[ROM][PORT][XperiaS][ICS 4.0.3] NexusTimeScape| Fast, Bravia, Awesome
  • 3 Antworten
T-REX600
Gast
NexusTimeScape
[XperiaS][ICS 4.0.3] NexusTimeScape | Fast, Bravia, Awesome
DOWNLOADS:
[ROM]NexusTimeScape 1.0.3:
http://d-h.st/gQR
OLD
[ROM]NexusTimeScape 1.0.2:
http://d-h.st/pNP
Hi guys, today i am announcing a brand new ICS based ROM for the Nexus S.
The ROM is using the latest Sony Xperia Arc S Beta ICS 4.0.3 firmware and works very smooth! Everything feels very fluid and looks gorgeous.​
Screenshot time! =)​
As you can see on the screenshots above, the Xperia ROM looks and feels great. Here is a Features list of the ROM:​
Rom Features
-Xperia Arc ICS 4.0.3 beta 4.1.C.0.7
-CM9 kernel (linux 3.0.25)
- Sony Bravia Engine
-Removed software (CPU) rendering - full PowerVR SGX 540 (GPU) rendering
-Very fast, clean & stable!
-Multi-language (WWE)
-Fully optimized and tweaked
-ROOT (SU + SuperUser Permissions - Thanks to ChainsDD)
-Newest BusyBox
-RAM optimizations
-Speed optimizations
-Battery auto-calibration script
-All system applications updated to latest available
-Zipaligned (Improved RAM management)
-Zipalign on boot (for user applications on data partition)
-Fully de-odexed
-init.d scripts (BusyBox run-parts) support
-Signatures hack
-Excellent battery life!
-..and many more!​
Issues:
- Laggy video-playback.​
- Stock camera doesnt work, so I'll use the ICS camera for now​
Code:
[CENTER][SIZE=6][COLOR=deepskyblue]Changelog[/COLOR][/SIZE][/CENTER]
[CENTER][B]NexusTimeScape 1.0.3:[/B][/CENTER]
[CENTER]- Updated CM9 Vendor/libs + kernel[/CENTER]
[CENTER]- Added latest SuperUser[/CENTER]
[CENTER]- Removed the 3D camera (useless for us)
- Improved overall stability
- Added ROM Manager support
[B]NexusTimeScape 1.0.2:[/B]
- Updated frameworks
- Updated apps
[B]NexusTimeScape 1.0.1[/B][B]:[/B]
- Started from scratch
- Updated all libs for Nexus S
- Build.prop mods
- Init.d mods
[B]NexusTimeScape 1.0:[/B][/CENTER]
[CENTER]- Initial build [/CENTER]
Naja ein Xperia-Port hätte gereicht :D Probiere die Version später!
Ich habe mir die ROM mal geflasht, scheint bisher alles ganz gut zu laufen :)
Nur eins währe noch ein nettes Feature, auf dem Homescreen den Balken einfach runter ziehen und oben rein die Wifi,GPS usw aktivierung rein zu machen....ich weiß es ist eigentlich eine Portierung, aber immerhin noch eine Custom ROM und somit kann man ein paar kleinigkeiten ja auch mal verbessern
forb'S
forb'S
forb'S
wiesi_at
richyg
Psygen
Adinoid
Adinoid
