[ROM]Nexus xperia 1.0.1 / ICS 4.0.3
  • 36 Antworten
Psygen
Psygen
Nexus xperia 1.0.3
And we are good to go..
After the succesfull port of the Xperia X8 rom to my old LG P500 http://forum.xda-developers.com/show....php?t=1293100
I thought it was time to continue the project and i am proud to introduce NEXUS XPERIA S
This is the port of the original beta XPERIA ICS ROM.
DOWNLOAD
How to Flash:
Download the zip file ( 200 mb)
Put it in your Sdcard
Download Dalvikwiper : dalvik-wiper.zip
Place it also in you card
Reboot into recovery
wipe data
wipe cache
Install zip from card
choose dalvicwiper.
Choose zip from SD card
Install the rom
Reboot.
To get ROOT access:
1.Flash the superuser fix via recovery. Superuser-3.0.7-efghi-signed.zip
Changelog UPDATE 28/04/2012
Original ICS sony Now ( Not beta)
XPERIA S Settings
Xperia S phone ui
Xperia S contacts
Xperia Gallery
Apex launcher + xperia launcher
Imported some 4.0.4 libs
Xperia S MMS
Plus additional stuff i dont remember.
Changelog UPDATE 30/03/2012
Fixed misplaced launcher icons
Fix market bug
New System UI
New Semc Music
Ability to change songs from lockscreen
Inserted 4.0.4 libs
Dolby-Sound booster
Timscape removed-added Xperia events
Several widgets
Updated apn
New semcphone
Changelog UPDATE 24/03/2012
FULL WIPE IS RECOMENDED
Fixed:
Touchscreen
Wifi
Camera ( original ics camera for the moment)
market
root
To get ROOT access:
2. Go to the market and download busybox by Stephen Sterricson and then select any version of busybox and install it. NOW YOU HAVE ROOT
Changelog UPDATE 23/03/2012
Huge progress during this time.Now XPERIA S framework.
ALPHA RELEASE
Radio fixed
Data fixed
Wifi working
Bluetooth Working
Lights working
Gallery working
USB & Storage working
Music works
Screenshot working
Internet works.
Orientation, xloud, ringers,timescape, track id and etc xperia stuff works.
Whats is not working:
Camera
and touch screen
Es gab schon eine Weiterentwicklung in der Zeit
Is Working
Radio fixed
Data fixed
Wifi working
Bluetooth Working
Lights working
Gallery working
Music works
Internet works.
Camera
Screenshots
and touch screen.
Reaktionen: Psygen
Für mich deckte sich das fast :D
Updatet Download Link - Have Fun :)
Sobald der Bug mit dem Display-Ding behoben ist würde ich´s auch ausprobieren im Alltag. So muss ich mich noch gedulden :)
Ich ziehs mir gerade herunter und werde das mal ausprobieren ^^
Erster Eindruck: Sieht cool aus, hatte noch nie einen Sony Android und alles ungewohnt auf aufregend. Das switchen zwischen den Homescreen läuft absolut flüssig! 400MB RAM verfügbar ist auch ok ...
Hin und wieder dauert ein Touch auf eine Option ein wenig aber das kann in einer Alpha verziehen werden.
Das Wetter Widget finde ich sehr Geschmackvoll und hübsch.
Tolle Arbeit des DEV! :thumbsup:
Bug: FC wenn man ein APP aus dem Store laden will!
Wäre cool, wenn du den Startpost aktuell halten würdest :) Dann könnte man den Fortschritt mitlesen :D
Ich werde es versuchen, das ROM ist schon sehr lebendig. Ich warte jetzt mal das nächste Update ab ob dann der Market funktioniert!
Market funktioniert bei mir mit der Rom !!! Läuft übrigens gut das teil:D:D
Was hast du gemacht Rex?? Bist wohl der einzige :D Es wird allerdings am Fix gearbeitet! ... Ja es läuft schon sehr gut und mal was ganz was neues
Kann doch auch nichts dafür läuft aber bei mir :D:D . Bekomme nur im Dateisystem keine root rechte, kann in der blöden Build.prob nicht LCD Sentive von 230 auf 240 ändern! das im Market alle apps kompatibel werden. Muss ich es halt in der zip von der Rom ändern und neu flashen :crying::D
Die hier Superuser-3.0.7_mod-signed.zip flashen, damit hat man wieder root rechte :D:D:D
Edit: Und man kann bei NStools den Governor einstellen, ging vorher auch nicht!
Und löscht //system/lib/egl/libGLES_android.so !! Wie immer halt !!!:D
Heute gehts fix mit dem Rom, der fullrelease wird eben hochgeladen ..
forb'S
forb'S
forb'S
Berlin88boy
brainmaster
richyg
