richyg
frajo schrieb:BMs MIUIs = "lecker" bzw. in organisch: sabber, sabber![]()
Dann hätten wir das ja geklärt ;-)
Brainmaster läuft bestimmt schon mit angeschwollener Brust rum ;-)
Download MIUI ICS 2.1.6 BrainmasterVersion 2.1.6:
MIUI Changelog:
Recommendations:
[System]
- Added During calling, if you return to Home or go to other App, the top green bar can identify current call status (such as mute, speaker status, etc.)
- Added choose recent contacts, group contacts, and favorite contacts via Contact picker.
- Added prompts in Download Manager while downloading via data network, and download file size limit can be set.
[Phone]
- Added support for long press on Back key to force close the current application (available via the drop-down notification bar, click the Custom button to set)
- Optimization of restore factory settings interface layout
- Optimization of screenshots in mute mode with no sound
[Contact]
- Added support for displaying the name of service provider numbers (e.g. 10086 shown as China Mobile)
[SMS]
- Added selecting ringtones in contact details interface
- Added clicking on the contact picture displays number attribution in pop-up interface
- Optimization choose recent contacts, group contacts, and favorite contacts via Contact picker.
- Optimization if the current account has no group, it does not display Add Group in the contact editing interface
[Lock screen, status bar, notification]
- Added favorite message content can be extracted
- Fixed problem of draft text displaying 1970-1-1
- Fixed MMS download notification error
[Theme]
- Added support for setting the default behavior when USB is connected (via drop-down notification bar, click the Custom button to set)
- Optimization of the compatibility of Android 2.3 themes
[Download Manager]
- Fixed lock screen and application icon dont effect after applying.
- Fixed the error of icon board caused by lacking of icons in theme package
- Added prompts in Download Manager while downloading via data network, and download file size limit can be set. (see Download Manager -> Settings)
My Changelog:
- English / German / Chinese version
- Added Ehahnced EXT4 tweaks
- Added Battery calibration script
- Updated the ADFree hosts file
- OTA present for the next release
- Calendar and Gallery sync fix
- Eugene Speedy 3 kernel
- Some small fixes and other things that I've forgot
richyg schrieb:irgendwas bei der Installation zu beachten, wenn man von der vorhergehenden 2.12.30 englisch kommt?
Reicht cache und dalvik wipe und dann drüber flashen?
brainmaster schrieb:Durch die erweiterte EXT4 tweaks dauert der erste Boot bis zu 5, 6 Minuten. Einfach ruhen lassen bis der Lockscreen kommt!
richyg schrieb:Der erste Boot hat bei mir keine Minute gedauert?!?!
Rom läuft flüssig, smooth, ohne Probleme, aber gefühlt nicht schneller als vorher.
Jetzt ist alles auf deutsch, trotzdem fehlen immernoch viele MIUI Features.
Eine Frage:
Kommt ab jetzt jedes Update per OTA?
brainmaster schrieb:Der erste boot beim full-wipe.
Ob es schneller läuft kann ich dir nicht sagen. Die apps sollen schneller starten.
Ich hoffe dass es mit der OTA klappt, obwohl die haben was bei der v4 geändert.
richyg schrieb:Nicht schlimm....wir werden es ja sehen, manuell ist ja auch kein Problem. Danke auf jeden Fall....
Hab übrigens immernoch das SMS Problem, dass bei neuen SMS kein BLN funktioniert. Habe folgendes beobachtet:
Bei normalen Notifications geht ja der screen NICHT an, sondern es kommt nur der Benachrichtigungston....in diesem Fall geht BLN, es blinkt. Bei einer SMS geht der screen an und bei Nichtberühren wieder aus, und BLN funktioniert NICHT!
Da gibts doch eine Systematik, dass das nicht funktioniert, oder? Irgend ne EInstellung?
Vielen Dank im Voraus!
frajo schrieb:Kann ich über 1.12.16 flashen oder brauche ich ein fullwipe?
Bondar schrieb:Bin mit dem Nexus S noch nicht ganz vertraut, hatte vorher ein Desire.
Wie bekomme ich die Verknüpfungen ala Themes/Einstellungen vom Hauptscreen gelöscht?
brainmaster schrieb:Wurde schon von mir geantwortet:
Deaktiviere dass automatische anlegen von Widgets im Market Einstellungen.
brainmaster schrieb:Standardantwort - versuche nur zu flashen. Wenn du Probleme merkst oder es läuft nicht rund, dann mache ein full wipe.
BM
frajo schrieb:Hat ohne Probleme geklappt und läuft seit gestern nachmittag geschmeidig.
Mir fehlt das 4-Way-Bootmenü. Ist das nur bei mir?
Superteilchen, Superjob, danke.
druzil schrieb:Dafür gibts die App "Quickboot" oder so ähnlich.
Edit: Die kommt bei dem Rom als Systemapp mit.
frajo schrieb:Schon klar, in BM's GB Miuis war das eingebaut, ohne App.
Genau so konnte man früher im eigenen Ordner die Symbole alphabetisch sortieren. Geht das auch nicht mehr?
