[ROM] BlockBuster Rom
  • 7 Antworten
aTg!s
aTg!s
Stamm-User
197
BlockBusterTeam present
BlockBuster Rom goes Ace v1.3
Is it this your waiting for? I don´t know - but here is it! Our BlockBusterRom soon for Galaxy Ace. Screenshots will follow.[/B. Visit our homepage www.team-blockbuster.com to gain more information. If you like our work press thanks and maybe donate something to support us.
BlockBusterRom - and living is easy
Features:
Of course it´s
  • - Based on a stock ROM KS9
  • - Full deodexed
  • - zipalaigned
Other Main Features are
  • - Root
  • - Ext4
  • - CWM 4
  • - Custom Sounds
  • - Custom Bootanimation
  • - Custom Screen Animations
Good Apps included
  • - Go Launcher
  • - TW Launcher
  • - HTC Like Launcher + Widgets
  • - Miui Musik
  • - Google Apps
    1. All Google Apps Updated to 2.3.5
    2. New Market 3.3.11
  • - Vlingo (Androids answer to Siri)
  • - QuickPic 3D Gallery
  • - Genie Widgets
In the first verison it has:
  • - Deodexed Apps
  • - Based on KS9
  • - zipaligned
  • - Custom Sounds
  • - Custom Theme (But not finished!)
  • - Speedfixes
  • - Allinonescript
  • - QuickPic as Gallery
  • - MIUI Music as music player
  • - All Google Apps updated to 2.3.5
  • - Updated Market
  • - Updated CSC
  • - TW-Launcher
  • - Go Launcher
  • - Faster GPS Tweak
  • - GenieWidget
  • - Titanium Backup
  • - Of course: Flashplayer
And is based on latest CF-Root. More features will follow...
I hope it´s correctly working for you - thanks for using it - maybe donate to support me - problems with it? Post here...
Downloads in second post
Also included ----------------------------------------------------------------------------------------------------------- Also Included
BlockBusterRom allinone init.d Script
This means: Better multitasking, better RAM manager, more free RAM, Battery Tweaks, Kernel Tweaks...
16 Apps running and still 100mb Ram left!!!
(Screenshots from Galaxy S. Don´t be irritated by the max. 339 Ram
Hier der Link:
[ROM] BlockBuster Rom goes Ace | Version 1.3 | Ready - Steady - Flash! - xda-developers
Hat sich jemand schon gewagt und diese CR ausprobiert?
das Script gibt more free RAM..?! Warum ist das nötig..das ist doch gar nicht notwendig.
Und warum werden Galaxy S Screenshots verwendet..die hätten es ja auch mal auf ein Ace spielen können :D
Und Flashplayer soll dabei sein? Naja..
Ich hab zweimal versucht dieses Rom zu flashen, leider ohne erfolg. Bin immer im Bootloop (auch nach Stunden) hängen geblieben, sodass mir nur das flashen via odin weitergeholfen hat. Hat es jemand von euch mal hinbekommen?
Hast du vor und nach dem flashen gewiped?
Aus diesem Grunde habe ich es gar nicht erst installiert - da waren wir bei xda zu viele mit Problemen,die die ROM geflasht haben. Zumindest war das im überfliegen des Threads mein Eindruck.
du musst das System mounten dann sollte es geht werde es später mal versuchen. ;-)
Ja, das habe ich gemacht. System mounten hab ich allerdings nicht probiert. Naja, war aber alles halb so schlimm, konnte ja problemlos zurückflashen. Bin nur auf der Suche nach einer Rom, die nicht soviel Akku zieht und trotzdem ein paar schöne Einstellungsmöglichkeiten hat, ähnlich wie CM7. Bisher leider ohne Erfolg.
Viele Grüße und falls jemand erfolgreich war, würde ich mich über Infos freuen, Raumluft
LittleBitterCup
  • LittleBitterCup
LittleBitterCup
LittleBitterCup
  • Grabber66
Grabber66
SG Ace Tom
