[ROM][BETA][5.1.1]Resurrection Remix-Lollipop v5.5.9-Onyx
  • 17 Antworten
Anti_
Anti_
Und nun die nächste Custom ROM, sie basiert auf CM, OmniROM & Slim!
Hier sei zu beachten das es atm noch die gleichen Bugs gibt wie bei der CM Version nur mit mehr features!
In naher Zukunft soll aber alles gefixt werden!
Navigation Bar
-Enable/Disable Navbar
-Navbar Ring Switch
-Navbar Ring Targets
-Navbar Button Customization
-Navbar Dimensions(Potrait & Landscape)
Statusbar
-Brightness Slider
-Enable/Disable Show Notification Count
-SuperUser Indicator Switch
-Carrier Label
-Carrier Label Switch
-Carrier label Colour
-Quick PullDown Switch
-Smart Pulldown Switch
-Clock Customizations
-Time & date
-Clock Colour
-Day & date Toogle
-Center Clock/Right Clock Choice
-Battery
-Battery Bar customization
-Battery Icon Customization
(circle/landscape/Potrait and more)
-Battery % Text
-Network Traffic Indicator
Theme Chooser
-Animations
-Toast Animations
-ListView Animations
-System Animations
App Circle Bar
-Choose apps in App circle
-Trigger Width
-Trigger Hieght
-Trigger Position
Recents Panel
-Clear All button Switch
-Clear All Tasks Switch
-Clear All Button Location
(Top right,Top Left,Top Center,Bottom Left,Bottom Right,Bottom Center)
Cclock Widget
-CLock And Alarm Customizations
-Weather Panel Customizations
-Calender Events
LockScreen
-Lockscreen Shortcuts
-Choose upto 5 Shortcuts
-100+ Icons for ShortcutsNotification Drawer
-Weather Display Switch
-Quick Settings
-Choice to Add 20+ Tiles
-Enable 2/3/4 Tiles per Row
-Enable Disable Birghtness Slider in Notification Panel
-Advanced Location Settings Switch
(Choose Battery saving/Device Only/High Accuracy Directly in Notification Panel)
-LongPress Toogles to Enter Settings
Buttons
-Backlight Timer
-Backlight Strength
-Navigation Bar left/Right handed mode Switch
-Power Menu
-Power Menu End Calls Switch
Home Button
-Home Button Wake Up
-Home Button answer call
-Long Press Actions
-Double Tap Actions
Back Buttons
-Wake Up device Switch
Menu Button
-Wake Up Device Switch
-Short Press Actions
-Long Press Actions
Search Button
-Wake Up Device
-Short Press Action
-Long Press Action
Volume Buttons
-Wake Up Device
-Playback Control
-Keyboard Cursor Control
-Swap Buttons on Landscape mode
Gestures
-Gestures Anywhere Feature
Perfomance Profiles
-LCD Density
-Expanded Desktop Mode
-All New CM Audio FX App
-Heads Up Customizations
-OverAll Smoothness Improvements
-Quick Unlock
-Optimizations to Improve Battery
-ALL cm12 Features
-AND MUCH MUCH MORE
Installation Instructions
- Download die letzte Build!
- Download Gapps
- Backup machen...
- Full wipe and factory reset (Ohne gehts nicht...)
- Flash ROM
- Flash Gapps
- Reboot.
- Enjoy!
Original Thread:
[ROM][5.1.1]Resurrection Remix-Lollipop v5.5.9-Onyx [15/12]
Downloads:
Resurrection-Remix-LP-v5.5.9-20151220-onyx.zip | by sud.vastav for X
Bearbeitet von: Klartext - Grund: Liste gespoilert.
Reaktionen: der_berliner und Janity
Guten Morgen,
konnte natürlich nicht warten und versuchte RR zu installieren doch der Installationsvorgang endete mit einer Fehlermeldung. Liegt wahrscheinlich daran das ich die Recovery von blu_spark r5 nahm. Mit dem Backup war das Wiederherstellen des Systems kein Problem. Im OP wird auf die Recovery von MasterAwesome hingewiesen. Vielleicht klappt es ja mit dem rc1. Also warten. :sad:
grüsse
Endlich geht es ja los :)
Warte aber erstmal mit dem Flashen bis was stabiles kommt.
Hatte vor dem O+X auf meinem GS2 über 1 Jahr lang die RR-Roms gehabt und die waren einfach nur klasse :)
Yeah, RR war auf meinen anderen Geräten immer meine liebste Custom ROM. Wär super wenn die schnell stabil wird.
Hey,
@Anti_ , würdest du den Rest im OP noch übersetzen und die Quelle verlinken? :)
(Die Featureliste habe ich mal gespoilert, die kann ruhig so bleiben)
Mache ich sobald eine neue Build da ist, die hier ist ja eh unbrauchbar da sie noch auf alten Cm Sourcen basiert ;)
Wobei du da aber auch die selben Bugs hast wie bei CM da meides auf der selben Sourcequelle basiert....
Hat die ROM eigentlich Ambient Display?
Kann es sein das hier die mobilen Daten noch nicht gehen? Dachte wäre gefixt.
Oh sorry gerade oben gelesen.
Guten Morgen,
neustes Update von Resurrection Remix vom 20.12. erschienen. Notification LED funktioniert nicht. Das selbige bezieht sich auch auf CM.
grüsse
Notification LED funzt sehr wohl bei CM ;)
Startpost aktuallisiert...
Guten Tag,
sorry, mein Fehler. Meinte damit nicht dass das Notifications LED in CM nicht funktioniert sondern das in RR die selben Fehler vorhanden sind wie z.Z. auch in CM. :rolleyes:
grüsse
UPDATE Das installieren von RR endete in einem Desaster. Erste Installation verlief soweit fehlerfrei doch beim Einrichten von RR gab es Probleme beim Wlan. Wollte immer überspringen doch RR wollte nicht. Bei der zweiten Installation gab es keine Probleme mit dem Wlan aber das zurückspielen der Daten aus der Recovery verursachte ständige reboots. Somit ist zunächst RR für mich gestorben. Vllt. wird es ja noch was.
ahoi
Guten Abend,
neuste Version vom 24.12. erhältlich.
ahoi
Was hat sich geändert?
Guten Abend,
Alles was sich auch in CM 12.1. geändert hat.
grüsse
Geht die led jetzt?
Hallo again,
wenn die LED in CM funktioniert wird die LED auch in RR funktionieren.
ahoi
Sunny
hatingdead
hatingdead
CerealKiller77
vonharold
vonharold
Al Falcone
  • Al Falcone
Al Falcone
Al Falcone
