[ROM][4.1.2]RR JB v3.1.1 AOKP Milestone1[N8000/8010]
  • 15 Antworten
FCB-Fan
FCB-Fan
Dauer-User
648
XDA-Thread
About Resurrection Remix AOKP Edition:
Since version 1.2 of Resurrection Remix the ROM has been based on AOKP, CM9/10 and original Remix ROM builds, this creates an awesome combination of performance, customization, power and the most new features, brought directly to your Device
Many things that in previous versions were tweaked with mods, are now included by default in the ROM so, please enjoy!
August 5th 2012, saw Resurrection Remix is release for Samsung Galaxy SIII (GT-I9300) devices.
November 1st 2012, Resurrection Remix released for Samsung Galaxy Note 10.1 (N8000) devices.
Special thanks to the AOKP team, the CM9/10 team, and of course to all the supporters
Included Mods
-Toggles
-Center Clock/No clock/Right Clock
-AM/PM display
-AOKP clocks and Digital Clock
-New Wallpapers
-Volume rocker moves cursor when keyboard is open (optional)
-Nova/Stock launcher included
-%1 battery mod and CircleMod battery
-Brightness adjustable via statusbar if auto brightness is disabled. It even shows your current brightness percentage as you slide!
-There's also a "Emergency Broadcast Settings" that allows you to check/uncheck for notifications of "Amber Alerts" and other such Local Emergencies. I personally haven't seen this yet in the other Jelly Builds.
-Change NavBar targets and long-press actions
-Battery Bar
-Change NavBar height
-Volume Panel (Volume Rocker allows you to change ALL volume levels in one Menu)
-Notification Counter
-Disable Boot Animation
-AOKP Statistics
-Device Options (Color Tweaks)
-Led Options (Color and Pulse Rate)
-NFC Polling Mode (NFC with Screen Off or Locked)
-Theme Engine
-Quiet Hours
-T9 Dialer
-Notification Shade Wallpaper Changer (And Transparency)
-Lockscreen Wallpaper Changer
-Wait To Lock Screen
-Volume Wake
-Quick Pin Unlock
-Phone Face-Down Ringer Setting (Silent/Vibrate)
-Headphones Plugged in Ringer Setting (Silent/Vibrate)
-Bluetooth Connection Ringer Setting (Silent/Vibrate)
-Lockscreen Weather
-Performance/Color Settings
-Brightness Control Slider
-Added Device (Color) Settings To Maguro
-Flip Phone To Silence Incoming Call
-NavBar Open/Close Notification Shade Option
-A Plethora of BugFixes and Updated Translations
  • Backup erstellen
  • Wipe Data/Factory Reset
  • ROM installieren
  • Fix Permissions
  • Reboot
Screenshots
[/CENTER]
Gesendet von meinem GT-N8000 mit "Stock"-JB *-*
Reserve
Super geile Rom. Die Rom funtzt ohne Probleme mit der n8010 Version.
Tolle Arbeit. Kein Vergleich zu ICS.
Hab die Rom nun knapp eine Woche ohne probleme auf meinem n8010.
S note funktioniert hier aber nicht oder ?
Ich glaube nicht. Der Stift funktioniert aber mit Lecture Notes und ezpdf, oder?
Gesendet von meinem GT-N8010 mit der Android-Hilfe.de App
S-Note ist eine Samsung Application... wenn der ROM auf einem Samsung Stock ROM basiert funktioniert es...
Der Stift funktioniert bei allen ROMs die den Standard / Originalen Kernel nutzen... denn dort ist die Stiftfunktion enhalten ;-)
Seit 4.0 sogar auf ROMs die andere Kernel nutzen, da die Treiber schon in Android integriert sind ;)
Gesendet von meinem S3 mit Android 4.1.2
Gleich mal probieren mit meinem N8010. Wenns gut läuft, werd ichs die Woche mal testen, mal sehen obs geil ist. :)
Ehrlich gesagt nicht so begeistert. :( Schade.
Und beim zurück flahen per recovery konnten die Daten nicht wieder hergestellt werden. :(
Also nackte Stock Rom...
Also ich habe seit heute die Team Union Rom drauf. War aber von der RR Rom begeistert. Hatte die RR Rom mehrere Wochen drauf. Sehr gute Performance u sehr gute Akkulaufzeiten.
Kann die RR Rom nur empfehlen!!:thumbup:
hab da mal ne Frage. Bin zur Zeit auf der RR JB AOKP M1 (4.1.2). Würde nun gerne wieder die Orginale Stock Rom flashen. Kann ich die einfach via Odin drüber flashen oder besteht da Brick gefahr? Bei meinem N7000 wurde mir immer empfohlen zuerst auf GB zu flashen und dann erst die Stockrom. Nun bin ich etwas verwirrt
Danke für eure Hilfe...
gruß Markus
Auf GB?
Warum willst auf die Stock zurück?
Ich bin wieder auf ICS weil unter AOKP und JB beim N8010 der USB Massenanschluss nicht funktioniert. Also mit Adapter.
Ich use aber die ICS von Darkman. Da geht alles u sie läuft sehr smooth.
Hab die per fullwipe, format System, format Preload etc. Installiert.
https://www.android-hilfe.de/forum/...ooted-busybox-deodexed-05-09-2013.311801.html
nein ich wollte wieder auf die 4.1.1 orginal Stock Rom zurück flashen, da ich die S Note App doch stark vermisse ;)
Bei meinem GT-N7000 sollte man nur zuerst auf ein org. GB Stock Rom zurück flashen, da es zu problemen mit dem Kernel (Brickgefahr) kommen konnte.
Deswegen meine Frage. Wie ist die sicherste Vorgehensweise um von dieser Rom ([ROM][4.1.2]RR JB v3.1.1 AOKP Milestone1[N8000/8010]) wieder auf die Orginale 4.1.1 Stock Rom zu kommen.
Hoffe ihr könnt mir da weiter helfen...
Gruß Markus
Einfach Stock flashen.
Da der flash von 4.1.x auf 4.1.x erfolgt sind keine weitere Schritte notwendig.
Prof. Dr. Dr. Lorenzo von Matterhorn schrieb:
When I am getting sad, I stop being sad and be awesome instead. True story.
ist hier noch jemand zu Hause?
Ich habe dieses Rom gerade geflasht und möchte den Theme Chooser nutzen.
Er sagt mir aber bei allen angebotenen Themes: "Dieses Design wurde falsch zusammengestellt ... "
und verweigert den Gehorsam.
Ich kenne diese Meldung vom GNex her. Dort hilft aber der (zwiscenzeitliche) Rückgang auf das System Theme.
Hier hilft mir aber weder das System Theme noch erneutes Booten.
Was habe ich übersehen?
html6405
Jol
html6405
Grauer-Rabe
html6405
Guroff
Guroff
