[ROM] CyberGR-MOD|NS.NGN|Hybrid ICS|CM9+AOKP
  • 31 Antworten
Adinoid
Adinoid
Enthusiast
1.104
Eine andere Version von ICS. Denke es würde die User hier interessieren :flapper: Link zu dem XDA-Thread
CyberGR-MOD|NS.NGN ver. X.0 ICS​
**CyberGR-MOD|NS-NGN ICS Hybrid is finally here with lots of changes, many additions and all ICS features working fully TWEAKED, really FAST, SMOOTH and STABLE..**
Features :
Based and built-on from latest sources of CyanogenMOD 9 + AOKP
Android version 4.0.3 - IML74K
Radio : free (you can flash which is best for you and your area, or stay with what u have now)
All the features till now supported from CM9 builts + AOKP additions
SD-Nand Card I/O Speedtweaks - EXT4 | Ram Tweaks
All Ezekeel`s Mods *BLN|BLD|BLX|LIVEOC*
NSTools by arifhn Integrated to easily configure all the above Mods
Overclock able up to 1440Mhz + Extra Boost with LIVEOC
Zipaling on boot
Zipaling all apps for better Ram usage
Fully Deodexed
Rooted and Busyboxed
Fast times on Reboots & Boots
3G/HSDPA Tweaks
Init.d scripts support
Cron scripts support
Full GPU HW accelaration
Newest Host File (Ads.remove)- 95%+ of ads are now blocked
Tweaked Trebuchet Launcher2.apk + 2 new wallpapers
New HD ICS Galaxy Nexus Boot Animation
Dev Tools + Spare Parts
CyberGR-MOD Control App (Massive thanks to RomanBB and Open Kang Team for letting me use those source code.)
Voodoo Control App
Debugging notification hide tweak
Working Media Effects under Video Recorder Settings
Facebook Sync hack
T9 Dialler
Hold back to kill application
Touch to focus on camera app.
Quad lockscreen and Octo lockscreens
Battery percentage
Enhanced Power Menu
Multi language
Control music with volume keys while screen is off
Power menu toggles
Newest Android Market and Google Music 4 ICS + MusicFX
Car Home Included | Modified Calculator with scientific functions | ES File Explorer by EStrongs | ICS Sounds with +2db Boost |
ROM Manager | Google Maps & Earth| Google+ & Messenger | Google Wallet |
And more..
What`s working : EVERYTHING!
Download Version:
Link
Reaktionen: Firetime
Hatte diese rom lange laufen. Für mich persönlich die beste. Bin nur wegen Aktualisierung diverser features auf die open kang gewechselt. CyberGR ist aber schnell nachgezogen. Schätze, ich muss mir v4 nochmals ansehen. Wenn man auf maximale Performance nicht so wert legt, lohnt sich ein Wechsel aber wahrscheinlich kaum. Die kangs sind mittlerweile auch top.
Auf jeden Fall hat diese Rom einen eigenen thread verdient. Wundert mich eigentlich, dass ihr bisher so wenig Beachtung geschenkt wurde. Sie war von v1 an schon sensationell ;) .
Update!
24.01: Fixed Network Locations, Error when trying to buy from Market - Fixed, Hopefully fixed NFC Tags (if there was any problem-lol), Some build.prop tweaks (data roaming now must be off by default) , Updated Hosts, Some changes to CyberGR|MOD Control app. regarding custom apps on Quad and Octo Lockscreens, Version name is now 5, Base kernel is now Matr1x 14.5 CFS by Mathkid95, Start-Up tweaks don`t stick after rebooting device - Fixed, Added CyberGR|MOD logo in updater-script and some sauces (for extra boost.. ;-)
Update. Startpost ist aktuell.
03.02: Updated to latest CM9 1.1 sources, Updated NStools to latest version, Updated Nova launcher to beta13, A bounce of new abilities under CyberGR|MOD Control, Added two new battery styles to choose from, Updated Hosts File, Disabled Start Up Tweaks under CyberGR|MOD Control (Everything you need is running by default), based kernel is now ICUP Speedy 7 by Eugene, Updated apns-conf file from 4.0.4 NS4G Port (Maybe better Compatibility for MMS), Added Font Installer app with the ability to choose from over 190+ Font styles, replaced default padlock icon with a colorful one, completely builted up from zero again some minor tweaks and some other minor things i can`t remember all of them right now! ;-)
Hat diese Rom eigentlich keiner mehr am laufen ? :D
auf XDA scheint sie ja nicht schlecht abzuschneiden ..
Was steht denn bei den xda´s?
Ich war mit dieser ROM von Anfang an sehr zufrieden. Hab mir jetzt (dir zuliebe :D) die v.8 aufgespielt. Und es funktioniert alles top. Wage aber nicht mehr zu beurteilen, ob sie besser oder schlechter als irgendeine andere ROM ist.
Ich hab sie auch draufgespielt und bin total zufrieden !! :D
Also, ist eine der BESTEN Roms,meiner Meinung nach, die ich getestet habe (Spitzenreiter neben nuhetri, nur das mit dem Fullwipe ist so eine Sache ..), läuft alles sehr smooth und die Einstellungsmöglichkeiten sind auch sehr schön. Wird sicher eine Weile draufbleiben :D
@flying fox: was hast du für einen Kernel drauf & was für Akkulaufzeiten ? :D
Den experimental von Steve Garon, siehe Signatur. Akkulaufzeit kann ich (noch) nicht beurteilen. Ganz ehrlich, ich denke, große Unterschiede wird es nicht mehr geben. Der Kernel macht einen stabilen Eindruck, ist performant, hat alle features, die ich möchte, und zumindest vom "Ruf" her soll er Akku schonend sein.
Diese ROM ist auch mein absoluter Favorit, neben der CNA. Mal sehen, wie lange sie mich hält (wahrscheinlich nicht länger als bis zum nächsten CNA-update :D) ....
Wie sehen denn deine Akkulaufzeiten bis jetzt aus? gerade in Hinblick darauf, dass du auch den Nova Launcher nutzt, den ich sehr mag!
Ich bin jetzt auch auf sgaron experimental umgestiegen, und kann es daher auch noch nicht beurteilen.
Heute einbisschen Zeit gehabt, mich durch div. Roms zu wühlen. Von dieser hier bin ich an sich schon begeistert, aber die aokp 25 fühlt sich doch noch etwas zackiger an. In wie weit das am OpenGL-Patch von Brainmaster liegt, den in nun dazu geflasht habe, weiß ich aber nicht. Allerdings war die Rom (aokp) schon beim Einrichten spürbar flüssiger. Jetzt sage ich der CyberGR doch wieder "good bye" :) .
Startpost ist nun aktuell
17.02: Updated to latest CM9 Sources, Added power key shutter in camera app, Added ability to change brightness by sliding your finger slowly on the statusbar, Toggles icons (alternate toggles) will be always white now, Ability to add CyberGR|MOD Control shortcuts on your desktop, Updated sync toggle, Updated Power Saver Code, Ability to set custom DPI, Implementation of weather display above Carrier text in notifications Drop-Down Area, End call button in notification area while in call, Fixed Clock some times not currently updating, Double checked GPS, Minor Speed Tweaks, Updated Rom Manager APP, Added Working Sound Recorder app (now will normally appear in your applications drawer), Added Torch app, Updated Host File as always, Updated Gapps, Added CyberGR|MOD Wallpaper app (Beta, more proper CyberGR|MOD Wallpapers will be added), Removed Wallet app (I hope US ppls can easily download it from the market or use an alternative method), boot.img is now unsecured, fixed FaceLock..Uhm maybe i missed something, but don`t worry won`t be so important!
Kann man bei aokp 25 den Bilschirm mit der Menütaste entsperren? Die anliegende zip muss ausgepackt werden und muss dann hier data/local/enable_menu_key liegen
  • enable_menu_key.zip
CyberGR-MOD|NS.NGN ver. 9.0 Hybrid Mix ICS Neue Version.
Changelog!
07.03: Reorganized all tweaks, Cleaned up everything that was messing around, Updated Weather options and code under CyberGR|MOD Control, Weather option for your lockscreen, Updated file Hosts as always, Added options to change your singal style (text and w/dBm), Added on-Screen buttons - they are on by default - you can personilize them as you wish via CyberGR|MOD Control and use the power menu to turn them On or Off when you want it, LCD Density has now a walk through guide (Wizard), Added airplane mode toggle to power menu, Added latest stable CM Music app, Updated NSTools app - Rom Manager - Google Maps - Google Voice, Updated torch toggle, Added torch widget, Added one new CyberGR|MOD Logo Wallpaper into Wallpapers app, Replaced contacts.apk with a reverted black one, Replaced old Calculator.apk with normal ICS one because of display problems when on-screen buttons are on, Base kernel is now Mathkid95`s Matr1x 17.5 CFS, Hybrid MIX brings overall much better performance and battery life!Secret cookies inside!!New Short name "Tornado"..
Ich habe ebenfalls diese Rom wohl noch die ver 8.0 werde dann wohl die Tage mal die 9er draufziehen^^
allerdings habe ich folgendes Problem:
taette schrieb:
Nach Custom Carrier Label kein Datennetz mehr?!
Guten Tag zusammen,
ich habe ein Nexus S und die Custom Rom CyberGR-MOD|NS.NGN ICS_ENG installiert zusätzlich den Matr1x Kernel cfs v17.5 nun habe ich das Problem, dass ich sobald ich ein "Custom Carrier Label" definiere kein Datennetz mehr und diese Einstellung lässt sich wohl ohne erneutes Flashen nicht rückgängig machen, so glaube ich zumindest!
Falls jemand ähnliche Probleme gemacht hat, also ob dies jetzt speziell an der CyberGR-MOD wäre ich sehr interessiert.
Falls ihr noch Fragen zu meinem Smartphone habt, ich habe alles erdenkliche in mein Profil eingetragen.
€dit: Ich habe noch etwas wichtiges vergessen: Ich habe zwar Balken, allerdings sind diese grau und nicht blau wie es sonst üblich wäre.
Quelle:Mein Thread
Habe jetzt mal probeweise dieses Rom drauf. Zusammen mit dem empfohlenen Trinity Kernel.
Habe damit allerdings einen derben Batterydrain! Bin nach 7h mit 2g und wenig Aktivität bei 76 Prozent. Hoffe das bessert sich noch ein wenig, sonst muss es wohl wieder runter.
4.0.4 - Update (version 10 Hybrid Mix) ist seit heute draußen. Noch keine Gelegenheit zu flashen, aber bald :) . Wird dann schwer, mich zwischen CyberGR, Pixel Rom und den CM9 nightly´s zu entscheiden.....
Changelog zur neuen Version
03.04: Updated to 4.0.4 IMM76D, Rom Patched to support BigMem, True Blue ICS icons included, Fixed misplaced Octo Lock Screen style, Fast Charge Support, Removed Nova Launcher and Trebuchet Launcher, Added Latest Official ICS Launcher and Apex Launcher 1.0.4, Navigation Bar aka On - Screen Buttons (soft keys) are Off by default now -you can enable them by going into CyberGR|MOD Control, Ability to change Navigation Bar Width and Heigth, Navigation bar re-touched under Power Menu options, Included and Fixed Face Unlock, Added Support for many more Languages and add on dictionaries into LatinIME.apk (Ex : Greek), Fix a problem when you set a Custom locations under Weather Option giving FC to CyberGR|MOD Control, Added Weather Panel (Tap on the Weather Icon when using Weather Panel to update it) , Fix Custom Lockscreens app shortcuts, Added ability to more volume slider options - You can enable them from CyberGR|MOD Control - General UI - Misc, Added ability to set custom lockscreen images for any target, Toggles on the very top of the statusbar option, Added lockscreen calendar options, Fixed Sync toggle, Added AOSP Lockscreen style, Added Latest Play Store and Play Music, Removed Inverted Contacts - People app added the default one back, Color Multipliers tuning and Color Gamma Tuning options under CyberGR|MOD Control if your Nexus S support them, Added day of the week under CyberGR|MOD Clock options, Padlock icon for the lockscreen is now the default ICS White one - I will release an update with the colourful one for users they still want it, Removed ES File Explorer and added CyberGR|MOD Rom Explorer with Root and Wifi FTP Support (based on MIUI File Explorer), Updated Google Maps - Google Earth and YouTube apps to the latest versions!!And many many more...New Short name is CyberGR|MOD "Hurricane"..
Kurz hineingeschaut. Hätte mir ein wenig mehr erwartet. Gefühlt gleich performant wie die CM 9 nightly´s, in meinen benchmarks um 50 Punkte mehr :) , leider fehlen mir ein paar Einstellungsmöglichkeiten bei den toggles, so zB wlan-thethering. Wetter scheint auch nicht zu funktionieren, ist mir aber eigentlich egal.
Für die, die die rom flashen: daran denken, dass lockscreen-Einstellungen nach wie vor nur gehen, nachdem man auf englisch umgestellt hat (direkt im CyberGR-Kontrollmenü.
