[ROM][UNOFFICIAL][GT-I9205/9200][SLIMLP][CM-12.1][XENONHD][TEMASEK][5.1.1]
  • 2.205 Antworten
Which ROMS should I build / Welche ROMS soll ich bauen ?
  • TEMASEK CM12
    Stimmen: 22 64,7%
  • AICP
    Stimmen: 3 8,8%
  • DIRTY UNICORNS
    Stimmen: 12 35,3%
  • RESURRECTION REMIX
    Stimmen: 8 23,5%
  • LIQUIDSMOOTH
    Stimmen: 9 26,5%
  • SLIMKAT
    Stimmen: 6 17,6%
  • BEANSTALK
    Stimmen: 8 23,5%
  • VALIDUS
    Stimmen: 3 8,8%
  • Umfrageteilnehmer
    34
  • Umfrage geschlossen .
sileshn
sileshn
Stamm-User
2.076
Important
This is a German forum, THEREFORE are English-speaking members stopped bilingual posts in English and German (Google Translate) to submit to. These are the forum rules.
This is a German forum. English speaking users are requested to use Both
English & German Google translated in your replies. This is a must.
The thread creator or Android Help Assumes no liability, if any damage to your device Caused by this software.
Flashing at your own risk and danger.
Credits | Thanks
  • This Rome exist without the work of Arne Coucheron aka Arco not. A big thank you to him.
  • Thanks to Berlino for translation into German.
  • Team Slim & Team Tesla
Installation
  • Do you come from another Rome or the stock firmware is Necessarily a Fullwipe (wipe / system / data / cache / Dalvik cache) required.
  • Flashes ago to update on at Earlier AICP Rome, wipe / cache and / Dalvik cache is Sufficient.
  • You must have a current CWM / TWRP Recovery installed to flash the Rome successful.
  • Starts Mega in download mode (Volume Down + Power Button Simultaneously) and it connects via USB (if Previously enabled USB Debugging) to the computer. Opens Odin and adds the Previously downloaded file recovery with a PDA and flashes this. Since the recovery flash is very fast and restarts flash the Mega after, it is important Either to press immediately after the vibration from the MEGA volume + button and to keep or remove the check in the "Auto Reboot" in Odin before flashing and then starts manually in the new Recovery - is important That You firstboot into recovery after Flash .
  • In the Recovery Fullwipe run (wipe / system / data / cache and / Dalvik cache) and the AICP-Rom + The Gapps Flash -> Start After the system.
It is strongly recommended you create a backup did in the recovery of your current Nadroid Rome / firmware before you flasht this Rome - to hedge in case something goes wrong.
About fastcharge
For fastcharge voltage configuration use this through terminal or console or you can use FauxClock app.
Code:
To enable it use:
echo 1 > /sys/kernel/fast_charge/force_fast_charge
For USB 2.0 use 500mA as MAX
echo 500 > /sys/kernel/fast_charge/fast_charge_level
For USB 3.0 use 700mA or 900mA as MAX
echo 900 > /sys/kernel/fast_charge/fast_charge_level
For wallcharger use from 900mA, 1100mA, 1300mA to 1500mA as top
Warning: Incorrect use of voltage could damage your phone or USB ports
Downloads
The download folder has limited access Because of the link has been abused by some XDA members. If someone wants to access, please announce in a private message to e-mail address for activation. The Rome may not be uploaded to other file-sharing services and redistributed . It costs a lot of time and effort to compile a ROM.
ROMS / RECOVERIES : https://mega.co.nz/#F!U5lRkYiT!wx8ChbO5riQ8erbIc2UcTA
GAPPS : The Open GApps Project
Sources
My sources are here .
Donations
A donation is not an absolute requirement, but appreciated. You can Ensure® this use Link. Many Thanks.: Biggrin:
Reaktionen: Cris, phubarr, kangburra und 14 andere
Mine...
Reaktionen: phubarr, alexischino, AndyYan und 6 andere
Ich habe noch das LiquidPop drauf, werde aber mit Sicherheit auch das CM12 probieren...danke für die tollen Roms.:thumbup:
I'm still on LiquidPop, but will try CM12 soon for sure. Thanks a lot for the awesome roms.:thumbup:
Reaktionen: AndyYan, Koenigstiger, Don_Pedro und 3 andere
probably a stupid question but are you working on bringing back home button wake or is it a no go? either way it doesnt matter but would like to know :)
wahrscheinlich eine dumme Frage , aber arbeiten Sie wieder nach Hause zu bringen Taste Zuge oder es ist eine nicht gehen? entweder so, wie es spielt keine Rolle, aber würde gerne wissen :)
Reaktionen: Don_Pedro
Willkommen bei CM12 und mehr :)
Danke für Euren Job hier!!!
Reaktionen: Don_Pedro, Mr. Obsolet, Andbil und 2 andere
I am not that talented. If CM decides to bring it back, you'll have it..
Ich bin nicht so talentiert. Wenn CM beschließt, sie zurückzubringen , wirst du es haben ..
Reaktionen: phubarr, AndyYan, Don_Pedro und 4 andere
now there's a separate thread does that mean that you have an update schedule or is it just whenever there is an update/you have time to compile?
jetzt gibt es einen separaten Thread bedeutet das, dass Sie ein Update Zeitplan haben oder ist es nur , wenn es ein Update Zeit ihn zu kompilieren / oder?
Reaktionen: Mr. Obsolet
Hallo ,
Ich werde meine I9205 , das funktioniert nicht mehr zu bekommen , und ich werde dieses ROM versuchen . Ich bin sehr aufgeregt. Vielen Dank für diese Arbeit.
Reaktionen: Mr. Obsolet, sileshn, Wopema71 und eine weitere Person
Answer in the OP.
Die Antwort ist in der OP .
Reaktionen: phubarr, AndyYan, Mr. Obsolet und 3 andere
@sileshn Thanks very much for all your great work.
Do you have any plans (don't even know if it is possible) to bring back proper
mute option? This is the one that puts me off the Lollipop ... Can't understand what's the idea with getting rid of this?
@sileshn Vielen Dank für Ihre großartige Arbeit .
Haben Sie Pläne ( weiß nicht einmal, wenn es möglich ist ) , um eine ordnungsgemäße zurückbringen müssen
Stumm Optionen? Das ist die eine, die mich schiebt der Lollipop ... Kann nicht verstehen, was ist die Idee mit immer das beheben ?
Reaktionen: Andbil und Mr. Obsolet
What do you mean by mute option? Under quick settings?
CM12 is in its infancy. Its hardly been 20 days that they have been working on the code and still a lot more is left to do. The first release is expected only after 90 days of code release, probably by the end of December. Patience is key..
If you look at the number of months it took for us to get a proper working cm11 for our device, I would say that the development of lollipop has taken place very very fast. It is very usable as a daily driver and I have been on Liquidpop from the day I left xda.
I still remember the days when we used to struggle to get small things working on cm11.
____________________
Was meinst du mit Stummschaltung das? Unter Schnelleinstellungen ?
CM12 ist in den Kinderschuhen . Seine kaum war 20 Tage , die sie auf dem Code gearbeitet und noch viel mehr ist noch zu tun . Die erste Version wird erst nach 90 Tagen nach Veröffentlichung des Quellcodes wahrscheinlich Ende Dezember erwartet . Geduld ist der Schlüssel ..
Wenn man sich die Anzahl der Monate, für uns war , eine richtige Arbeits cm11 für unser Gerät suchen, würde ich sagen, dass die Entwicklung der Lutscher sehr, sehr schnell stattgefunden hat. Es ist sehr brauchbar als ein täglicher Fahrer , und ich habe auf Liquidpop vom Tag meiner Abreise xda gewesen .
Ich erinnere mich noch an die Tage , als wir zu kämpfen, um kleine Dinge arbeiten cm11 bekommen
Reaktionen: phubarr, Koenigstiger, blafasel und 4 andere
I mean proper Silence option, so we can still get a notifications but no sound :) I know you've implemented quick settings icons in power menu in latest build but it still doesn't mute the phone just enables NONE option (which kills even the alarm clock)
I know that it is early build and you're working hard that's why I've only asked a question if you think this would be even possible.
I'm patient, just curious :)
Ich meine richtige Stille Option , so dass wir noch ein Meldungen , aber keinen Ton :) Ich weiß, dass Sie Schnelleinstellungen Symbole der Macht Menü in neueste Build implementiert haben , aber es immer noch nicht das Telefon stumm schalten nur NONE Option ermöglicht zu bekommen (was auch tötet der Wecker )
Ich weiß, dass es frühen Builds und Sie arbeiten hart , deshalb habe ich nur eine Frage gestellt , wenn Sie denken, wäre dies auch möglich sein.
Ich bin geduldig , einfach nur neugierig :)
Ich erinnere mich noch an die Tage , als wir zu kämpfen, um kleine Dinge arbeiten cm11 bekommen .
Bookmark this link. You'll know what's going on...
Bookmark diese Link. Du wirst wissen, was los ...
Reaktionen: phubarr, Don_Pedro, Reddy und 2 andere
:ohmy: It seems like we will have to flash a lot in the next months. Happy flashing then.
:ohmy: Es sieht so aus dass wir so viel in die nächste Monate flashen müssen. Glücklich flashen dann.
Reaktionen: blubenow, 177020, Wopema71 und eine weitere Person
Der Touchscreen funktioniert nicht, oder habe ich irgendetwas falsch gemacht ?
@Coun96
Was hast du denn wie gemacht? Von welchem Rom oder Firmware kommend? Etwas mehr Informationen wären für eine Hilfestellung und evtl. Tips hilfreich...
What did you make and how did you make it? Coming from which rom or firmware? Some more information would be great for support and tips...
Reaktionen: Wopema71, Reddy und Mr. Obsolet
Ich hatte vorher die Cm 11 installiert, bei der auch alles super lief. Ich habe alle Punkte der Installationsanleitung oben befolgt, aber einen Fullwipe gemacht.
Kann das am Kernel liegen, das der Touchscreen nicht mehr funktioniert?
Ein Fullwipe muss sogar dringend beim Wechsel von CM11 zu CM12 gemacht werden. Mit welchem Recovery wurde denn das CM12-Rom installiert bzw. der Fullwipe ausgeführt?
Im Zweifelsfall mal auf ein anderes Recovery wechseln bzw. würde ich noch mal ganz sauber mit Fullwipe flashen.
A fullwipe is mandatory coming from CM11. Which recovery did you use to flash the CM12-rom/made the fullwipe?
Maybe you should try another recovery or flash once again with fullwipe...
Reaktionen: Koenigstiger, Mr. Obsolet und Reddy
Als Recovery hatte ich TWRP 2.7.0.5. genutzt.
