[ROM] CyanogenMod 9 v4.0.3 von KalimochoAz
  • 312 Antworten
blur
Enthusiast
1.234
Hier will ich Euch die CM9-Version von KalimochoAz aus dem CM-Team vorstellen.
Der Link zum Original-Thread:
[ROM] CyanogenMod 9 + CM Night builds - xda-developers
Downloads aktualisiert am 21.04.:
v7.0
GappsICS vom 17.03.2012
Die beiden Zips müssen direkt hintereinander geflasht werden,
ohne einen Reboot dazwischen.
NEW ON v7.0:
  • Deep idle is now tested and stable.
  • Ne preset screen with gama/multipliers combinations (thanks to ale.landra91 cpaixao and malycomix.
  • More battery time.
  • Freq issues solved on deepidle
NEW ON v6.0:
  • Deep idle is now stable, at least on our tests.
  • Gamma hack is new, a new idea with great colors Check the CM preset button on gamma hack and on multipliers.
  • Code updated
NEW ON v5.0:
  • New kernel 3.0.27
  • Updated code to 05.04.2012
  • Kernel and code based on 4.0.4
NEW ON v4.0:
  • New kernel 3.0.25
  • Updated code to 22.03.2012
NEW ON v3.0:
  • Added Torch, now with widget
  • Added option to camera to take photos by pressing power button
  • Updated Code to 20.02.2012
  • Added code to display %battery
  • Removed Lulzactive
  • Solved the caller app issue ( after some calls you received and FC on number pressing on old releases )
  • Updated kernel 3.0.21 & new kernel speeds
  • Changed various settings
NEW ON v2.0:
  • More kernel upgrades
  • code updated
  • Added some overclock patches for stability
  • New music app
  • Added New settings
  • Added new governor lulzactive. I suggest you to use this one for depending the use of your phone.
  • New Settings icons
  • No more flickering on turn on/off the screen
  • Modified kernel for kms
  • lulzactive as default governor with some tweaks.
  • Added setting to control kms ( settings/ performance / memory ) You will win memory on your devices
  • Default values for ksm set to reduce cpu usage
  • more system updates
  • New option to control lulzactive governor. Look on Settings/advanced
  • Reapaired error at multiplier colors
  • Cleaned the code at device options
  • Added Torch app working ( https://github.com/KalimochoAz/IcsTorch )
  • Voodoo wm8994 DSP corrected into DSPManager to avoid sporadic FCs
Reaktionen: Huede82, anime, Nexus S und 3 andere
Bleiben alle Einstellungen erhalten, wenn man es über CM7 flasht?
Ein Flashen von ICS über ne GB-Version,
ich kann mir das nicht vorstellen, dass das funktioniert.
Aber nach nem Backup kannst du es ja testen ;)
Kali meint nur, dass das drüberflashen über ne CM9 Version klappen soll.
Ich will das gleich testen, bin aber hier mobil unterwegs und das dauert ...
Shit-Edit: Ich muss das wohl auf morgen verschieben, Vodafone lässt über Proxies nur bis zu ~32MB Dateigröße bei Downloads zu,
habe ich nicht zum ersten Mal
:bored:
Ihr müsst weiter testen
Kann es sein das mit der 15er Version der Kalender nicht funktioniert? Bekomm den nicht zum synchen :(
Edit: mit dem neuen App Packet geht es: http://bit.ly/gapps403_v2
Reaktionen: blur
Die Bedienung der Alfa 15 ist deutlich flüssiger als es noch mit der Alpha 13 war.
Zu GoogleMaps:
In dieser Rom steckt noch Google Maps 5.
Um auf 6 updaten zu können, muss Ihr erst die 5er Version löschen.
Hierzu in Titanium Maps als User App deklarieren und dann löschen.
Dann ist der Weg frei für den Download von 6.0 aus dem Market
Damit dann aber das mit personalisierten Karten etc. klappt,
musst Ihr Maps wieder in eine System App umwandeln.
läuft die alfa 16 besser als nexus beam 4.1 ?
würde mich auch interessieren!
Gesendet von meinem Nexus S mit Tapatalk
ich weiß nicht, ob Ihr darauf ne Antwort bekommt.
Es scheint mir, dass nicht allzu viele mit CM9 unterwegs sind,
und dann auch noch einen Vergleich zu Nexus Beam 4.1 herstellen können.
Ich hatte zwar mal eine "ältere" Variante von Nexus Beam auf dem Phone,
die mir nicht gefallen hatte, aber das lässt natürlich keine Aussage zu über 4.1.
Nexus S v4.0.3 Alfa 17 ist bereits zum download freigegeben ;)
Reaktionen: blur
Danke,
der Eingangspost ist angepasst.
Da kommt man ja mit dem Flashen nicht hinterher.
Leider funktionierte nach dem Drüberflashen von 17 über die 16
die Kalendersyncro nicht mehr.
Habe alles Erdenkliche versucht, also doch eine Neuinstallation der 17.
Wenn das so weiter geht, dass am Tag 1-2 Alfas kommen,
die sich nicht einfach drüberbügeln lassen, muss ich aussteigen aus dem Flash-Wahn.
Nicht alle lesen ja bei den xdas mit,
Kali hat gerade diese Einstellung vorgeschlagen:
I suggest you go in launcher settings ->Drawer->Unmark "join with apps" It will work better
Mal ne blöde Frage:
Wo finde ich denn die Einstellungen für den CyanogenMod?
Oder ist der einfach noch nicht soweit, dass bisher außer den Sachen in Preferences nichts drin ist?
Oli92 schrieb:
Mal ne blöde Frage:
Ja genau, mehr gibt es bisher leider nicht.
In manchen Versionen kommt dann ein Menüpunkt dazu.
Spannend ist was der neue CM9-Launcher "Trebuchet" noch bringt.
Jetzt schon sind die Homescreens horizontal bedienbar,
die Dockbar soll ja scrollbar werden.
Hoffentlich ist bald wieder die Energiesteuerung in der Benachrichtungsleiste und das passende Widget drin. Das vermisse ich am meisten.
Me too!
Ja jeder neuen Alfa gucke ich da zuerst.
In Brainmaster Miui ICS gibt es die Leiste schon.
Verdammt bei mir rückelt es sobald ich ins MENU möchte :cursing:
Habe sogar ein Neustart versucht aber dennoch ,obwohl alles Wiped wurde :-(
Die letzten Alfa-Versionen waren bei mir richtig schnell in der Bedienung.
Keine Lags, kein Ruckeln.
Du hast die 17 neu installiert, davor nen fullwipe gemacht?
Ich wipe dann aber zur Sicherheit immer nochmal Cache und Dalvik
und formatiere die System-Partition.
System-Format empfiehlt auch Kali ausdrücklich.
Jep genau so habe ich es gemacht ... ich habe ja noch ein FULLWIPE.zip die habe ich am ende auch ausgefürht.
Ich versuche es aber nochmal,mal sehen.
