Dodge
Dauer-User
- 650
Resurrection Remix 5.8.0
- stable -
Basiert auf dem neuesten Google Android 7.1 & CM 14.1 Sources
OxygenCam verfügbar (credits @siankatabg [OxygenCam])
Neuester ElementarX Kernel
DASH Charge
ODEX Dateien für data apps hinzugefügt, firstboot beschleunigt
SuperSU eingebaut
OTA Updates
CM Theme Chooser
Beinhaltet alle CM13 Features
und viele weitere Änderungen unter der Haube:
Navigation Bar
-Enable/Disable Navbar
-Navbar Button Customization
-Navbar Slim Dim
-Animate Dim
-Dim Timeout Duration
-Dim Alpha
-Double Tap To sleep navbar
-Navigation Bar left/Right handed mode Switch for landscape
Statusbar
-Brightness Slider
-Enable/Disable Show Notification Count
-SuperUser Indicator Switch
-Double Tap To sleep Statusbar
-Carrier Label
-Carrier Label Switch
-Carrier label Colour
-Carrier Label Size
-Clock Customizations
-Time & date
-Clock Colour
-Day & date Toogle
-Center/Right/Left Clock Choice
-Date Format
-Clock Font Styles
-Battery
-Battery Bar customization
-Battery Icon Customization(circle/landscape/Potrait and more)
-Battery % Text
-Network Traffic Indicator
-Network Traffic Arrows Switch
-Incoming/OutGoing Traffic
-Network traffic Color
-Statusbar RR Logo
-RR logo Color
-StatusBar Weather
-Weather Color
-Weather Position(left/right)
-Weather Style
-Weather Size
Animations
-Toast Animations
-ListView Animations
-System Animations
Gestures
-Gestures Anywhere Feature
-3 Finger Swipe Screenshot Gesture
App Circle Bar
-Choose apps in AppSidebar
-Trigger Width
-Trigger Hieght
-Trigger Position
-App Sidebar
-Choose apps in App circle
-Trigger Width
-Trigger Hieght
-Trigger Position
-Pie
-Pie Trigger(left ,Right ,Bottom)
-Pie Targets
-Pie Colors
-More Pie Features
Recents Panel
-Clear All button Switch
-Clear All Tasks Switch
-Clear All Button Location(Top right,Top Left,Top Center,Bottom Left,Bottom Right,Bottom Center)
-Recents Search Bar
-Full Screen Recents
-Slim Recents
-OmniSwitch
Cclock Widget
-CLock And Alarm Customizations
-Weather Panel Customizations
-Calender Events
LockScreen
-Lockscreen Bottom Shortcuts
-Lockscreen General Shorcuts
-100+ Icons for Shortcuts
-Double Tap to Sleep Lockscreen
-Lockscreen Media Art/Enable Disable
-Quick PIN/Patter Unlock
-LockScreen Blur
-Lockscreen Blur Intensity
-LockScreen Wallpaper
-Lockscreen Weather Widget
-Lockscreen Icons Color
Quick Settings Draggable Tiles
-Customizable Tiles
-Show Two Main Tiles Per Row
-Dyanamic Tiles Adjustment
-Notification Drawer
-Weather Display Switch
-LongPress Toogles to Enter Settings
-Disable Immersive Mode Messages
-Force Expand Notification
-Task Manager Switch
-Time Contextual Header(HD,Modern,Poly)
-Quick PullDown Switch
Buttons
-Backlight Timer
-Backlight Strength
Advanced Reboot Menu
-Power Menu Customizations
-Power Off
-Reboot(Recovery, Bootloader, Hot Reboot)
-ScreenShot
-Power Menu End Calls Switch
-Restart SystemUI
-Airplane Mode
-ScreenRecord
-On the Go Mode
-Sound Panel
Home Button (For devices with HW keys Only)
-Home Button answer call
-Long Press Actions
-Double Tap Actions
Menu Button (For devices with HW keys Only)
-Short Press Actions
-Long Press Actions
Search Button (If Device Supports)
-Short Press Action
-Long Press Action
Volume Buttons
-Wake Up Device
-Playback Control
-Ringtone Volume Control
-Keyboard Cursor Control
-Swap Buttons on Landscape mode
-Volume Key Answer
Miscellaneous
-Selinux Switch (Switch Between Permissive and Enforcing Selinux if Device has Selinux Enabled)
-cLock Shortcut
-Disable Battery Saver Warning Color
-Disable Fc Notifications
-Wakelock Blocker
-Media Scanner On Boot Behaviour
-Cammera Shutter Sound Enable/Disable
SystemUI Tuner
-Enabled By default
-Removed Demo mode and Tweaked SystemUI Tuner As compared To AOSP
-StatusBar Icons Cuzomizations
-Quick Settings Customizations
Other Features
-Perfomance Profiles
-LCD Density
-Expanded Desktop Mode
-Audio FX
-Heads Up Switch
-Live Display
-Configurable 0,90,180,270 Degree Rotation
-Lock Screen Autorotate Switch
-Native Tap to Wake From Marshmallow
-Double Tap Power Button To enable Camera gesture
-Prevent Accidental Wakeup
-Wake Phone on Charging Plug
-Battery Light Customizations
-Notification Light Customizations
-Font Size
-CM privacy guard
-Performance Tweaks(Kernel Aduitor Inbuilt)
-Navbar Slim Dim
-Animate Dim
-Dim Alpha
Statusbar
-Brightness Slider
-Carrier Label
-Carrier Label Size
-Time & date
-Clock Colour
-Day & date Toogle
-Date Format
-Clock Font Styles
-Battery
-Battery % Text
-Statusbar RR Logo
-RR logo Color
-StatusBar Weather
-Weather Color
-Weather Style
-Weather Size
Animations
-Toast Animations
-System Animations
Gestures
App Circle Bar
-Trigger Width
-Trigger Hieght
-Trigger Position
-App Sidebar
-Trigger Width
-Trigger Hieght
-Trigger Position
-Pie
-Pie Targets
-Pie Colors
-More Pie Features
Recents Panel
-Recents Search Bar
-Slim Recents
-OmniSwitch
Cclock Widget
-Calender Events
LockScreen
-LockScreen Blur
-Customizable Tiles
Buttons
-Backlight Timer
-Backlight Strength
-Power Off
-ScreenShot
-Restart SystemUI
-Airplane Mode
-ScreenRecord
-On the Go Mode
-Sound Panel
-Long Press Actions
-Double Tap Actions
-Long Press Actions
-Short Press Action
-Long Press Action
Volume Buttons
-Wake Up Device
-Playback Control
-Volume Key Answer
Miscellaneous
-cLock Shortcut
-Wakelock Blocker
SystemUI Tuner
-Enabled By default
Other Features
-LCD Density
-Audio FX
-Heads Up Switch
-Live Display
-Font Size
-CM privacy guard
- Anleitung -
1. TWRP auf den neuesten Stand bringen (falls nicht geschehen)
2. Nandroid Backup nicht vergessen!
3. Empfohlen: Factory reset (data+system+cache)
4. Flashe Firmware & Modem
5. Flashe ROM
6. Flashe GApps (ARM64, 7.1)
7. Reboot!
- Downloads -
TWRP 3.0.2-1.28 (f2fs)
TWRP 3.0.2-1.25 (ext4)
Firmware & Modem OpenBeta9
Neuester ROM-Build
v5.8.0 vom 30.12.2016
Open GApps
OxygenCam
XDA-Developers - LINK
