[ROM] SuperAosp from Super@tmel & tolemaC for Nexus S
  • 62 Antworten
OOmatrixOO
OOmatrixOO
Dauer-User
280
Hallo.
Bin nun auch zum Nexus S gewechselt und möchte euch dieses Rom vorstellen. Ich hatte vorher ein Magic und da gab es auch eine Version von diesem Rom.
Original Thread & Screenshots: SuperAosp from Super@tmel & tolemaC : Foro Nexus S : Foro Móvil Zona : Operadores, marcas y de móviles, aplicaciones, opiniones
XDA Thread: [ROM] SupeAosp 6.2 for Nexus S - xda-developers
Special thanks to the creator of the item inexus from which I have been inspired to give a graphic touch to the rom.
This rom (not a mod) has been developed entirely from the source of Google and very little of Cyanogen framework.
Thanks to Cyanogen and all his staff for the contributions received.
Is installed from the recovery, as always, do not worry if it takes a while to leave the first splash is entirely normal and configuration files running on first boot.
WARNING!
Only if you come from different roms (Donut, Eclair, Froyo) is necessary to WIPE, when coding in Gingerbread from this rom will not need to wipe again to install later roms.
This rom installs itself alone, that is completely reconfigures.
Before installing the rom Wipe recommend because it has many changes. When installed and out of recovery by restarting leave untouched while the LED flashes. At this point I recommend you salteis the account settings to skip giving google and once in the launcher and set podreis rom to your liking. This is because otherwise the phone will Autoconnect the market and begin to automatically download all the applications you had installed and it saturates the terminal because it does hit, besides putting the background image that you had prior to the rom and then you ask me that as it is possible that if I install the rom to wipe the bottom appears to me that I had before. In this way you will do a clean install. Then you enter the market and instalais a free application to refresh anyone that you have installed in the terminal.
Very attentive to you to do restorations of any kind against the rom or program that you can have problems. (I mean backups, including their own SupSetup least in the section on applications), special attention to restore configuration data of any kind. Under the best not to doubt.
SupSetup new V20 in all roms, not serve any previous SupSetup for this rom
The new integrated SupSetup activation brings on-demand applications in the applications section extras, you can enable applications that interest you as the Roma comes in "Lite" (without extra applications installed) so that everyone can choose the best configuration.
It is important before you set up Google account to be activated from applications before SupSetup so that when you connect to the servers to configure your Google account, they enter the downloads section.
After entering the market and to display applications install any application downloads for cool downloads.
General
- Rom in "LITE"
- New graphical look different from SuperGinger's
- All you had the SuperGinger but since source of non-Cyano Google
Added
- Wake & Unlock
- Always visible Bluetooth Settings (tolemaC)
- Hide clock
- Percentage of battery
- It's part of Cyanogen CyanogenModsettings
- Etc ...
Applications
- You can install more from the extra applications SupSetup
- Google Apps
- Flash Player 10.2
Download: Download
Changelog:
* 8.6 SuperAosp AW
- Select the permissions for default installations (anti trojan)
- New kernel with lower consumption of wifi and a better response.
- disabled widgets indicators in the top bar
- Edited the browser to enhance the existing lag
- New SupSetup with clean code
- 1 new topic
- New Wallpapers
- More translations in many apk's
* 8.2 SuperAosp AW
- Integrated with Google Talk video
- Launcher even more smooth and accurate
- New Kernel Mixture Rev3 Netarchy + very cute
- Published on sound control from start SupSetup
- All git.android and cyanogen unbeatable possible integrated
- AW = Anti wipe, if you wipe to stay the default applications and settings, it is not necessary to reinstall the rom again.
* SuperAosp 8.0
- Fully tailored to Android 2.3.4
- No problems with USB
- New Kernel Rev2
- Fixed problem explorer to create folders root
- New battery by Nelo
- New Wallpapers
- Etc. ..
* SuperAosp 6.4
- Recompiled the kernel to avoid the annoying restarts (UV mode now)
- more stable Kernel
- Removed for now the startup sound
- Editing some pictures of the framework
* SuperAosp 6.2
- Solution to the tables in texts
- Implemented operating in compact mode (default) is changed in the parts, interface
- New transitions and animations (only HDPI)
* SuperAosp 6.0
- Lots of changes in framework for stability
- Gallery now supports screen rotation without having activated
- Contacts and Phone allows landscape mode
- Added control adlx Romstats of people who use the roms in different version. completely transparent. You can see from here Rom Stats
- Reissue of how to address issues to avoid problems when applied
- Now the status bar can be put down as in the tablets. From integrated SupSetup Spare Parts
- Added Advanced Settings Widgets
- Improved wireless internet access in some routers polemic
- New kernel even more optimized
Reaktionen: anime, Jeanstraeger, weby und eine weitere Person
Wie verhält es sich bei dieser ROM mit den GPS-Problemen?
Naja hab das Nexus s erst ca 1 Woche. Weiß jetzt nicht ganz genau, was es da für Probleme geben soll / gibt. Aber als ich es ausprobiert hatte (zb GMaps) gabs keine Probleme.
Seit dem neuesten Update lange Wartezeiten bis ein Sat gefixt wird. Verbindungsabbruch bei der Navigation...
Hm so ausführlich hab ich GPS noch nicht getestet. Oder mal im XDA Thread nachsehen, da sind mehr Benutzer mit der Rom unterwegs.
MfG
Reaktionen: Antje
* SuperAosp 6.4
Neues Update:
* SuperAosp 8.0
- New Kernel Rev2
- New Wallpapers
- Etc. ..
also bei mir läuft es 1a und bleibt auch drauf!!! super arbeit - danke!
Neue Version:
*SuperAosp 8.2 AW
- Google Talk Video
- Kernel Netarchy+Supercurio = rock and stable kernel
- Implemented fixes git.android+cyanogenmod
- etc...
Hab es mal Just for Fun ausprobiert und es ist wirklich schnell. :thumbsup: Also bei mir bleibt es solange drauf bis es entweder CM 7.1 gibt oder ein neues Nexus S Stock-Rom :lol:
Jup, danke für den Hinweis.
Hier der komplette Changelog:
* 8.2 SuperAosp AW
Download wie immer im 1. Post.
Reaktionen: Opss
Hm, die Screenshots auf XDA und in dem spanischen Forum zeigen unterschiedliche Fonts: welcher ist im ROM tatsächlich drin? Ich mag den geänderten rundlichen nicht, der braucht zu viel Platz ...
also meines erachtens nach standart schriftschnitt!
also ich konnte keine veränderung der fonts feststellen nach einspielen des Roms!
Super Rom, läuft schnell und stabil.
Das Theme ist geschmackssache.
Bleibt auf jedenfall auf dem Nexus, bei Cm und NSCollab ist mein Gerät 3 mal am Tag nicht aufgewacht (Akku raus)
Hatte ich mit Dem SuperAOSP noch nicht
Ich muss einfach nochmal etwas zu diesem ROM schreiben nachdem ich es jetzt mal ein Weilchen im Dauertest hatte.
SuperAosp ist einfach das schnellste ROM dass ich bisher hatte.
Unter vollem Einsatz (surfen, simsen, telefonieren) hält der Akku knapp 2 Tage (sehr intensive Verwendung) was ich absolut spitze finde.
Außerdem ist es bei mir bis jetzt kein einziges mal abgestürzt (CM hat da öfters Bye Bye gesagt).
Also ich kann es einfach jedem weiter empfehlen.
Mfg
Sent from my Nexus S
geb da dawzon völlig recht. läuft völlig stabiel ohne reboots oder fc's! gprs kommt mir etwas langsamer vor aber sonnst top!
Neue Version:
SuperAosp 8.6 AW
- New kernel Netarchy + very cute with less use of wifi and a better response.
- 1 new theme
- New Wallpapers
- More translations in many apk'se
-->Download<--
Kurze Frage: An der Geschwindigkeit hat sich mit der neuesten SuperAOSP Version nichts geändert? Wäre wichtig für mich ;)
Danke und MFG
Tapatalked with my SuperNexuS
Läuft Top!
Zur Geschwindigkeit kann ich nichts genaues sagen... Geht aber wieder ab wie Schmitds Katze!^^
Kommt mir Persönlich nen Tick schneller vor.
Also lohnt sich der neue Kernel? Okay dann werde ich heute mal damit Experimentieren! :D (hoffe dass bei mir nicht der Sprach-Bug vorkommt und plötzlich ist alles auf spanisch).
Also ich habs jz seit gestern drauf und das Rom läuft 1A.
Kanns nur weiterempfehlen!
Top Rom für den Alltag!
Hectic
AdO089
AdO089
forb'S
forb'S
forb'S
InVade
puma95
puma95
