Abbados
Stamm-User
- 494
Es wird alles gelöscht. Wird auf Werkseinstellung alles gesetzt. Musst also alles sichern.
If you are switching ROMs (changing from one ROM to a completely different one) then you should perform a factory reset. A factory reset wipes data and cache (which includes dalvik cache). A factory reset will also wipe sd-ext and android_secure if your device has those items. 99% of the time, this is all that you need to wipe and you only need to do it once, not three times as some people would lead you to believe.
