[ROM] CMREX v.11 FinalRelease|Base CM9|Goodbye ICS
  • 466 Antworten
Wie gefällt euch das ROM ???
  • Umfrageteilnehmer
    24
T-REX600
Gast
CMREX v.11 FINAL RELEASE | Smooth and Fast
Goodbye ICS
So da ich das MOD basteln im CM9 Nightly Thread eingestellt habe, bringe ich Euch jetzt meine selbst zusammengestellte CM-ROM.
So das war hier meine letzte CMREX Rom, ein großes Danke an Euch allen !!!!
Changelog:
Code:
[B]v11 Final Releease.18-08[/B]
- Android 4.0.4 IMM76L base CM9 Final Releaese code + Kernel
- AROMA INSTALLER
- Sony Mobile Bravia Post-Processing Engine [COLOR=royalblue]"Bravia Engine is a post-process engine created by Sony for the Sony Ericsonn phone brand. BRAVIA is an acronym of “Best Resolution Audio Visual Integrated Architecture”. You can say the enhancement only on-screen because the engine not changes the input of the screen but it operate on the output."[/COLOR]
- [COLOR=red]update files:[/COLOR] BeatsAudio (31.07.2012) Audio Enhancement Engine [COLOR=royalblue]"[/COLOR][COLOR=royalblue]is a sound engine that change the output values of your phone. It includes sound libraries and a software equalizer for the best audio experiance! The best quality is produced in cooperation with Beats Audio! This enhancement can work with the standards htc enhancement! So it can work with beats audio for an exclusive music and movie experience!"[/COLOR]
- Sony PlayStation Certification [COLOR=royalblue]"[/COLOR][COLOR=royalblue]PlayStation Certification will allow you to enjoy the stuff created for exclusive devices have this certification (like Games, etc.)!"[/COLOR]
- SRS Sound Einstellungen im Musikplayer
[LEFT]- Brainmaster Tweaks: Build.prop, 3D Patch [/LEFT]
- AwesomeBEATSv3 (Sound Settings wenn SRS off)
- Docking Einstellungen möglich wie beim GNEXUS
- Desing  Standart ICS, Cobalt (blau) und Gummetal Cobalt (schwarz)
- Performens Tweaks
- [COLOR=red]neue[/COLOR] Benachrichtigungs und Klingeltöne
-[COLOR=red] neuer[/COLOR] Lockscreenton
- [COLOR=red]neuer[/COLOR] geänderter Lockscreen Style
- YouTubeHD + Plugin
- geänderte Grafik fürs Wetter im Lockscreen
- NSTools app
[LEFT]- Apex Launcher app
- Trebuchet Launcher app
- ES Datei Explorer app
- Font Installer app
- Dolby Mobile app
- Adobe Air app
- Adobe Flashplayer app
- Spare Parts+ app
- Titanium Backup app[/LEFT]
[B]v10 RC2.19-07[/B]
- Android 4.0.4 IMM76L base CM9RC2 code + Kernel
- AROMA INSTALLER
- [COLOR=red]update files:[/COLOR] BeatsAudio5.1 Audio Enhancement Engine [COLOR=royalblue]"[/COLOR][COLOR=royalblue]is a sound engine that change the output values of your phone. It includes sound libraries and a software equalizer for the best audio experiance! The best quality is produced in cooperation with Beats Audio! This enhancement can work with the standards htc enhancement! So it can work with beats audio for an exclusive music and movie experience!"[/COLOR]
- SRS Sound Einstellungen im Musikplayer vom SGS3
[LEFT]- Supercharger V6
- CM9 Music app
- Performens Tweaks
- Jelly Bean PlayStore
- geänderter Lockscreen Style
- NSTools app
- Desing Cobalt und Standart ICS
- Dolby Mobile app
- Adobe Air app
- Spare Parts+ app[/LEFT]
[B]v9RC.01-07[/B]
- Android 4.0.4 IMM76L base CM9RC1 code + Kernel (3.0.36 Build vom 29.06.2012)
- AROMA INSTALLER
- BeatsAudio5.1 Audio Enhancement Engine [COLOR=royalblue]"[/COLOR][COLOR=royalblue]is a sound engine that change the output values of your phone. It includes sound libraries and a software equalizer for the best audio experiance! The best quality is produced in cooperation with Beats Audio! This enhancement can work with the standards htc enhancement! So it can work with beats audio for an exclusive music and movie experience!"[/COLOR]
- Volume+ app (entfernt)
- CM9 Music app
- Performens Tweaks
- mehr Benachrichtigungs und Klingeltöne als CM9Nightly
- geänderte Bootanimation(entfernt)
- NSTools app
- Dolby Mobile app
- Adobe Air app
[B]v8.24-06[/B]
- Android 4.0.4 IMM76L base CM9 code + Kernel (Nightly Build vom 23.06.2012)
- AROMA INSTALLER
[LEFT]- Supercharger V6 (optional als zip)[/LEFT]
- Volume+ app (Sound Settings wenn SRS off)
- CM9 Music app
- Performens Tweaks
- Dolby Mobile app
- Adobe Air app
[B]v7.20-06[/B]
- Android 4.0.4 IMM76L base CM9 code+Kernel vom 19.06.2012
- AROMA INSTALLER
- SRS Sound vom SGS3 mit Einstellungen im Musikplayer
[LEFT]- Sony Bravia engine
- BeatsAudio (HTC)
- CM9 Music app
- Performens Tweaks
Code:
[B]CMREX-TabletUI v.1[/B]
- Android 4.0.4 IMM76I base PARANOIDANDROID v1.1a + CM Kernel vom 31.05.
[LEFT]- AROMA INSTALLER
- Apex Launcher
- ES Datei Explorer
- Desing Cobalt und Standart ICS [/LEFT]
- SRS Dolby Mobile Sound vom SGS3 (optional Dolby_srs_CMREX.zip)
- Volume+ App voll Funktionsfähig (Sound Settings)
[LEFT]- BeatsAudio (HTC)[/LEFT]
- neue Grafik fürs Wetter im Lockscreen
- More...
[COLOR=red][B]Hinweis!![/B] [/COLOR][COLOR=black]Vor dem wechsel in den Tablet mode unbedingt in Hybrid Setting den Hybrid Mode aktivieren. Falls eine App nicht starten will dann ebenfalls im Hybrid Mode die List of apps öffnen und dort bei der App den Density auf 240 und Style auf Phone mode stellen.[/COLOR]
Hinweis !! Bei der Installation des Roms gleich danach die Google Apps mit flashen, egal ob Fullwipe oder nur Wipe Cache Partition.
Download
Kernel:
Gapps:
GOOGLE APPS vom 17.03.​
XDA THEME THREAD
3D_Patch.zip (Danke Brainmaster)
Dolby_srs_CMREX.zip (optional)
Chainfire3D plugin:
libGLEMU_NVIDIA.zip
libGLEMU_POWERVR.zip
libGLEMU_QUALCOMM.zip
Was kommt als nächstes:
Reaktionen: aandryuha, Aljeex, B-Hard und 14 andere
@Blur: Bitte !!!!!!
Danke Dir, sieht gut aus
:thumbsup:
Wird aber heute nix mehr, der Download soll noch 40 Minuten dauern ...
Wie sieht es aus mit den Tweaks von Brainmaster?
Drüberflashen, oder sind die vielleicht schon drin?
:thumbsup:
Rom ist ziemlich groß geworden, ups :D:D Habe Brain seine Tweaks erstmal raus gelassen. Wollte noch was fürs nächst update aufheben :thumbsup: !
Eine frage: Mir hat damals der Mod super gefallen, allerdings hatte ich große Probleme mit der Stabilität, hatte immer mehr Abstürze und konnte am Ende teilweise keine SMS' mehr empfangen.
Wie schaut es eigentlich hier mit der Stabilität aus? Würde die ROM echt gerne nutzen, nur ist mir die Systemstabilität eben auch sehr wichtig.
Oh man.....es gibt ja millionen Themes für ISC, das ist das erste was mir unglaublich gefällt! Gibt`s das auch einzeln?
+1
mir gefällt das auch super,
wie im Startpost bereits verlinkt:
Official CM9/AOKP Themes Thread **78 THEMES** - xda-developers
EDIT: Besser natürlich direkt im Market.
Der ursprüngliche Beitrag von 08:34 Uhr wurde um 10:04 Uhr ergänzt:
Eine Aussage hierzu wird in ein paar Tagen möglich sein, bis jetzt läuft es ohne Probleme.
Kein Wunder das Cobalt-Theme hat ja schon ~20 MB
Das war auch nicht das Problem bei mir, habe VDSL, die Plattform war langsam.
Reaktionen: richyg
Da muss ich Blur recht geben, wird sich in paar Tagen zeigen, weil jeder sein Rom mit Unterschiedlichen Einstellungen und Apps betreibt. Aber ich habe es jetzt bis auf paar kleine Änderungen schon seit dem 18.05. laufen, ohne Probleme:D . Bei den Mods war es immer so schwer da CM neue Builds rausgebracht hat auf dem der Mod nicht mehr abgestimmt war. Wo es sich ja beim kompleten Rom anders verhält !
T-REX600 schrieb:
Hat wer noch ne andere Quelle?
Will mir auf keinen Fall dieses iLivid Dingsda installieren :sneaky:
Der 3d-Patch von BM wurde hier schon öfter verlinkt, finde aber grade nix.
Lade gleich hoch als Anhang
Hier ist es :D:D
  • 3D_Patch.zip
Reaktionen: blur
Danach Chainfire3D aus Market laden und diese Plugins (Anhang) auf SDKarte schmeisen, Plugins in Chainfire Installieren, in Default OpenGL settings bei Use plugin auswählen. Nvidia läuft am besten laut Benchmark :D:D:D
  • libGLEMU_NVIDIA.zip
  • libGLEMU_POWERVR.zip
  • libGLEMU_QUALCOMM.zip
Reaktionen: bierpatriot1
So, habe mir gestern die ROM installiert. Lief bis jetzt eigentlich problemlos, nur hatte ich auf einmal bemerkt überhaupt keinen Empfang mehr zu haben. Ein Neustart brachte zwar Abhilfe, aber mal sehn wie sich das weiterentwickelt.
Bin aber mit dem Rom sonst zufrieden, das Theme gefällt mir sehr gut.
Wird es in späteren ROMs evtl. auch noch zusätzlich das Theme vom Mod damals geben, denn das gefiel mir damals auch richtig gut.
Bei mir keine Empfangsprobleme, wer weiß was es war. Zum Thema vom MOD sage ich "nein". Will diesmal bei CM9 bleiben und keine Misch Rom (CM9AOKP) auch wenn ich die Wetteranzeige und die vielen Systemeinstellungen selbst gern mit im Rom haben wöllte :D.
PS: Was hast du für einen Kernel, CM oder anderen ?
hab den normalen CM-Kernel.
OK! Na ja beobachte es mal . Oder mal unter Einstellungen-Drahtlos&Netzwerke-mehr...-Mobilfunknetze-Mobilfunkanbieter (Suchen lassen) nach suche auf "Automatisch auswählen" klicken, es erscheint "im Netzwerk Registriert" und dann sollte es nicht wieder vorkommen. :D:D:D
Der ursprüngliche Beitrag von 20:22 Uhr wurde um 21:06 Uhr ergänzt:
@Blur: Hast du Brain`s Tweaks mit geflasht?
Der ursprüngliche Beitrag von 21:06 Uhr wurde um 21:20 Uhr ergänzt:
Habe erst mal die Grafik-Geschichten abgearbeitet ;)
und dann zwar etwas gezögert, vermutlich gibt es Überschneidungen mit den Tweaks von BM,
und dann trotzdem noch die Tweaks installiert.
OK, wenns läuft ist ja schön, habe es bis jetzt noch nicht geschaft die mal zu flashen bis auf 3D patch.
Der ursprüngliche Beitrag von 21:25 Uhr wurde um 21:30 Uhr ergänzt:
Keine Überschneidungen gefunden!! Wenn du die zip Datei Brainmaster CM9 Tweaks meinst. Habe seine zip gerade mal durch geschaut!
blur schrieb:
läuft bisher ohne Probleme
ich dachte der 3D-Patch sei da auch drin.
ja gut der ist mit drin, überschreibt dann halt beim flashen Dateien die schon vorhanden sind ,mehr passiert da nicht !
Reaktionen: bierpatriot1 und blur
