[ROM] GingerReal
  • 382 Antworten
Wickeda
Wickeda
Gugt mal ..... :smile: hatte die beta ROM schon drauf und wahr sehr zufrieden ......
Orginal: http://forum.xda-developers.com/showthread.php?t=1228436
To Moderator/admin
I know there are a lot of threads for this ROM sorry for that
I posted this thread as an official one, my request is to delete those others if any to prevent confusion
Hereby, I present you GingerReal. The fastest and most stable Gingerbread ROM around.
The development of this ROM, is 100% aimed on stability and speed, which we have proven. Current install base over 100.000 smartphones around the globe!
GingerReal for Samung Galaxy S | GingerReal for Samsung Galaxy Ace | GingerReal for Samsung Galaxy S2
Flash this ROM and you will never go to another
* Flashing knowledge is necessary to keep yourself out of trouble
* Read the installation procedure before posting any questions/issues!
* I am not responsible for your bricked or not working devices
* PLEASE BE PATIENT AND DO NOT ASK FOR ETA. UPDATES WILL COME WHEN THEY ARE READY!
* You may always leave feedback and post bugs
-Based on KPH (KPN is in the works)
-Jupa Engine R1.0.0 >> All information on how to use it here
-CF-Root B80
-CWM4 recovery
-Big APN list
-Hacked host file (no ads)
-Apps2sd
-Animation tweak
-Some build.prop tweaks
-GingerReal stuff (launcher + boot)
-Did some stability tweaking
-100% stock theme (some work from seilent can be found on sourceforge)
-Ext4 partitions by default
-A lot more
There are more ways to install this rom. Use the way you like it the most.
Remeber GingerReal devs don't have an ace we will provide a very simple installation guide
Notice: all data will be wiped
1. Flash stock KPH/KPN (GingerBread bootloaders is the most important)
2. Flash ClockWorkMod 4.0.0.9 recovery for ace
3. Download the latest release down here and put it on your SD-card
4. Boot into recovery mode
5. choose "install zip from sdcard"
6. choose "choose zip from sd"
7. choose the GingerReal-ACE-V.x.x-xxxx.zip and let it install
8. Reboot your device
9. wait till it is fully booted
Update you ROM
1. Download the latest release down here and put it on your SD-card
2. Boot into recovery mode
3. choose "install zip from sdcard"
4. choose "choose zip from sd"
5. choose the GingerReal-ACE-V.x.x-xxxx.zip and let it install
6. Reboot your device
7. wait till it is fully booted
All Ace downloads can be found on:
GingerReal Sourceforge
Download link: http://sourceforge.net/projects/gingerreal/files/Samsung Galaxy Ace/
Reaktionen: ace.the.galaxy, ChaosWare, LastRebel und eine weitere Person
schon ausprobiert? stabil? lade sie mir grade runter kann sich nur noch um stunden handeln^^
Hi jo hab sie schon drauf bin gerade dabei sie einzurichten ;-) hatte schon die beta drauf wobei die sich bis auf ein paar Bug fixes nicht groß von dieser unterscheidet.
probiere sie grad auch mal aus
postet mal eure eindrücke bitte! ich bin auf der suche nach nem custom-rum wo ich nicht die problem mit dem berühmten "SoD" habe... das geht mir nämlich mächtig auf die nerven... und die originale firmware auf dauer macht auch keinen spaß! ;-)
Läuft bisher ganz gut. Finde aber das Theme etwas altbacken und werde mir sobald eins draußen ist, dieses auch installieren. Gesamt Eindruck ist bisher ganz in Ordnung, obwohl ich meine das die flash rom einen tacken schneller und flüssiger ist
Reaktionen: LastRebel
kannst glaub ich generell jedes theme raufklatschen was für die kpn ist... hab meins auch draufgemacht. funzt bei mir einwandfrei
und kph themes gehen auch, hab mir noch das dark miui theme draufgeklatscht und es lief. Bin grad am testen der kpn version (1.1.0), läuft meiner meinung nach flüssiger als 1.0 .
Hehe cool und wie ist GingerReal so kann es leider erst am WE flashen da ich zur zeit nicht zuhause bin. Erzählt mal wie es läuft etc. bitte soll ja neben dem cyanogenmod eine der besten roms sein.
hat jemand zufällig den wecker von der KPN auf lager... fehlt bei der rom...
also die kpn version läuft seit heute morgen (habe direkt von der fla.sh rom geflashd), ist flüssig, schnell und bisher gute batterie zeit (genaueres wenn ich richtig zum testen der ausdauer komme). Persönlich rate ich zur kpn version, da sie schneller und flüssiger als die kph version ist.
hol dir doch nen wecker ausm market^^
näää, bei mir kommen keine apps rauf :D... naja extrahier ich mir den selber
also um mal ein eindruck zu posten....
mit dem akku bin ich jetzt 1 tag und 10 stunden ausgekommen, muss aber dazu sagen, das ich 3g nie anhab, datennetz nur wenn ichs brauche. ansonsten bischen w-lan... bischen bei whatsapp geschrieben, viele apps habe ich auch nicht drauf. telefonieren tu ich meist nur kurz!
habe auch ein paar systeminterneapps gelöscht, die im hintergrund ausgeführt werden. weiß nicht obs was bringt, aber hatte mal irgendwo was davon gelesen.
ja ansonsten kein SOD... habe wifi scan auch abgeschaltet! bei der rom, hackt und laggt gar nichts, ace startet sehr schnell am anfang, meiner meinung nach... alles in allem eine sehr gute rom. ich bleib dabei
Weis jemand was die kpo (gingerreal 1.2)version an änderungen hat? soll ja heute nacht hochgeladen werden.. sollte man davor die kpo version mit odin flashen?
Hmmm nacher mal nachlesen weis ich noch garnicht.
Gesendet von meinem GT-S5830 mit der Android-Hilfe.de-App
Nabend zusammen!
Ich habe mir die GingerReal 1.1.0 installiert.
Mir ist aufgefallen dass unter Tweaks die Einstellung "Kernel: Scheduler" nicht übernommen wird wenn man sie aktiviert. Nach dem Reboot ist der Haken wieder raus.
Kann das jemand bestätigen bzw weiß woran das liegt?!?
Mfg
Originally Posted by redmaner
Tonight I think V1.2 KPO
Sent from my GT-I9100 using Tapatalk
mal schauen ob er was hochlädt^^ und noch was neues :
I creating something new for the SGA will take some time but it's worth it
mal schauen was er zusammenköchelt^^
Mal ne frage geht bei euch ein screenshot? ich drücke die beiden tasten doch nix passiert, bei fla.sh gings noch.
shit nee bei mir gehts auch nicht ^^
LittleBitterCup
  • LittleBitterCup
LittleBitterCup
LittleBitterCup
  • Grabber66
Grabber66
Hatshipuh
neophyte1983
neophyte1983
