[OS][2.3.7] Port MiUI Life (multilang)
  • 10 Antworten
BRain_storming
14
Ich bin nicht der Entwickler die Rom ist von Gabreek ich wollte nur seine Arbeit bekannter machen!
Meines Erachtens ist dies bis jetzt die beste Miui Rom für unser Ace und sie ist sogar Deutsch!
Miui vereint Cyanogenmod und Design und bringt auf euer Ace ein Ganz neues Level der Eleganz!
Dies ist der Auszug von xda-developers
Quelle: xda-developers
gabreek schrieb:
Miui Life v5
First of all, sorry for my bad English :p
Hi guys, allow me to present my first rom for android, made ​​from a CM7 based, made ​​the port a MIUI 2.4.20, is very fast and stable and unlike all gb miui for galaxy ace is still in development and active support.
Date o relases (based on brazil time, gmt-3):
MIUI Life beta 1 (27.04.13) OUTDATED
MIUI Life v2 (09/05/2013) OUTDATED
MIUI Life v3 (14/05/2013) OUTDATED
MIUI Life v3.1 (15/05/2013) OUTDATED
MIUI Life v4 (17/05/2013) OUTDATED
MIUI Life v5 (07/06/2013
Code:
[V5] What does not work / Bugs:
- USB Tether native app use google play
- RadioFM is always on max vol
- rtl language thanks fot eljokar4ever for reporting on bug tracker (i'm fixing)
Code:
Changelog:
V1:
initial relase
V2:
- Multilanguage
- Fixed bug with GAPPS (google play services)
- Fixed random FC's and random reboots
- New theme (miui V5)
- Fixed bug with contacts
- Fixed bug with sms
- Adrenaline engine added
- New libs GPU adreno 200 (taken from P500)
- Build.prop edited for improvement 3d
- Increased battery life
- Quick and smooth like no other: B
V3:
- Fixed bug that caused the facebook messenger restart the phone
- Fixed bug with native Screenshot
- Fixed bug with permissions sms
- Fixed bug in restart when receiving sms
- Fixed bug permissions external application to receive sms
- Fixed some translations (pt-BR)
- Changes in framework
V3.1:
- Removed adrenaline engine
- Removed libs that caused instability
- Fixed bug with Bluetooth v3 appeared in
- Fixed bug with miuimusic that appeared in v3
- Fixed bug with downloads that appeared in v3
- Stable for daily use
V4:
- Some mods on framwork.jar
- 30 steps volume mod thanks to AndroidON
- smooth scrool thanks to AndroidON
- Disabelad CPU rendering full HW .. thanks to slaid480
- Check's RAM Management Script V4 thanks to GadgetCheck
- removed a loooot of unnecessary files (much less bugs,much more performance)
- added beats audio
- fixed bug with "can't mount" on the first time you try to mount link2df
- fixed bug with DND
- removed XIAOMI accounts (was buggy)
- Removed Miui backup (same)
- soft buttons light fix thanks to AceSamsung for the tip and to xxxMADxxx for the fix
- Added SpaceKernel thanks to SpaceCaker
V5:
- ringtone loop fix
- fixed custom ringtone (READ HOW-TO)
- updated russian translations
- included indian fonts
- fr and pt-pt sms reboot fix (tested and working)
- fc and reboot fix
- some modifications on theme
- New theme more v5 ui (+ 1500 icons)
- new bootanimation
- MIUIv5 lockscreen resized by me
- wifi tether app included
- much more i don't remember
Screenshots (v4): Here (v4)
Screenshots (v5): Here (v5)
Ok guys, the v5 is here ! MUCH more stable MUCH more fast, im testing about a week and EVERYTHING is working extremely fast, i tried but couldn't fix the RTL languages so I decided to relase without, but I'm going to work now only for fix this as fast as possible
Download:
v5: Download (Go to "Downloads" page !)
- How to install:
- Move to sd card
- Enter recovery
- Full wipe (factory, cache, dalvik)
- install zip from sdcard
- choose the rom and install
- restart the phone.
SOME USEFULl TIPS
- If you are having randons and non reported bugs, try to flash cm7 and after this one
- Select custom ringtone from MIUI Music app
- Hold home button on lockscreen to activate torch
- Double touch on lockscreen center to activate music lockscreen
- I recomend you to use FlyOnMod Script for muuuch more performance
- If you want the black status bar from SS download it HERE place on sdcard/miui/themes and in theme manager to to cust > status bar.
- the rom becomes more stable after a few reboots
Bugtracker: https://code.google.com/p/miui-life/issues/list (post here too !)
hope you enjoy aand press thanks !
Credits:
- For porting this rom i read soo many tutorials, so thanks to everyone (don't remember, was two months ago)
- SpaceCaker for the amazing SpaceKernel
- GadgetCheck for the ram script
- AndroidON for the 30 step volume tutorial
- slaid480 for the disable cpu rendering tutorial
- AceSamsung for the tip and to xxxMADxxx for the fix of the buttons light
Sorry if i forgot someone
PS: solltet ihr die Theme wechseln, ändert nicht den lockscreen, da dieser nicht an eure Bildschirmgröße angepasst wird...
Lösung : Milocker oder MiHome verwenden ...
oder angepasste mdpi themes für lockscreen verwenden :D
oh mannn, ich such mal ne themen sammlung, die in meiner blütezeit mit dem ace entstanden ist, wenn ich sie nicht gelöscht habe.. :D
in XDA gibt es paar threads, wo mdpi themes aufgelistet sind !
Der ursprüngliche Beitrag von 22:30 Uhr wurde um 22:37 Uhr ergänzt:
wollte nur mal sagen, dass mir aufgefallen ist, dass ich die besten fotos mit ner miui rom gemacht habe auf dem ace :D
EDIT:
flashing... .. . .. ... .. . .. ... .. .
jaja... der Tom hat ein frisches MIUI-Spielzeuch. Da werde ich mir das eben auch mal flashen ... (war auch schon in xda drüber gestolpert).
Aber nur, weil ich Abwechslung brauche... Im xda-Forum sind doch noch Schwächen herauszulesen. Der DEV ist Anfänger, glaub ich.
jup, läuft in meinen augen noch nicht so gut, finde da die rom von lagloose (htx miui oder die von nims, die rc3 besser!)
Hier meine alte MIUI Themes sammlung, der ordner gehört auf die sd karte (wohin ergibt sich dann schon..)
leider 900mb schwer, da ich sie nicht mehr angeschaut habe und etwas chaos in dem ordner ist :D
https://drive.google.com/folderview?id=0BzL2d4VLJjHTVmdHc0x0MXczdmM&usp=sharing
dabei ist auch ein backup eines themes, welches ich immer genutzt habe :D (unter theme/backup)
wer lust hat, kann ja mal downloaden :)
ich habe auch lange die miui von lagloose genutzt aber da ich auch gern instagram bin ich wieder weg... das ist die erste miui die ich getestet habe wo instagram geht ... :) für mich ein wichtiges kriterium :)
Fazit nach einem Tag ... läuft gut. Hatte aber mehrfach Reboots z.b. als ich meinen Whatsapp Account verifizieren wollte. Jetzt aber stabil.
GPS und Co. schaue ich mir gleich an. Vermutlich muss der Server richtig eingestellt werden...
EDIT: Position war ohne Veränderungen innerhalb einer Minute gefixt. Alles ok.
Das ROM bleibt auf jeden Fall bis Ende des Wochenendes drauf. Ich will MIUI nochmal eine Chance geben. :) Wobei mich schon jetzt diese ungewohnte Menüaufteilung nervt... Gewöhnungssache.
Miui auf ics wäre viel besser aber leider sind da tonnenweise an bugs: (
Dort ist alles einfacher und übersichtlicher
Ich schau mal nach der guten ics Rom und berichte dann: )
Gesendet von meinem LG-E975 mit der Android-Hilfe.de App
Ich hatte damals ICS MIUI drauf. Das hat meinen Akku gefressen wie nichts. Basierte damals auf Maclaws ICS.
Bei diesem ROM hier, by Gabreek, kriege ich TTS nicht ans Rennen. Oder noch nicht ...
edit: TTS nicht ans Laufen gebracht. Wenn jemand nen Tipp weiß, gerne her damit.
gab ein update ist jetzt noch schneller und stabiler und viele neue icons...
Ich habs immer noch drauf (schäm :)
Fred
was heißt hier schäm :DDD?
Ultralucker
  • Ultralucker
Ultralucker
Ultralucker
  • BRain_storming
email.filtering
Intega
I
