: rtl8192cu: Fix some code in RF handling [Larry Finger]
2014-03-10 | rtlwifi: rtl8192cu: Add new device ID [Larry Finger]
2014-03-10 | rtc-cmos: Add an alarm disable quirk [Borislav Petkov]
2014-03-10 | ring-buffer: Fix first commit on sub-buffer having non-zero delta [Steven Rostedt (Red Hat)]
2014-03-10 | raw: test against runtime value of max_raw_minors [Paul Bolle]
2014-03-10 | radeon/pm: Guard access to rdev->pm.power_state array [Michel Dänzer]
2014-03-10 | powerpc: Make sure "cache" directory is removed when offlining cpu [Paul Mackerras]
2014-03-10 | power: max17040: Fix NULL pointer dereference when there is no platform_data [Krzysztof Kozlowski]
2014-03-10 | PM / Hibernate: Hibernate/thaw fixes/improvements [Bojan Smojver]
2014-03-10 | PCI: Enable ARI if dev and upstream bridge support it; disable otherwise [Yijing Wang]
2014-03-10 | parport: parport_pc: remove double PCI ID for NetMos [Sebastian Andrzej Siewior]
2014-03-10 | ore: Fix wrong math in allocation of per device BIO [Boaz Harrosh]
2014-03-10 | NFSv4: OPEN must handle the NFS4ERR_IO return code correctly [Trond Myklebust]
2014-03-10 | nfs: tear down caches in nfs_init_writepagecache when allocation fails [Jeff Layton]
2014-03-10 | nfs4.1: properly handle ENOTSUP in SECINFO_NO_NAME [Weston Andros Adamson]
2014-03-10 | net,via-rhine: Fix tx_timeout handling [Richard Weinberger]
2014-03-10 | net: avoid reference counter overflows on fib_rules in multicast forwarding [Hannes Frederic Sowa]
2014-03-10 | mtd: mxc_nand: remove duplicated ecc_stats counting [Michael Grzeschik]
2014-03-10 | Modpost: fixed USB alias generation for ranges including 0x9 and 0xA [Jan Moskyto Matejka]
2014-03-10 | mm: setup pageblock_order before it's used by sparsemem [Xishi Qiu]
2014-03-10 | mm: __set_page_dirty uses spin_lock_irqsave instead of spin_lock_irq [KOSAKI Motohiro]
2014-03-10 | mm: __set_page_dirty_nobuffers() uses spin_lock_irqsave() instead of spin_lock_irq() [KOSAKI Motohiro]
2014-03-10 | mm/page_alloc.c: remove pageblock_default_order() [Andrew Morton]
2014-03-10 | mm: hugetlbfs: fix hugetlbfs optimization [Andrea Arcangeli]
2014-03-10 | mmc: atmel-mci: fix timeout errors in SDIO mode when using DMA [Ludovic Desroches]
2014-03-10 | md/raid5: fix long-standing problem with bitmap handling on write failure. [NeilBrown]
2014-03-10 | md/raid5: Fix CPU hotplug callback registration [Oleg Nesterov]
2014-03-10 | mac80211: fix fragmentation code, particularly for encryption [Johannes Berg]
2014-03-10 | lockd: send correct lock when granting a delayed lock. [NeilBrown]
2014-03-10 | Linux 3.4.82 [Greg Kroah-Hartman]
2014-03-10 | Linux 3.4.81 [Greg Kroah-Hartman]
2014-03-10 | Linux 3.4.80 [Greg Kroah-Hartman]
2014-03-10 | Linux 3.4.79 [Greg Kroah-Hartman]
2014-03-10 | lib/vsprintf.c: kptr_restrict: fix pK-error in SysRq show-all-timers(Q) [Dan Rosenberg]
2014-03-10 | KVM: x86: Fix potential divide by 0 in lapic (CVE-2013-6367) [Andy Honig]
2014-03-10 | KVM: return an error code in kvm_vm_ioctl_register_coalesced_mmio() [Dan Carpenter]
2014-03-10 | KVM: Fix buffer overflow in kvm_set_irq() [Avi Kivity]
2014-03-10 | intel-iommu: fix off-by-one in pagetable freeing [Alex Williamson]
2014-03-10 | Input: synaptics - handle out of bounds values from the hardware [Seth Forshee]
2014-03-10 | inet_diag: fix inet_diag_dump_icsk() timewait socket state logic [Neal Cardwell]
2014-03-10 | IB/qib: Fix QP check when looping back to/from QP1 [Ira Weiny]
2014-03-10 | IB/qib: Convert qib_user_sdma_pin_pages() to use get_user_pages_fast() [Jan Kara]
2014-03-10 | IB/qib: Add missing serdes init sequence [Mike Marciniszyn]
2014-03-10 | hpfs: deadlock and race in directory lseek() [Al Viro]
2014-03-10 | hp_accel: Add a new PnP ID HPQ6007 for new HP laptops [Takashi Iwai]
2014-03-10 | genirq: Add missing irq_to_desc export for CONFIG_SPARSE_IRQ=n [Paul Gortmaker]
2014-03-10 | ftrace: Synchronize setting function_trace_op with ftrace_trace_function [Steven Rostedt]
2014-03-10 | ftrace: Have function graph only trace based on global_ops filters [Steven Rostedt]
2014-03-10 | ftrace: Fix synchronization location disabling and freeing ftrace_ops [Steven Rostedt]
2014-03-10 | fs/file.c:fdtable: avoid triggering OOMs from alloc_fdmem [Eric W. Biederman]
2014-03-10 | Frameworks: derp [Lars Greiss]
2014-03-10 | frameworks/base - translation: RU [gwindlord]
2014-03-10 | Fix Cortex-a15 compile (HEAD, m/kk4.4, github/kk4.4) [Josue Rivera]2014-03-16 | Add vzw-g2.mk (HEAD, m/kk4.4, github/kk4.4) [arcardinal]
2014-03-10 | ext4: protect group inode free counting with group lock [Tao Ma]
2014-03-10 | e752x_edac: Fix pci_dev usage count [Aristeu Rozanski]
2014-03-10 | drm/radeon: warn users when hw_i2c is enabled (v2) [Alex Deucher]
2014-03-10 | drm/radeon: skip colorbuffer checking if COLOR_INFO.FORMAT is set to INVALID [Marek Olšák]
2014-03-10 | drm/radeon: set the full cache bit for fences on r7xx+ [Alex Deucher]
2014-03-10 | drm/radeon/DCE4+: clear bios scratch dpms bit (v2) [Alex Deucher]
2014-03-10 | drm/i915: kick any firmware framebuffers before claiming the gtt [Daniel Vetter]
2014-03-10 | dm: wait until embedded kobject is released before destroying a device [Mikulas Patocka]
2014-03-10 | dm sysfs: fix a module unload race [Mikulas Patocka]
2014-03-10 | dm space map common: make sure new space is used during extend [Joe Thornber]
2014-03-10 | Bump for 3.4.81 [Josue Rivera]
2014-03-10 | Bump for 3.4.80 [Josue Rivera]
2014-03-10 | Bump for 3.4.79 [Josue Rivera]
2014-03-10 | Btrfs: handle EAGAIN case properly in btrfs_drop_snapshot() [Wang Shilong]
2014-03-10 | bnx2x: fix DMA unmapping of TSO split BDs [Michal Schmidt]
2014-03-10 | block: add cond_resched() to potentially long running ioctl discard loop [Jens Axboe]
2014-03-10 | b43legacy: Fix unload oops if firmware is not available [Larry Finger]
2014-03-10 | b43: Fix unload oops if firmware is not available [Larry Finger]
2014-03-10 | b43: fix the wrong assignment of status.freq in b43_rx() [ZHAO Gang]
2014-03-10 | b43: Fix lockdep splat [Larry Finger]
2014-03-10 | audit: correct a type mismatch in audit_syscall_exit() [AKASHI Takahiro]
2014-03-10 | ASoC: adau1701: Fix ADAU1701_SEROCTL_WORD_LEN_16 constant [Lars-Peter Clausen]
2014-03-10 | ARM: at91: smc: bug fix in sam9_smc_cs_read() [Jean-Jacques Hiblot]
2014-03-10 | apps/Settings - translation: RU [gwindlord]
2014-03-10 | apps/Browser: translation - RU [gwindlord]
2014-03-10 | ALSA: rme9652: fix a missing comma in channel_map_9636_ds[] [Takashi Iwai]
2014-03-10 | ALSA: Enable CONFIG_ZONE_DMA for smaller PCI DMA masks [Takashi Iwai]
Reaktionen: Jrp Defy, CVH, hara74 und eine weitere Person
Hab direkt Probleme mit Player Pro gehabt mit der Version in der neuen Weekly. Er findet nur sdcard0 und nicht die Musik auf meiner SD Karte (sdcard1) Zeigt das ganze Laufwerk nicht an. Root Explorer geht ohne Probleme und von da aus kann ich auch die MP3s manuell starten.
:confused2: hää....?
Bei mir ist Player Pro nicht in der Weekly!
BTW: Poweramp u. N7Playyer machen keine Probleme!
Ich denke das er damit sagen will das der Player seit er die neue Weekly Installiert hat Probleme macht :)
Gibt es schon ein Termin für die nächste Stable?
die bisherigen Weekly waren bei mir nicht mehr oder weniger stabil als die "stable", daher handelt es sich in meinen Augen "nur" um einen Termin ohne Mehrleistung.
Anders herum aber:
Die "stable" Versionen hatten nach meinem Wissen hinten immer eine 0. Siehe auch letzte vom 16.2.
Demnach wäre dann also nächste Woche (24ter/25ter) die aktuellere "stable" fällig! :drool:
Kann mich aber auch irren!:tongue:
Reaktionen: Yandroid94
Stimmt, klinkt logisch, danke :)
Achtung. Eilmeldung auf g+
"SlimKat weekly 3.9 released. -It is highly recommended to download and flash the new gapps package to have everything fully working.*Gapps filename is the same as last week (check the upload date).*YouTube still remains to the old one due that google is still fixing latest version.
Read the announcement in full at our website: http://www.slimroms.net"
Wenn es läuft, dann hat man einen Lauf.
http://www.slimroms.net/index.php/changelog/440-build-3-9-changelog
Reaktionen: starmagoo, Jrp Defy, plauzeee und 2 andere
Hmm. Von 3.9 auf 3.1 . komische Nummerierung
Wieso? 3.9 dann 3.10, was stimmt nicht daran?
Schon gut. Hab 3.1 gelesen. Wollte den kommi schon löschen aber geht bei tapatalk nicht oder ich weiss zumindest nicht wie. Wieder schneller geschrieben als gelesen .
In Tapatalk den eigenen Post markieren, auf den Stift klicken und dann editieren :)
Reaktionen: plauzeee und MichelFell
Und damit es nicht zu langweilig wird, gibt es von heute auch gleich nochmals frische Gapps dazu!
klickmich!
BTW: Der etwas höhere Akkuverbrauch der letzten Zeit scheint überwunden zu sein. Bei mir sind es nun 2% (offline) in 24Std. ggü 6% vorher.
On Air sind die Werte sicherlich deutlich höher!:winki: Ich wollte aber mal den reinen Systemverbrauch messen ohne variable Zusätze von Apps oder Verbraiuchern.
Reaktionen: plauzeee, hara74 und MichelFell
Ich bekomme seit gestern permanent broadcast Meldungen. Hat jemand ne Idee wie ich das abschalten kann. Eingeschaltet habe ich nichts.
Thomas
Gesendet von meinem INM8002KP mit der Android-Hilfe.de App
Es gibt wohl nur eine extra Einstellung, wenn als Std. SMS Programm in den Systemeinstellungen Hangouts aktiviert ist. Dann geht das wohl in Hangouts/Einstellungen. Der normalerweise in den Systemeinstellungen von KitKat mal vorhandene Menpunkt wurde hier deswegen entfernt.
Edit: Ursprüngliche Aussage wurde angepasst.
bauner
bauner
bauner
bauner
Talinsei
bauner
bauner
bauner
