[ROM][JBO03E] Brainmaster's Stock JB 4.1.1
  • 21 Antworten
brainmaster
brainmaster
What do you get with this ROM?
Its Full Stock JB 4.1.1 ROM that includes following
Tweaks:
- Deodexed
- Rooted
- Zipaligned
- Busyboxed
- Busybox Run-Parts (support for scripts in the init.d)
- Supercharged
- Circle Battery
- Unsecured Boot.img
- ADB Enabled
- EXT4 and TCP Tweaks
- Dalvik moved to the /cache partition
- Advanced automated Zipaligning of system/app and /data/app
- ADFree Hosts file
- Sticky Recovery (Custom recovery doesn't get overwritten after flashing the ROM)
- Unicode support for SMS/MMS
- AppWidgetPicker
- 360° Rotation
- Symlinked SDCard to /storage/sdcard0
DISCLAIMER:
You are installing this ROM on your own risk!
How to install:
- Copy ROM file on your SDCard,
- Start Recovery,
- Go to "mounts and storage" and select format /system, /data, /cache, /boot,
- Install ROM,
- Reboot,
- After the Setup procedure, let the Phone settle down for few minutes.
Further Instructions:
Don't forget to Force the GPU Rendering in the Developer Options.
Download:
Brainmasters.JB.4.1.1.JRO03E.Nexus.S - Size: 198 MB MD5: 1c7f4896c52937a4fce912db33a7104a
If you like this ROM you can support my work with a PayPal Donation.
Note:
This is probably my last tweaked ROM for the Nexus S Community, since I'll be probably moving in the next weeks to GNex.
You are great guys and great Community - thanks for supporting my work. Without you, I wouldn't spend so much time tweaking my Phone.
  • JBO03E.Stock.Battery.zip
Reaktionen: Aljeex, ppr, MöCkY und 11 andere
Reserviert 1.
Nicht du musst dich bei der community bedanken sonder wir bei dir!! Schade das du uns nexus s user richtung gnex verlässt!! Auf jeden fall ein grosses danke für all deine arbeit und dein hilfe!! :thumbsup::thumbsup:
PS: Natürlich auch dein jelly bean rom funktioniert erstklassig
Danke du Brainmaster! :)
Werde dir bald Folgen und mir auch das Galaxy Nexus kaufen.
Werde die Rom nachher mal aufspielen und schaun. :D
Kann schon jemand was zur Akkuleistung sagen?
Das ROM läuft ja soweit echt spitze, aber es gibt da noch paar Dinge (Bugs?), die mir aufgefallen sind:
- CRT Animation fehlt (nicht so wild)
- Karten in Google Now funktionieren nicht :( (ziemlich wild)
Mehr ist mir in den 2-3h, die es jetzt bei mir läuft, noch nicht aufgefallen. Gibt's schon Ideen, was man da machen kann?
Ich hab sie grad am Testen und die läuft nicht schlecht, auch mir fehlt die CRT-Animation. Schade finde ich, dass LBE noch nicht auf JB läuft(die ROM wird dann unbenutzbar), auch wenn es vllt. nur an LBE selbst liegt und daher noch an JB angepasst werden muss. Werde die ROM daher jetzt erst mal nur offline nutzen.
Freu mich dann schon rießig, wenn CM10 und Co. schon weit fortgeschritten sind. :)
animation ist da
google now läuft, oder eben das was google für deutschland zZ vorgesehen hat.:mad:
was du machen kannst, fullwipe.
Geiles ROM, danke BM. :thumbup::thumbup::thumbup::thumbup:
Welchen alternativen Kernel, der bei voller Akkuladung 100% anzeigt, empfiehlst du?
Hello verwendet von euch noch wer swiftkey und hat auch das problem das man es nach jedem neustart wieder als eingabemethode einstellen muss!? oder hat jemand eine lösung dafür?
Ist bei mir auch so, wird wohl an Swiftkey liegen.
Wird noch eine weile dauern bis alle Apps für JB optimiert sind.
Gesendet von meinem Slider SL101 mit Tapatalk 2
Naja dachte da es gestern schon ein update gab von swiftkey sollte das eigentlich hinhauen!
Version 3.0.0.302
Bug fixes including UI and Jelly Bean issues
Version 3.0.0.302
Ich habe Version 3.3.0.0.302 und keinerlei Probleme
Ja die version hab ich auch!! Ist aber kein problem von brainmasters rom sondern habe ich bei allen jellybean roms!
Ich hör' hier immer Probleme, welche Probleme?
Eben hatte ich nach'm Neustart - weil hier alle von Problemen reden - die Meldung Eingabemethode wählen.
Zur Strafe :bored: hab' ich noch'n Neustart gemacht und... keine Meldung mehr :cool2:
Geht doch! :thumbup:
Tja schön für dich wenn es bei dir funktioniert!! Solche postings kannst dir sparen!! :cursing:
hab das Rom seit gestern laufen. Allerdings habe ich das Problem das es nicht gerade schnell läuft. Öfter mal ein hakler und am nervigen ist, das der launcher oft bei startet. Ich drücke die Home taste und sehe erstmal einen leeren screen bis alles neu geladen wurde. Habe auch schon andere Kernel und alternative launcher benutzt.
Hat jemand ähnliche Probleme oder ne Ahnung womit das zusammen hängen kann?
Zur Info, ich habe ein i9020a,falls das wichtig ist.
Grüße
Gesendet von meinem Nexus S mit Tapatalk 2
Habe selbiges Problem mit dem sich ständig neu aufbauenden Launcher. Auch insgesamt kann ich keine Unterschiede zu CM9 feststellen, Project Butter bleibt mir ziemlich verborgen, den großen Leistungsschub jedenfalls spüre ich nicht.
Danke an BM fürs bereitstellen, ich wechsel aber wohl wieder zu CM und warte dann auf Version 10.
Auch mir mit der JB Rom Beta5 von T-Rex geht es so. Am Anfang war schon ein utnerschied aber nach Installtion einiger Apps etc. war dieses "Butter" Gefühl weg. War vermutlich auch ein Placeabo aufgrund der Vorfreude ;)
also wenn ich bei diesem ROM den Air Kernel flashe habe ich laufend reboots. Mit normalem kernel funktioniert alles perfekt
InVade
puma95
puma95
Elting
Hurst
forb'S
forb'S
forb'S
