[ROM] MIUI v4 (MIUI-Germany)
  • 296 Antworten
Müllstein
Müllstein
Weil der alte Thread des "Standard"-MIUI v4 ziemlich verkommen ist :lol: mach ich einen neuen auf den ich stets aktuell halten werde.
Changelog of MIUI 2.6.8 (MIUI V4)
[System]
Optimisation - when adjusting the clock minute selection, the clock does not automatically add / subtract
I9100 update to base version ZSLPG
LT18I update to base version 4.1.B.0.431
Honor update to base version B919
Optimisation of the application task management, total available memory and actual physical memory. In addition showing memory occupied by hardware resources.
Fix problem with return key to exit applications does not clean up application from memory even after exiting application using the return key
Fix black screen after call, the volume keys and camera button can wake up the screen
[Phone]
New call, new call reminder supports notification tone, can also be set up with prompts e.g. (Times to be reminded, vibrate on first alert) etc.
Fix problem using Application control (protection) to limit access to dialer and contacts
Fix in some cases the answer call panel disappears
Fix set ringtone for no delay, call still has sound problems
[Contact]
New contact details page, click on the picture to view the ID
New - Contact details page for Birthday information automatically goes to Calendar when pressed on
Optimise selection, editing, large contact picture; generate small icon in dashed box
New contacts Lunar birthday corresponds to the next calendar Date of birth
[Messaging]
New birthday greetings feature, send special birthday message items to friends / family
Optimisation support to search contacts in Messages
Fix (CDMA) cannot prefix number with the "+" number to send a message
[Lock screen, Status bar, Notification bar]
Add Variety lock screen to support the cut-off screen buffer as a picture source (which can unlock effect blinds, folding, etc.)
Add Variety lock screen support using screenshots as a picture source
New Variety lock screen support query web service, and through the use of XPATH to retrieve different parameters
Added support for 3D rotation
[Themes]
Optimised browsing ringtones, previews and download to give a better user experience
Fix new icons in some cases local thumbnails
Fix problems with incorrect theme package size
Fix various FC issues
Fix click the first item in the list view, the title bar will show problems
Fix Desktop theme module cannot be used
Fix problem with backup of font from theme, when restored leads to some garbled issues
[Camera] [MI-ONE]
New video support click on the screen to focus
Optimise the photo compression parameters, default compression has been modified to improve quality (Default Picture size can be changed in settings)
Fix taking photos at 5 megapixels, the photos the edge shows a green and sometimes varied colour line
Optimise video recording now allows a maximum recording of 2 hours continuously
Added support for 16:9 ratio full-screen camera format (See Settings to modify sizes)
[Gallery]
For optimal viewing pictures, slide up and down the picture from side to side
Repair using a picture covering the same picture and thumbnails and real Figure
Fix some unusual colour problems after finishing playing video and returning to the viewfinder interface
[Music]
Added new version of Music player app
[Backup]
Optimise lack of SD card space backup reminders
Repair bulk backup or restore for contacts and MMS causes FC
[Settings]
New functions for stopping current program (press return key) with a longer response time
Add support for majority of original factory settings
[File Manager]
Optimise load efficiency when entering the file search
[Calendar]
New month view and list view, now able to add the Lunar New Year
Optimisation to update the calendar reminder text descriptions
Optimisation to merge multiple calendar birthday entries
Fix problem due to Daylight savings time leads to the Lunar calendar date being incorrect
Download 2.6.8
Tweaks von Brainmaster die das ganze noch um vielfaches verbessern
Reaktionen: matt0086, Manuel Sajed, Adinoid und eine weitere Person
nabend,
Ich habe es im changelog nicht wirklich gefunden. Kann jemand sagen ob das Problem mit der Rufnummernanzeige und Kontake gefixed worden ist ? danke und gruß flummi
Ich bin ziemlich angewiesen auf Tracks mit den Volume Tasten skippen. Besteht diese Möglichkeit bei Miui v4?
flummi schrieb:
nabend,
Hab ich keine Probleme mit, funzt ohne Probleme. Hab aber alles mit + 49 in den Google Kontakten angelegt.
Gesendet von meinem Nexus S MIUI V4
Funktioniert bei mir mit Brainmasters Miui Rom auch ohne +49. Schätze mal, wird dann hier auch so sein.
MfG
Hallo, ich habe mal eine Frage, hatte mir die MIUI auf mein Nexus s geflasht, gibt es dort aber eine möglichkeit den Homescreen, Anrufe etc. in Querformat zu bekommen oder müsste ich alternative launcer verwenden?? (Drehen ist aktiviert laut Einstellungen)
Vielen Dank im Vorraus!
miui launcher ist immer im hochformat, war ja am anfang ne kleine iphone copy. aber was meinst mit anrufe im querformat annehmen?? stelle ich mir komisch vor das telefon quer ans ohr zu halten??
Naja ich verwende halt eine KFZ Halterung im Querformat...und wenn alles nur im Hochformat ist ist die Rom für mich unbrauchbar...aber danke für sie Info..
Dann nutze einen alternativen Launcher ;-)
MfG
MfG
Dann macht MIUI allerding nicht wirklich viel Sinn..m.M.n :D
ja und nein, miui hat viel mehr zu bieten als den launcher.
bloß wenn ich einen alternativen Launcher verwenden soll, kann ich auch gleich bei meiner CM 9 bleiben^^
Aber kann mir das ja mal vlt mit der Zeit anschauen, welchen Launcher bevorzugt ihr denn?
Apex
Hallo Zusammen,
Also getestet , neue Version drauf, alles clean vorher, Kontakte alle ok, aber bei anruf erscheint immer nur die Telefonnummer, bei Google ist alles mit +49 eingetragen... deshalb fliegt MIUI wieder runter..
gruß
Flummi
Wieso das? Würdest du nur wegen dem Launcher MIUI nutzen? Ich sicher nicht. Für mich gibt's da andere Vorzüge.
Ja klar aber der Launcher gehört einfach der Optik zu Liebe mit dazu finde ich.
flummi schrieb:
Hallo Zusammen,
gruß
Flummi
Genau das selbe Problem hier.
Schade eigentlich... finde die Rom schon toll
Der Bug ist mit Android 4.0.4 beseitigt worden soviel ich weiß. Dementsprechend wird es auch in der nächsten MIUI auf Android Basis 4.0.4 nicht mehr vorkommen.
MIUI 2.4.6 ist auf Offizielle Versionen « MIUI GERMANY | MIUI verfügbar.
ChangeLog siehe miui-germany, ist schon 4.0.4 ics
das hier ist inkl rob2seven`s theme, der es versucht hinzubekommen, ein theme für miui v4
http://miui-germany.de/forum2/index.php?page=Thread&threadID=4529
klasse arbeit von ihm,
Q
quasimodo
Q
forb'S
forb'S
forb'S
Q
flying fox
