[ROM][5.1.1][SOKP][LVY48C-R8.0]-SONIC OPEN KANG PROJECT-
  • 4 Antworten
der_fahrer
der_fahrer
SONIC OPEN KANG PROJECT- A Premium Quality, ROM for the ONEPLUS ONE
Was ist SOKP?
Kurz und knapp: Eine Rom die eig. alles aus anderen Roms kann
und somit voller Anpassungen und Features ist!
Features:
  • Dolby Digital Plus​
  • Layers​
  • SlimPIE​
  • AppCircleBar​
  • Floating Windows​
  • Wakelock Blocker​
  • Live Display​
  • uvm.!​
Zitat:
STATUS BAR :
Clock & Date with custom definable location and styles along with selectable custom colors
Customizable Status bar Battery icon with percentage .
Status Bar Brightness control
Option to Enable & Disable Network Activity Arrows
Double Tap to sleep option on status bar
Status Bar Task Manager
Quick Settings :
26 user Selectable Quick Setting tiles including Ambient Display,Nav Bar ,Slim Actions, Live Display, Gesture Anywhere ,Battery Saver & App circle bar tile.
Switch to Disable & Enable Enlarge view of first row tiles.
Option to Set four Tiles In a row of quick Settings.
Switch to enable/disable vibration on tile touch.
Switch to enable/disable Brightness Slider.
Options to add max 3 actions in Slim Action tile.
Configurable QS Quick Pull down .
Configurable QS Smart Pull down.
Animation Controls:
IME Animations
Over Scrolling Effects
Toast Animations
List View Animations
AOKP System Animations
Option to Enable/Disable Scrolling Cache
Scrolling Modifiers.
Navigation Bar
Switch to Enable/Disable onscreen navigation bar
Navigation Bar buttons large number of buttons provided including Screenshot, power menu, custom application buttons etc.
Navigation bar dimensions
option to select menu location
Switch to enable/disable landscape view of navigation bar.
Hardware Buttons:
Switch to enable/disable hardware key buttons
Buttons back light option
Option to hide/show/auto detect overflow button
Customizable key actions including normal press,long-press, double-tap actions for back,home and menu key.
Power-Menu:
More them 10+ user configurable power menu options this includes bellow mentioned buttons
Screen Shot ,Screen recorder, Advanced reboot, Custom Application, users
PIE Control :
Switch to enable/disable pie control
Configurable various number of buttons including button style and button second layer
User configurable button styles with trigger option , custom color,transparency ,and size
Option to configure menu visibility in pie controls
Display Settings :
User configurable brightness settings along with adaptive brightness .
Display sleep settings from 15 sec to 30 min including 45 sec step.
Daydream
Expanded Desktop with per application configuration
LCD Density Settings
En chased font size slider
Auto Display rotation with all rotations angles including 180 degrees .
Screen Cast
Custom Display options like volume rocker wake ,wake on charger plugged/unplugged .Double tap to wake (supported devices only)
Ambient Display with Advanced Doze options including Doze pulse .
Live Display:
Live Display modes
Color temperature Settings
Switch to enhance colors
Color calibration including RGB sliders
Gesture Anywhere &vApp Circle Bar :
Switch to enable/disable Gesture anywhere & app circle-bar along with tile on QS
Option to set gesture location, trigger width ,height, position
Recents Panel :
Switch to select slim and stock recents panel
Custom background ,text color option in slim recents
option to show/hide topmost task in slim recents
Configurable recents applications size in slim recents
Sounds & Notifications
Interruptions
Enable/disable camera shutter sound
Enable/disable safe headset volume
swap volume buttons when screen is rotated
Volume steps
less frequent notification sounds can be configured from 3sec 5 mins
User configurable per application notifications
Notification lights with custom color options for missed cal ,voice mails etc [only supported devices ]
Battery light with custom color option [only supported devices] for battery low,charging, pulse if battery low, and fully charged lights
Heads Up Notifications with Snooze timer and time out options .
Security & Lockscreen :
Privacy Guard
Smart lock
Double tap to sleep anywhere on lock-screen
Show/hide advanced reboot
Hide quick settings on secured lock-screen
Lock Screen Shortcuts
Other Options :
Dolby Digital and Digital plus as standalone sound controllers.
Layers RRo 2.1 with orion to launch layer manger from Settings
Wake Lock Blocker
Screen Recorder with external audio , video-size, and bit rate options.
Custom application settings menu with privacy guard .Appops settings
Configurable media scanner behavior on boot.
Device partition info on Storage settings.
Option to hide super user indicator.
Disable FC notification
Kill apps back button with configurable time option
Option to show CPU info on Development settings
Custom colors for battery saver and trigger options
Advanced Keyboard options like auto rotation with time out,disable full screen keyboard ,volume key cursor control.
Still list continues .................................
For more updated And Detailed List of Features with images visit here
Installation:
Erste Installation (von anderer Rom kommend usw.):
  1. In Recovery-Modus booten​
  2. Data, System, Cache und Dalvik wipen​
  3. Neuste SOKP-ROM installieren (*ZIP)​
  4. Nochmal Cache und Dalvik wipen​
  5. System starten​
  6. Wieder zurück in den Recovery-Modus​
  7. GAPPS flashen (bspw. TK-Gapps)​
  8. Cache und Dalvik wipen​
  9. System starten​
Ihr habt eine ältere SOKP-Rom und wollt updaten:
  2. Neuste Version der SOKP-ROM flashen​
  3. Cache und Dalvik wipen​
  4. System starten​
Download:
Change-Log:
Verlinkungen:
Source&Credits:
Complete Source of SOKP including Device ,kernel , vendors which we use in our official Release builds.
We would like to thank Google AOSP ,Slim-ROMS ,CyanogenMod for their device trees, hardware repos , frameworks/Settings mods and their code that was incorporated into this project. We also extend our gratitude to the devs whose code that we have incorporated. Proper authorship has been maintained and can be viewed on our repository.
We would also like to credit
My Friends @thereassaad & @worstenbrood
Dolby Developers Team
Zeroinfinity(i love you you are my motivation....)
Koushik Data
aki_007
Rizal Lovigs
ibanez7
RockoDev
Acid
ImbaWind
Developers of HWAUIE ACSEND P6 k3v2oem1 Device
Developrs of Acer E1 Device
Sonic-Developers & Members...
Our Dynamic supporters & Beta-testing Team
If we still miss any one by-mistake Please don't start Thermo-Nuclear War or Ward War -3 in with me In thread Just Push a PM to me we will Add your Name to list if you deserve it ...
Click Here to visit the Detailed List of Credit that we maintain
Anmerkungen:
  • für die Ungeduldigen wie mich: beim ersten Flash kommt es vor,
    dass nach dem Bootlogo der Bildschirm schwarz bleibt! Hier einfach
    abwarten und Tee trinken! Ab 5 Minuten neu booten und neu Versuchen!
    Falls es dann nicht klappt ist was schief gelaufen!
  • TitaniumBackup kann den erstgenannten Punkt verursachen! Bei mir war es das Wiederherstellen der SMS-Datenbank, sowie der Kontakte!
  • Die Rom ist laut Entwickler seit R6.0 MultiRom fähig!(Selbst nicht getestet)
  • Bugs bitte im offiziellen Forum melden, ebenfalls gibt es dort einen Thread für Anfragen von neuen Funktionen
ROM OS Version: 5.1.x Lollipop
ROM Kernel: Linux 3.1.x
ROM Anforderungen: Root mit Unlocked Boot-loader & neuestemt Custom Recovery
Basiert auf: AOSP
Versioninformationen
Status: Stabil
Aktuelle stablie Version: SOKP-L-5.1.1-LVY48C
Veröffentlichungsdatum der stabilen Version: 23.07.2015
Falls euch die ROM gefällt unterstützt die Entwickler mit Spenden!
Weder ich noch Android-Hilfe.de haften für gebrickte Smartphones! Jedes flashen erfolgt auf eigene Gefahr!
Dies ist mein erster Rom-Thread, bitte verzeiht mir Fehler und macht mich darauf Aufmerksam!
Reaktionen: Pharao373, prototyp01, pill und eine weitere Person
Geht bei dieser Rom Xposed? Danke für die Vorstellung der Rom.
xposed zeigt bei mir leider Fehler an: zu neue SDK version(22) und findet eine library nicht.
ich gehe mal von aus das es nicht funktioniert, habe mich aber nicht explizit damit außeinandergesetzt, weil ich xposed momentan nicht benutze.
Sry :blushing:
Reaktionen: pill
Es wurde die Version R8.1 heute veröffentlicht!
Außerdem scheint Xposed (Version von romracer) doch zu funktionieren.
So da ich leider momentan keine Zeit habe und nicht geflasht habe, habe ich den Thread nicht aktuell gehalten: Somit wurde die R9.0 übersprungen(war nix wichtiges drin, außer deaktivierung von diesem anti piracy ding)...
Die neuste Version ist momentan die 10 (genannt MR1) die auch wieder etwas mehr mitbringt => siehe changelog
Sunny
Sunny
Sunny
-HUGO-
-HUGO-
-HUGO-
TomTim
TomTim
TomTim
