[ROM] SuperOSR Nexus S by Superteam
  • 19 Antworten
OOmatrixOO
OOmatrixOO
Dauer-User
280
Die neue Version von Super@tmel und seinem Team. Mit neuen Namen. :thumbsup:
Original Thread, Screenshots & Download: SuperOSR Nexus S por Superteam Gingerbread 2.3.5 : Foro Nexus S : Foro Móvil Zona : Operadores, marcas y de móviles, aplicaciones, opiniones
This rom installs itself alone, that is totally reconfigured.
I recommend that you setup salteis account giving to omit google and once in the launcher now you can configure the rom to your liking. This is because the phone but the market is autologin and automatically begin downloading all the applications you had installed and it saturates the terminal because it does hit, plus it puts the background image that you had prior to the rom and then you ask me than it is possible that if I install the rom wipe me see the bottom it had before. Thus will you do a clean install. Then you enter the market and a free instalais anyone to cool that you have installed on the terminal.
Very attentive to you to do restorations of any kind or program against rom that you can have problems. (I mean backups, including their own SupSetup least in the section on applications), special attention to restoration of configuration data of any kind. Under certainly better not to.
New SupSetup V20 in all roms, not serve any previous SupSetup for this rom
The new integrated SupSetup activation brings on-demand applications in the applications section extras, you can enable applications that interest you and the rom is in "Lite" (without extra applications installed) for each to choose your best settings.
It is important before you set up Google account to be activated from the applications before SupSetup so that when you connect to the servers to configure your Google account, they enter the download.
After entering the market and to display applications install any application downloads for cool downloads.
General
- Rom in "LITE"
- New graphical look different from SuperGinger's
- All you had the source of SuperGinger but from non-Cyano Google
Added
- Wake & Unlock
- Bluetooth always visible from Settings (tolemaC)
- Hide clock
- Percentage of battery
- It's part of Cyanogen CyanogenModsettings
- Etc ...
Applications
- You can install more applications from SupSetup extras
- Google Apps
- Google +
- Go Keyboard
- Flash Player 10.3
http://cdn.movilzona.es/repos/superatmel/ROMS/SuperOSR/NexusS/SuperOSR-ST@-Nexus-S-1-AW.zip
Reaktionen: frajo und anime
ich hab mir die oben genannte Rom drauf und bin auch sehr zufrieden, hab sie echt liebgewonnen nur warum geht das Wifi nicht? Es lässt sich nicht aktivieren. Wie bekomme ich das zum laufen?
Danke für Antwort
Gruss
Hallo.
Also da kann ich nur spekulieren, da es bei mir ohne Probleme läuft und sich aktivieren sowie deaktivieren lässt. Hast du vorher nen full wipe gemacht? Alternativ könnte man auch nen anderen Kernel probieren.
MfG
Gesendet von meinem Google Nexus S mit der Android-Hilfe.de-App
Dann ists wirklich komisch. Fullwipe hab ich natürlich gemacht.
Was für einen Kernel würdest du denn empfehlen?
Fix permissions schon gemacht?
Ja auch die permission sind fixed.
Sent from my Nexus S using Tapatalk
Andere Kernel (zB den in meiner Sig) getestet? Vor dem flashen wipe cache und dalvik cache und danach nocheinmal fix permissions.
Den Matrix hab ich jetzt auch grad. Danke für die Tipps. Eine Frage hab ich noch: Was ist besser für die fixed permission etc, übers Clockwork Recovery oder über eine App wie zB. den Rom Manager?
Danke
Ergibt das selbe Resultat.
Version 2.0.2 ist online!
-> Download <-
Reaktionen: anime
Version 2.0.6 ist online!
Changelog -> von Google übersetzt... also nicht böse sein wenn etwas nicht korreckt übersetzt wurde:razz:
2.0.6 SuperOSR
Integrierte matr1x-Kernel, ich hatte einen Fehler in der vorherigen integralen Zusammenstellung
2.0.4 SuperOSR
- Shankar-Kernel (Kernel v6.5 Matr1x CFS) <------ wurde nicht ... :confused2:
- Graphic Retusche
- Behebung eines Fehlers in der Startup-sysinit2
- Mit Äußerlichkeiten der Codeaurora Zusammengestellt
-> Download <- :thumbup:
Gibt es noch eine support seite für dieses Rom ?
Noch eine? Zwei sind zumindest 2 Posts über dir verlinkt.
MfG
Hat schon jemand Erfahrungen mit der 2.0.6 gemacht und kann was zu Stabilität und Geschwindigkeit sagen?
Habe das ROM schon seit knapp einer Wiche drauf. Lief am anfang extrem flüssig wird mit der Zeit aber langsamer.. Außerdem hatte ich heute schon ein paar freeze und ein paar reboots.. mal schauen, vielleicht wechsel ich wieder...
Edith:
Um ehrlich zu sein, bin ich noch sehr unschlüssig. Grundsätzlich ist das ROM ja schon echt gut und wirklich extrem schnell.. Von der Akkudauer läuft das so ca. 1,5 bis 2 Tage. Was vergleichsweise zu unter den ROMS denk ich ganz ok ist muss dazu aber noch sagen, dass ich auch noch sehr viel rumgespielt habe (einstellungen), oft whatsapp und sms schreibe ab und zu Telefoniere.. Ich werde es einfach noch eine Woche testen und dann weitersehen..
Ich kann dazu nichts sagen, bin seit ner Weile mit Brainmasters Miui Rom unterwegs und sehr zufrieden.
MfG
Ich hatte da etwas mehr Probleme (Reboots, freezes), werde jetzt mal zu CM7 wechseln und ausprobieren..
Hectic
AdO089
AdO089
forb'S
forb'S
forb'S
dvux
dvux
dvux
