[ROM][ICS][AOSP] Bugless Beast | (Nightlies)
  • 5 Antworten
Adinoid
Adinoid
Enthusiast
1.104
Verlinke hier nun eine weitere ICS ROM von Peter Alfonso aus dem XDA-Thread :flapper:.
  • Notable Changes/Features:
  • Common: Android 4.0.4 via stable release branch
  • Common: Deodexed, rooted, "user" build variant
  • Common: Hide "System updates" preference
  • Common: Enable adb debugging by default
  • Common: Disable data roaming by default
  • Common: Add additional live wallpapers
  • Common: Add various bug fixes from CyanogenMod
  • Common: Add build date to "About" screen
  • Common: Remove bugmailer from user builds
  • Common: Add extended power menu (DvTonder)
  • Common: Allow 180 degree rotation
  • Common: Disable kernel debugging, update by merging remotes
  • Common: Add "Mark All Messages As Read" button to Email app (dustinmj)
  • Common: Enable more keyboard keys for larger screens (cyanogen)
  • Common: Add auto-dim backlight setting (solarnz)
  • Common: Add CPU Settings to "Developer options" (cyanogenmod)
  • Common (Phones): Add notification drawer toggles and settings (cyanogenmod)
  • Common (Tablets): Add auto-hide status bar setting (flemmard)
  • Common (Tablets): Add Wi-Fi, Bluetooth, and GPS toggles (flemmard, tdr)
  • Common (Tablets): Add home button to browser toolbar
  • Common (Tablets): Move status bar clock to the right, fix padding
  • Common (Tablets): Use desktop user agent by default
  • Common (Tablets): Hide mobile signal icons when connected to Wi-Fi (solarnz)
  • Stingray/Wingray: Enable dock settings
  • Toro/Maguro/Crespo/Crespo4G : Add Google Wallet application
  • Toro/Maguro/Crespo/Crespo4G: Add "Nexus" notification sound
  • Toro: Increase battery capacity from 1750 to 1850
  • Toro: Allow use of native tethering for free
  • Toro: Remove Verizon applications and libraries
  • Crespo/Crespo4G/Stingray/Wingray: Add Face Lock security feature
  • Crespo/Crespo4G: Add Touch To Focus camera feature (havlenapetr)
  • Crespo/Crespo4G: Disable keeping bluetooth module hot by default
*Note: I make changes almost daily, be sure to check the changelog or my github for the latest.
Downloads:
Crespo (Nexus S)
*Note: I make builds almost daily, be sure to check the above links for the latest.
Miscellaneous:
I have attached screen shots to this post and my Google+ album.
There are no bugs, hence the name "Bugless" Beast.
Reaktionen: anime und Nexus S
Ich hole den Thread mal wieder hervor aus den Tiefen unserer Untergegangen Threads. :D
Pete ist nun auch bei den XDA`s verfügbar mit seinem Bugless-Beast und hat extrem viele gute Kommentare bekommen.
Eine Chance hat der "Daily-Driver" auf jeden Fall verdient, finde ich :laugh:
@ all,
clean, fast and stable!!! Spiele mir immer das aktuelle
nightly drauf. Klappt problemlos nach einem clean cache und dalvik wipe.
Roddy
Auch eine gute Rom, wenig Einstellungen aber smooth & elegant :D
Gibt es eigentlich auch mods (ics reloaded ..) für diese Rom?
Gesendet von meinem Nexus S mit der Android-Hilfe.de App
mike.bee schrieb:
Bin zu Pete's Nightly BuglessBeast gewechselt. Spürbar flotter und Akku hält bei 3H Screenontime auf voller helligkeit bis zu 10 stunden. Da ist bei den meisten Roms schon nach 6 Stunden schluss...
Kan ich nicht bestätigen, also bei mir ist am Abend bei häufiger nutzung die Akku Leistung ähnlich anderer ICS Roms.
Am besten ist die Akku Leistung noch mit Open Kang wo man den Energiesparmodus konfigurieren kann (Sreen off- Data off) DAS spart Akku!
kann man irgendwie den 'Skip tracks by pressing volume' Mod einbaun ? damit wäre diese Rom perfekt, sie läuft sonst super smooth !
  • lagloose
lagloose
forb'S
forb'S
forb'S
Hectic
AdO089
AdO089
