Adinoid
Enthusiast
- 1.104
PERFORMANCE ENHANCEMENTS
* zipaligned and all images optimized
* reduced boot up time
* reduced app starting time
* improved scrolling cache
* increased navigation button animation speed
FEATURE LIST
* Based off of Clean Android 4.1.1 Rev3 (JRO03H)
* T-mobile Theme Manager (tmobile, CyanogenMod, xoomdev)
* T9 Dialer/Landscape/Dialpad Settings (CyanogenMod)
* Customizable Messaging App:
- SMS Templates (rciovati)
- Custom Vibrations (mssmison)
- Timestamp Options (aravance)
* Customizable Status Bar: (miui, CyanogenMod, romanbb, sethyx, kejar, syaoran12 ,romanbb)
- Battery Icon style
- Battery Icon in notification bar
- Miui style battery bar
- Clock style
- Clock Am/Pm style
- Clock Day of the Week
* Customizable Notification bar:
- Notification bar Power Widget (DvTonder - CyanogenMod)
* Customizable Navigation Bar: (Zaphod-Beeblebrox, KhasMek, romanbb)
- menu button visibility and location
- number of navigation buttons
- order of navigation buttons
- navigation bar size
* Customizable Lockscreen:
- Customizable number of lockscreen targets (CyanogenMod)
- Configurable lockscreen wallpaper (Danesh M)
- Add weather to the lockscreen (DvTonder, Danesh M, Marius Volkhart, Rick C, Aokp)
- Add calendar reminders to the lockscreen (David Morgan)
- Ability to unlock with menu (CyanogenMod)
- Quick pin unlock (unlock with pin/password without pressing ok - CyanogenMod)
* Customizable Sound Settings:
- Customizable volume panel (Stevespear426)
- Configurable ascending ringtone (Danny Baumann)
- Safe headset volume (CyanogenMod)
- Volume rocker music controls (CyanogenMod)
* Customizable Display Settings: (CyanogenMod)
- Customizable Rotation Modes
- Customizable LED Pulse (Duration and Color)
- Volume wake (tap either the up or down volume key to wake your phone from sleep)
- Volume music controls (long press volume buttons to skip tracks)
* Custom Profiles (CyanogenMod)
- assign different profiles to change the behavior of your phone to your liking
* Quiet Hours (CyanogenMod)
- the ability to set when notification sounds, haptic feedback, vibration and notification light will function
* Performance Settings:
- Processor Speed (change cpu governor and clock speed)
* Info and Tools:
- Spare Parts
- Development app
- Testing Settings
* ADB over Network (enable TCP/IP debugging over Network interfaces (WiFi, Usb networks)
EXTRA TOOLS
* Superuser app
* Busybox
* Bash
* Nano
na ja,Adinoid schrieb:Probier die ROM aus dann weißt du was drinnen ist ;-) ich kann auch nicht alles machen hier (hab die Features nicht gefunden)
blur schrieb:na ja,
der Wunsch der Forumsleitung ist es nicht einfach nur mit paste & copy hier nen Thread zu eröffnen,
sondern auch möglichst eigene Erfahrungen und Einschätzungen zu beschreiben.
War auch ne Weile hier oben angepinnt.
