WxK
Dauer-User
- 1.142
Kein support und updates. (Anschaffung eines neues Tablets)
Basiert auf dem aktuellen GT-N8000 und GT-N8010 Darkman deodexed Rom
BlueDark Theme von Schmalzstulle
Voraussetzungen:
- Samsung Galaxy Note 10.1(wer häts gedacht
- Root
- Philz Touch Recovery
- Tasse Kaffee/Tee
Tweaks@xda:
Performance:
* 4cyl Turbo v0.5.4 w/ 250 shot NOS | Entropy | zRAM Swap
Sämtliche ausprobiert und die am Besten funktionieren übernommen.
-Ergebniss? Super Fast und Butter Lätta weich![]()
Hardware&Software:
Code:
Network & Internet
[LIST]
[*]Wifi Scan interval in seconds
[*]TCP Congestion Algorithm selection
[*]Media streaming tweaks
[*]Use Google DNS servers
[*]Enable/Disable HSUPA
[*]Protect against SYN attacks by hardening your TCP stack
[*]Avoid Time-Wait state
[*]Block all redirects
[*]Block source-routing
[*]Various IPv4 tweaks
[/LIST]
Multitasking
[LIST]
[*]3 presets of OOM Groupings (lom/mid/high)
[*]3 presets of Minfree values (low/mid/high)
[*]2 presets of zRam compression (64mb/128mb)
[*]Adjust Dalvik VM to new OOM & Minfrees
[*]Adjust kernel to new OOM & Minfrees
[*]Renice low consumption processes to a softer value
[/LIST]
Dalvik VM
[LIST]
[*]VM Heap Size selection
[*]VM Heap Growth-limit selection
[*]VM Heap Start Size selection
[*]Optimization Flags selection, any combination of verification, optimization & register mapping
[*]Force dex optimization on /data only
[*]Enable/Disable Just in Time Compiler (JIT)
[*]Enable/Disable JNI Error Checking
[*]Enable/Disable bytecode verification for Dalvik
[/LIST]
Toggle Android Features
[LIST]
[*]Hardware Acceleration
[*]Force GPU rendering
[*]Surface Dithering
[*]Purgeable Assets
[*]16bit Transparency
[*]Kernel JNI Error Checking
[*]Android Logger
[*]Locking launcher in memory
[/LIST]
Telephony
[LIST]
[*]Call Ring Delay
[*]Proximity Sensor delay
[*]In-Call amount of volume steps
[*]SMS & MMS retry timer if failed sending
[*]SMS & MMS amount of retries if failed sending
[*]Enable/Disable AMR Wideband (a.k.a HD Voice)
[/LIST]
Touchscreen & Display
[LIST]
[*]Amount of fingers recognized by the screen (multitouch)
[*]Minimum amount of time between 2 touch events (Pointer Duration)
[*]Maximum amount of events per second WindowsManager can handle
[*]SurfaceFlinger's minimum velocity
[*]SurfaceFlinger's maximum velocity
[*]Enable/Disable FPS Capping
[/LIST]
Miscellaneous
[LIST]
[*]Optimize sqlite3 databases at each boot
[*]I/O Tweaks for ext4 file-systems
[*]Internal & External sdcard tweaks
[*]Zipalign all apks at each boot
[*]Various battery saving tweaks
[*]Various camera quality tweaks
[*]Raising jpg quality to 100%
[*]Enable quickpoweron
[/LIST]
Apps:
* MiExplorer BlueDark mit Rootzugriff
* Bauhaus Font mit Roboto getauscht
* Awesome Audio Beats
* Sony WALKMAN
* Sony Sketch
Installation:
- ROM herunterladen und auf interne/externe SD-Karte speichern
- Ins Recovery-Menü booten
- Ein Nandroid-Backup erstellen (empfohlen)
- Full-Wipe durchführen: wipe cache/ wipe dalvik cache / Factory-Reset und Format System (wenn Ihr von einen anderen Rom kommt) ansonsten Wipe Cache/Dalvik Cache
- ROM installieren (select ZIP from SD/ext.)
- Neu starten
- Einrichten
- Neustarten
- Genießen
Der erste Neustart:
Geht schnell eine Rauchen oder Kaffee trinken!
Screenshots:
Credits:
Darkman (Base Rom)
Schmalzstulle (Base Theme)
XDA (Skripte,tweaks,Apps...)
Darkman (Base Rom)
