Anti_
Die erste CustomROM auf CM Basis ist da!
Mittlerweile ist alles gefixt und es sind nurnoch kleinigkeiten die ein bisschen rumbuggen, aber dem Daily gebrauch nichts ausmachen:
What doesn't work
What works
Source code:
Device tree
Kernel
Vendor
Downloads:
ROM
Build 1.0s - STABLE
Build 2.0s - STABLE
Build 3.0s - STABLE (MIRROR)
Build 4.0s - STABLE
Build 5.0s - STABLE
Build 6.0s - STABLE | (MIRROR)
Build 7.0s - STABLE
Build 8.0s - STABLE
Build 9.0s - STABLE
Build 10.0s - STABLE
Recovery
CM-recovery.img
recovery-twrp.img
Installation:
What doesn't work
- In-call recording
- In-call Speaker Mic
What works
- Boot
- WiFi
- Hotspot
- Audio
- Camera
- RIL
- Bluetooth
- GPS
- Tri State keys
- Mobile data
- proximity sensor
- Gestures
Version 9 (01Jan)
Version 8 (31dec)
Version 7 (27dec)
Version 6 (24dec)
Version 5 (22dec)
Version 4 (19dec)
Version 3 (17dec)
Version 2 (16dec)
Version 1
- props: clean unnecessary radio props
- lights: notify even when charging
- wifi: remove "config_wifi_dual_band_support"
Version 8 (31dec)
- Echo solved
- Revert "audio: Remove unnecessary audio flags"
- Disable EAP-SIM support
Version 7 (27dec)
- Revert audio settings back to 3.0s
Version 6 (24dec)
- lights: Remove button backlight feature
- Enable OTG by default
- Fix vibration for capacitive buttons
- Remove button backlight
- Re-enabled ambient display(pick-up device to show notification works)
- Misc performance related tweaks.
Version 5 (22dec)
- FM Radio Added
- In-call volume now reduces
- Mic works on speakers (needs confirmation)
- GAPPS crash should now be resolved (need confirmation) {USE OPENGAPPS}
Version 4 (19dec)
- Fixed crash when calling on headphones.
Version 3 (17dec)
- Fixed battery charging lights
- Fixed ambient display
- Fixed keypad disabling and using softkeys.
Version 2 (16dec)
- Changelog
- GPS Fixed
- LEDs fixed
- Battery stats work
- OTG might work (need testers)
Version 1
- Initial release
Source code:
Device tree
Kernel
Vendor
Downloads:
ROM
Build 1.0s - STABLE
Build 2.0s - STABLE
Build 4.0s - STABLE
Build 5.0s - STABLE
Build 7.0s - STABLE
Build 8.0s - STABLE
Build 9.0s - STABLE
Recovery
CM-recovery.img
recovery-twrp.img
Installation:
- Sicherung erstellen mit TWRP
- Recovery aus dem Download per ADB/Fastboot flashen (Wichtig, sonst funktioniert die Installation nicht!)
- Clear data/factory reset
- Clear cache
- Flashen der ROM aus dem Downloadbererich oben!
- Flashen der GApps (Google benutzen...)
