Adinoid
Enthusiast
- 1.104
Wow, der vollständige Changelog der neuen Version sieht auch nicht schlecht aus
Adinoid schrieb:Wow, der vollständige Changelog der neuen Version sieht auch nicht schlecht aus![]()
[System]
Added when manually installing an application the system will automaticall scan the app for viruses and security issues
New text editor function, press and hold on text to get magnifying glass
Optimisation to expand the m-key response range
Optimisation of the switch controls to replace the ideographic check controls
Fix panel (lower right corner) of current task list in "Task Manager" icon to click on a smaller area
Fix problem during call, cannot recognise some headphones when they are pulled out
Fix Exchange FC issues
[Phone]
Added support to make two short numbers
Optimisation of T9 to improve the search, synchronisation, update and import efficiency of contacts and reduce space and memory usage
Optimisation of number attribution input logic
Fix issues with SIP accounts causing FC
Fix in some cases the underlying state error leads to FC error in Phone
Fix in some cases sorting errors
Fix the number of contacts update error
Fix names which contain special characters (figures) cannot be directly searched for
Fix part of the multi-tone word problem of low-frequency sound
Fix in some cases the search will display repeated results
Fix cannot display SIP/Internet phone numbers
Fix in some cases strange numbers will be identified as contact problem
Fix problems where two SIP phone accounts causes FC if one is not set to main number
Fix FC error when invalid SIM is detected and attempting to set PIN lock code
Fix in some cases ringtone errors
[Contacts]
Optimise the location and style of the contact details / avatar popup panel
Fix problem when setting large contact photo avatars leads to FC
Added new support (including Gregorian and Lunar calendars) to add birthday reminders
[Alarm Clock]
Optimise the alarm interface resources package is deleted will cause the alarm to FC
[Messaging]
Fix problem with messages, forwarding and copying details will not automatically exit the edit mode
Fix issues being usable to set SMS notification tones
[Lock screen, Status bar and notifications]
Added support for facial unlock (FaceLock)
Added support to hide screenshot notifications (See Settings for details on disabling screenshot notifications on the status bar area)
Optimisation of clicking on the notification bar switch toggles
Fix lockscreen password protection, when screen automatically switches off and you wake the phone the lockscreen does not return to the initial state it was left in previously
Fix notification bar download progress bar background error
[Desktop]
Optimisation of folder opening speed
[Themes]
Migration of V4 themes to new server
New support for themes to hide status bar lock screen icons
Optimise preview display effects for different devices
[Camera]
Add picture captured effects
Added two-finger pinch gesture zoom
Fix during focusing process, cannot exit the camera to view thumbnail previews
[Gallery]
Fix FC issue for list of albums when pulling down list
Fix problems setting desktop and lock screen wallpapers when using third-party tools (unable to crop)
Viewing album picture optimised, significantly enhance the loading speed (up to 5 times more. First time app loads the cache will be rebuilt)
Fix part of the image size is displayed as a problem
Fix slideshow function causes FC error
[Music]
Fix when pausing music via the status bar controller, the controller in some cases disappears
[Settings]
Optimisation of pattern lock UI (increase pattern drawing accuracy)
Optimise hardware keys light for 5 seconds then automatically turn off
[Download Manager]
Fix problem where files cannot be downloaded over 3GWAP/ CN WAP
[Browser]
Optimisation of new night mode interface, 50% reduction in power consumption
[Access Control]
Fix problem when access restriction is enabled the password can be bypassed in some cases
[LED lights]
Fix problem setting LED light colours do not take effect
Adinoid schrieb:Wie ist die neue Version so? Ich denke bei der nächsten wechsel ich wieder mal![]()
flying fox schrieb:Habe MIUI seit langem wieder einmal laufen - habe kaum einen Vergleich zu den älteren Versionen, aber das letzte update finde ich gar nicht einmal schlecht. Der Launcher wirkt immer noch etwas laggy, meine apps laufen aber soweit flüssig. Vielleicht bleibe ich mal ein bisschen bei MIUI, features wie die integrierte Zugriffsverwaltung (zB Lokalisationsrechte von apps verweigern...) gefallen mir recht gut.
Sagt, welchen custom-Kernel kann man denn dazu flashen? Matr1x, Air etc führen bei mir zu bootloops.
amo66 schrieb:Hast du ihn sauber installiert ?
Ich meine:- Cache-Wipe
- Dalvik-Wipe
-Kernel flashen
-fix permissions
Gesendet von meinem Nexus S mit der Android-Hilfe.de App
OOmatrixOO schrieb:Hab zur Zeit den Air Kernel drauf. Ist Stock bei Oodies Miui Rom. Zuvor lief aber auch der aktuelle Matrix Kernel ohne Probleme.
Aber auch der INK Kernel läuft gut mit Miui.
MfG
Sent from my Nexus S using Tapatalk 2
