[OS][2.3.6, Samsung-based] StockLite
  • 102 Antworten
X
xmandeh
tj_droid schrieb:
IMPORTANT -
1) This is not Team Adreno Ace's ROM. This is my own ROM. Please post all bug reports and enquiries here, not on Team Adreno Ace's Facebook page.
2) All those developers who took my permission to use this ROM as a base ROM, please PM me again. I need to discuss something important. You are not allowed use this ROM as base until you PM me and take my permission.
Major Update (18/3/2012)- See changelog for more information
Here's a Stock light-weight ROM targeted at those users who love speed and stablity.
DOWNLOAD v6 - Make sure you backup all your data before flashing. After flashing, you'll lose all your data.
Download Record - 4576 downloads in just 4 days
Procedure -
1) Download this file and place it in your sd card.
2) Make sure you have ClockWorkMod recovery 5 (or any other recovery based on CWM5 such as PX Recovery) installed and your device is rooted. Download CWM 5 from here - [fully functional] CyanogenModRecovery 5.0.2.6 - xda-developers
3) Switch off your phone.
4) Boot into recovery mode by pressing home+power button simultaneously.
5) Wipe Data, Wipe Cache
6) Select 'install zip from sd card' and then select 'choose zip from sd card'
7) Navigate to the downloaded file and select it
8) Wait
9) Reboot
10) First boot will take a lot of time, around 5-7 mins or maybe more. Please be patient and do not think that your ace is bricked.
IMPORTANT - No need to flash stock ROM via ODIN to flash this ROM. You can flash this ROM directly. You wont face any problems even if you flash this on a custom ROM.
Features -
1) Based on latest stock DDKQ8 2.3.6 (India) - (you dont need to have an Indian baseband to flash this. You can flash this on any baseband. It will work like a charm)
2) Very fast and ultra-stable
3) Awesome battery life
4) Deodexed
5) CF-root b83 applied including overclock kernel (You can manually install CF-Root b84 if you wish. You wont face any problems)
6) DarkTremor apps2sd support
7) Screenshot functionality- take screenshots by pressing Home+Power button simultaneously.
8) Zip-aligned
9) BLN support - you need to buy BLN pro from market to access all functions
10) 60-65 MB free in system/app. That technically gives you more internal memory.
11) ROM's download size is just 89MB (approx.)
This ROM is meant for performance and speed. Its just stock ROM with nothing modded, I've removed useless apps to make the ROM faster. This ROM has got an extra adrenaline shot ;)
Following apps have been removed to provide more internal space or increase ROM's speed -
1) All useless widgets
2) Live wallpapers
3) Memo (you can install other better memo apps from market if you want)
4) Thinkfree Office
5) Swype (new and better versions available at beta.swype.com)
6) Samsung apps
7) Email app
8) Protips
9) Unified inbox aka social hub
Gmail, Google Maps, Google search , Voice Search and Youtube app have been removed to decrease ROM size. These apps can downloaded manually from market if needed.
Screenshots of supported Languages (Please dont send me PM's asking me which languages does it support, I am tired of answering such PM's)-
CHANGELOG (v6.0) -
1) Version 6.0 is twice as fast as Version 5.0
2) CRT Animation included. Go to settings -> display -> animations -> tick 'all animations' to enable CRT animation.
3) Fixed XT9 error in Samsung Keyboard
4) DarkTremor apps2sd fixed (Thanks to evilxdeadly)
5) Optimized Google Gears bootanimation for ace's resolution (Thanks to dali47)
6) Init.d support added
7) SlaidFastMOD included
8) Turboboost included
9) Adrenaline Boost v2 included
10) Hacked Hosts file to disable ads
11) Added modified MMS.apk - no MMS auto-convert (Thanks to P4qui7o)
12) Extended Power Menu added
13) Latest version of Google Play 3.5.15 (aka Android market) added
14) Battery life increased. Now battery life is even more than v5.0
CHANGELOG (v5.0) -
1) New base - Latest Indian Firmware - DDKQ8 with new Galaxy NOTE type lockscreen and new incoming call buttons
2) No frills CPU control app added to change CPU frequencies manually
3) DarkTremor Apps2SD included into the ROM.
4) Added back FMradio, Deskclock (aka Alarm clock), GenieWidget (aka News
and Weather app) due to user demand.
5) Stock Touchwiz added back. Wonokairoen's touchwiz removed. You can
install it manually if you like.
6) Transparent status bar replaced with original statusbar.
7) New bootanimation - Droid Razr bootanimation has now been replaced with
simple, sweet "Google Gears" bootanimation.
8) Google Play added (aka new android market 3.4.6)
9) Speed and Battery life has improved a lot. Cant find words to describe 'em. 9 - 11 hours of battery life while continously using wifi, 1.5 to 2 days of battery life on normal usage (tested).
10) Support for BLN control added.
11) ext4 manager app included to manage ext4 partitions.
Lockscreen :-
Call screen :-
Patches -
1) For HTC Beats enhanced audio (with xLoud), download beats-aceport.zip from attachments and flash via CWM.
For HTC Beats Modded Music Player download HTC-Beats-music.zip from attachments and flash via CWM.
2) For 14 toggles mod, download ace_14_toggles_stocklite.zip from attachments and flash via CWM.
3) There's a minor bug in the ROM which displays RIGHT to LEFT languages incorrectly. To fix this error, flash this file via CWM - RTL_patch_StockLite_v6.zip
Huge THANKS to dali47 for this patch :)
4) Lockscreen mod - If you dont like the looks of stock lockscreen, dali47 has edited the lockscreen and given it a appealing look. Download lockscreen mod - CenterLockscreenClock_StockLite_v6_all-lang.zip (Now supports all languages)
Thanks to dali47 for this mod.
5) For Pdroid patch, head on to toxina's thread - [Release ]PDroid Patch for CM 7.2 by vo-1 / Stocklite V6 - xda-developers
Notice to developers - You can use this ROM as a base ROM, but before using please PM me regarding this.
**Bug reports and suggestions are welcome.
PS - If you ask silly questions such as - "Does it have stock samsung keyboard?", then you'll probably never get a reply from me. Read the thread properly.
Credits -
1) Ketut for CF-root
2) dsiXDA for android kitchen
3) jinavs for Google Gears bootanimation
4) raiderx77 for video player
5) skynet28 for CRT animation Tutorial
6) djsky2011 for beats audio port for ace
7) evilxdeadly for DTapps2sd fix
8) dali47 for optimizing bootanimation for ace's resolution.
9) slaid480 for slaid fast mod
10) gadgetcheck for turboboost
11) imbawind for adrenaline boost
12) Google for android
13) Samsung for Galaxy Ace
14) ME for this ROM (LOl, JK) :p
Please dont just say thanks, press the 'THANKS' button :) :p
Sent from my GT-S5830 using Tapatalk.
Meiner meinung nach die beste ROM momentan, Stock - schnell - gute Batterierlaufzeit und PDroid!!! :cool2:
Reaktionen: Seelensammler66685, M4RWiN und dayan99
läuft gut, keine probleme hier bei mir. danke!
Hallo Leute.
Hab mir die Rom heute auch mal geflasht.Bin gespannt, wie sie läuft. Was mir auf den ersten Blick gleich gut gefallen hat, ist die Möglichkeit die Buttons in der Statusleiste zu verändern. Leider hat die Rom von Haus aus keine %-Anzeige des Akkus oben in der Leiste. Hab mit dem Kitchen eine gebacken bekommen,nur funktioniert.dann leider die variable Button Gestaltung in der Statusleiste nicht mehr. Gibt es einen Weg - und wenn ja wie - beides zu integrieren?
Danke im voraus
Gesendet von meinem GT-S5830 mit der Android-Hilfe.de App
nach einem tag test muss ich sagen, ich bin höchst zufrieden, hier läuft wirklich alles sehr rund und ich bleibe bis auf weiteres dabei. ein echter geheimtipp!
Bin auch gespannt.Ausschlaggebend wird für mich die Akkus-Laufzeit sein. Ergänzend zu meiner obigen Frage noch: Wollte den Taskmanager mit Titanium löschen und hab versehentlich erst "Programmüberwachung" gelöscht. Wofür ist das da bzw kann ich dadurch Probleme im Betrieb bekommen?
WOW!
Ich bin begeistert...
Diese ROM ist endlich mal was anständiges!
Im gegensatz zu anderen (GR, CW und andere) läuft diese ROM super stabil, ist schnell, es funktioniert ALLES!!! und sieht zudem noch verdammt gut aus durch kleine Anpassungen.
Beste ROM meiner Meinung nach!
Werd mir jetzt noch den veränderten Lockscreen patchen und bin dann rundum zufrieden! :)
*edit*
Und die Akkulaufzeit ist der WAHNSINN!!!
Sonst war mein Akku, nach nächtlichem aufladen, am Abend immer schon fast wieder leer.
Jetzt hält der Akku locker noch 'nen 2ten Tag! :D
Und das bei schätzungsweise gleicher Benutzung!
akkulaufzeit ist bei der SGS II rom auch verdammt gut
schlecht ist die rom nicht ;)
wenn jetzt noch die Batterieanzeige in % wäre, hätte ich nichts zu bemängeln!
*EDIT*
Hab mir das mal kurz selbst gebaut. Sieht ganz gut aus glaube ich.
*EDIT2*
Hab nochmal den screenshot angehängt. Weil mir die 1. Version nicht so gefallen hat, hab ich noch ne 2. Version gemacht.
@Extended: Frag mal aus Interesse.Wie nutzt du das Handy.Hab die Rom nämlich auch seit ein paar Tagen drauf und konnte keinerlei Verbesserung der Akkulaufzeit feststellen.Leider.
@Schirde.Hab mir auch mal Neue Akkuprozentanzeige gebacken und hat auch geklappt.Allerdings hätte ich dann nicht mehr diese gepatchte Statusanzeige (Quick Panel). Hast du die noch bzw. hast du sie.überhaupt dazu installiert und wenn ja wie.
Danke euch.Ansonsten bin ich im Übrigen bisher auch sehr zufrieden mit der Rom.Außer das der Bildschirm beim Scrollen im Telefonbuch arg hängt.
Grüße
die probleme mit den kontakten hatte ich auch, hab dann ex dialer installiert, das läuft sehr flüssig.
@ Xion1986: habs eben mal für dich ausprobiert. ich hatte mir ja %- Anzeige geflasht. Danach jetzt die ace_14_toggles_stocklite.zip .
es funktioniert. %- Anzeige ist da und die toolbar auch.
Reaktionen: Xion1986
das ruckeln liegt an der app ;)
@schirde: das bild konnte bei mir nicht angezeigt werden :)
Danke für den Hinweis.Dann versuche ich auch mal so rum.Hab es anders gemacht und war ganz unglücklich darüber, dass ich dann nur noch die normale Statusleiste hatte.;-)
Viele Grüße
So habe dem stocklite v6.0 noch ICS_theme_v1.2 hinzugefügt . Kleine änderung jetzt noch mit batterie prozentanzeige.
http://www.mediafire.com/?n72sa2n2hhmhm9s Nach install bitte Task Manager Öffnen und RAM Manager\Speicher leeren oder Speed Booster oder ein anders Tool um den RAM bereinigen.
Und für das schlechte GPS noch eine Verbesserung.
GPS besser ACE.rar Habe ich jetzt dem stock rom hinzugefügt.
normal über ClockWorkMod recovery 5 , install zip from sd card hinzufügen .
Meine Wallpaper: http://www.mediafire.com/?5rd7n2lchrchai1
Die Uhr mit Wetter und alle Skins dazu: http://www.mediafire.com/?c0sctc1v5l45ehl
Die Skins bitte unter SD\Android\data\fancywidgets kopieren aber es gehen nur 10 Skins (Uhr und Wetter). Also am rechner anschauen und dann die Euch gefählt kopieren.
A1u09Trw5CQuAAAAAElFTkSuQmCC
z8KERDe7nwpBwAAAABJRU5ErkJggg==
febh7HffjInsi3++ftLo77HYPpyN7+X8BOCMXcm+WXZ8AAAAASUVORK5CYII=
Bemerkungen erbeten !!!!!!!!!!
Reaktionen: satbora
Nabend,
super Rom soweit nur hab ich ein Problem.
Ich kann nur ca. die Hälfte meiner Apps auf die SD-Karte verschieben.
Die Facebook-App z.B. lässt sich ohne weiteres nicht verschieben bzw. Titanium Backup kann es verschieben aber danach ist die App verschwunden.
Kann mir einer helfen?
Vielen Dank!
Gruß Ron
Na mit Root Explorer in /system/app sind doch alle Deine apps gespeichert. Einfach mit Root Explorer den ganzen Ordner app auf die SD verschieben. So habe ich das gemacht.
Reaktionen: ronron428
okay die vorgehensweise war mir noch nicht bekannt aber macht schon sinn;-)
mit link2sd konnte ich auch alle apps verschieben ohne das sie verschwinden.
Gruß Ron
In der Stock rom ist ja im Verzeichnes der gleiche Ordner vorhanden dieser wird dann auf das Telefon kopiert und von dort installiert.
In diesem Ordner habe ich die Ice Theme eingefügt und die framework ausgetauscht.
Aber Du mußt Deine Programme genau so vorher einfügen weil das ja System Anwendungen sind und sich nicht im laufenden System Installieren lassen.
Also stock rom öffnen und in den app ordner Deine apps hinzufügen. Ich habe es geöffnet mit win rar. das fehlende programm reinziehen. fertig Und dann Testen
Karsten
@ jens _ wahle
geht der PDroid patsch von der ersten Seite auch mit deiner Version von der V6
d3nnis-gt
somebody
  • somebody
somebody
somebody
hoffi1712
frank_m
frank_m
