[ROM] Brainmaster's MIUI ROM
  • 812 Antworten
OTA Sent for 1.10.21, 1.10.28 and 1.10.28.1 ROMs.
RTL Fix can be separately downloaded and its not included since they separated the Hebrew from the Arabic-Persian version.
Included are the Extended Settings, 4-Way Reboot and Volume Skip mod.
Probably fixed the Signal loss and Radio Dumps bug, please report on this!
Theme still broken on some elements, since I'm waiting for the theme to be updated so that I can mod it.
Changelog:
Version 1.11.4:
MIUI Changelog:
Launcher:
  • Fix problems with the Sim Toolkit icon overlapping with other items
Themes:
  • Optimisation of the application, new font based themes will be prompted to restart phone
  • Fix problems setting ringtones through the system causing problems with FCs
Camera:
  • Fix problem in some cases the camera application freezes / hangs
  • Fix some issues with Camera silence when taking photos
Gallery:
  • Optimisation of video thumbnail loading speed
  • Fix in some cases third-party applications choosing to open via gallery for images causes FC
  • Fix in some cases when clearing gallery thumbnail cache, the cache is not cleared
  • Fix problem where gif animations are not loaded with the animation
Music:
  • Optimisation of WMA, APE encoding formats
  • Fix problem with file names containing punctuation, audio files unable to be played back
Backup:
  • Added support to backup local MMS
Settings:
  • Search optimisation settings, support for partial matched keyword searches
  • Removal of LED settings for Samsung models because these models do not have the LED function
Browser:
  • Optimisation of the default navigation pane layout, optimisation of switching screen orientation to give more usable screen space
  • Optimisation to significantly improve page zoom fluency
Update Manager:
  • Automatically sign-in ranking optimization, and better support for multi-language display.
Other:
  • Fix micro-channel audio card issues
My Changelog:
- Updated apps to the latest version
- Updated Market to 3.3.1.1 version
- Updated the DSP Manager app
- Removed SDX Stock App Removal, ROM Manager and ES File Explorer apps
- Replaced the three removed apps with the ROM Toolbox app
- Enhanced Web and Market browsing
- Probably fixed the Signal los and Radio Dumps bug (need feedback on this)
- Some small fixes and other things that I've forgot
Downloads:
1.11.4 Brainmaster MIUI ROM
1.11.4.MULTI Brainmaster MIUI ROM
Reaktionen: frajo und flying fox
Was macht das RTL Fix?
RightToLeft - für alle Arabische oder Rechts2Links Sprachen. Nicht für Europäische Sprachen wie Deutsch.
RTL = right to left... in Kombi mit o.g. Ländern könnte ich mir vorstellen, dass das die Richtung der Schrift bedeutet....(?)
edit: @Brainmaster war flotter - wie meistens :). thx!
funktioniert BLN trotzdem noch?
Habe mir heute morgen diese ROM draufgespielt und den STOCK Kernel behalten.
Ich muss sagen, dass ich super zufrieden bin!
Einzig, dass das Aufwachen in den Lockscreen minimal hakt, bin ich echt angetan.
Ob ich nun noch einen anderen Kernel einspiele weiss ich noch nicht, mal sehen, wie sich die beiden über die Woche vertragen.
Sollte einer von Euch aber mit einem anderen Kernel durchweg postives erlebt haben, bin ich ganz Ohr!
//EDIT:
Hab noch was.
Wenn ich angerufen werde, dauert es etwas bis der Display aufwacht, und hinzu kommt, dass er dann sofort wieder schlafen geht.
Habt ihr das auch?
Für alle, die es interessiert...
In der Brainmaster MIUI sind folgende Skripts enthalten:
Code:
01efstar
01sysctl
05modules
06defaulttheme
07internalsd
08dalvik
93tcp
94netsecurity
95zipalign
96nandtweak
97ramscript
98noatime
99tweak
Francos Kommentar dazu:
Code:
Shit... no wonder some users have problems with their
setups, too much  99omfgpwnscriptsthatfuckmobiledevicesmorethanhelpi  ng...
I'll give you a  sugestion, wipe that shit, reinstall the rom and then flash
the kernel,
probably takes less time than going over all those scripts
one by one [IMG]http://media.xda-developers.com/images/smilies/wink.gif[/IMG]
Jetzt meine Frage:
Der Kernel scheint ja nicht an diese MIUI angepasst zu sein.
Ergo frage ich mich, wieso er dennoch scheinbar gut läuft.
Kann es sein, dass wenn die Brainmaster weniger Skripte verwendet, der Kernel NOCH besser laufen würde?
//Nochmal Franco
Code:
- delete any script that contain remounting tweaks;
- delete any script that contain dirty_ratio, dirty_writeback etc tweaks;
- delete any script with minfree tweaks
Gibt es bei Brainmaster Skripte, die sowas enthalten?
Wenn ja, könnt ihr mir sagen, welche das sind?
OOmatrixOO schrieb:
Ich muss nochmal nachfragen. Hat jemand die neue Version von LBE Privacy Guard installiert?
Bei mir kommt es auf einer frischen Installation zu Bootloops. Irgendwas stimmt da nicht. Alle Rechte sind gesetzt.
Aber nur bei dieser Rom. Bei anderen funktioniert es ohne Probleme.
MfG
Hat niemand das Problem bzw könnte es mal testen? wäre für Hilfe dankbar.
MfG
Code:
01efstar
01sysctl
05modules
06defaulttheme
07internalsd
08dalvik
93tcp
94netsecurity
95zipalign
96nandtweak
97ramscript
98noatime
99tweak
Code:
the kernel,
Jetzt meine Frage:
//Nochmal Franco
Code:
Die enthaltene scripte verursachen keine Probleme. Die sind mit absicht unterteilt und durchdacht.
Francos Werte für minfree und RAM sind zu Aggressiv für mein ROM.
Also - einfach mein ROM installieren und dann Francos Kernel, brauchst du nichts anpassen.
Reaktionen: flying fox
MfG
Hey Matrix,
habe es auf dem kelLMSKing Rom drauf. Läuft 1a!
MfG
... eben getestet, shit, Dauer-Reboots, wie komme ich da wieder raus :cursing: :laugh: ...?
druzil schrieb:
Hey Matrix,
Ja ich weiß, habe es da auch probiert und es funktioniert, nur bei Brain seiner Rom nicht :scared:
Habe rausgefunden, wenn man in der Super User App das Rechtemanagement abschaltet, dann hören die Reboots auf :biggrin:
Hab sicher 20 Versuche gebraucht, bis ich schnell genug in der App war und den Schalter umlegen konnte. :cursing:
Also irgendwas stimmt da nicht in der Rom!!!
MfG
Das mit Superuser hatte ich mir gedacht, nur war ich nie schnell genug.... naja, wer sich hier herumtreibt, der muss flashen mögen, also alles neu :) - ich hatte noch das Pech, dass der Rom Manager nicht macht, was ich will, ich bekam bei meinen backups immer die Fehlermeldung, dass die Checksum-Datei fehlt. Kennt jemand das Problem?
Egal, diese ROM flashe ich immer wieder gerne :) .... stabil, schnell, spitzen support!
Darum hab ich immer ein Backup parart. ;) Aber nicht per Rom Manager, alles per Custom Recovery. Mit dem Rom Manager hatte ich auch öfter mal Probleme, darum ist der geflogen.
Aber das bringt uns ja leider nicht bei dem Problem weiter. Evtl kann sich ja Brainmaster mal dazu äußern. Vieleicht hat er ne Idee.
MfG
MfG
Würde ich gerne, allerdings weiss ich nicht warum es Probleme macht.
@Brainmaster:
bei den XDA´s hat sich gezeigt, dass die app "Google Talk", und zwar die Version v1.3 mit Videochat, Deep Idle verhindern soll. Dies hat sich bei mir auch bestätigt. Erst seit Deinstallation von Google Talk scheint Deep Idle auch wirklich zu funktionieren - ohne den "Trick" mit der Kamera. Vielleicht lässt sich in deinem nächsten Release diesbezüglich was machen. Die 1.3er Version ohne Video-Chat scheint diesbezüglich kompatibel zu sein. Nur so eine Idee.....
@Brainmaster
Ich habe NoLed als Stromfresser im Verdacht und den Eindruck, dass BLN deutlich genügsamer ist. Deshalb deinstalliere ich NoLed immer.
Gibt's diesbezüglich andere Erkennntnisse?
Wenn ich mich recht entsinne, ist NoLED nur für das AMOLED NxS, da bei unserer Version das ganze Display aktiviert wird und bei der AMOLED Version nur die Symbole die eingeblendet werden.
Quelle finde ich auf die schnelle nicht.
Reaktionen: frajo
OTA Sent!
Changelog:
Version 1.11.11:
MIUI Changelog:
Phone:
  • Fix problems with ringtones
  • Added automatically switch end of recording notice
Messaging:
  • Fix problems with MMS backup restore displaying items in correct order
  • Fix problems with Chinese attachment names could not be saved
  • Fix delivery reports repeated questions several times over
Camera:
  • Fix silence camera option problems
Music:
  • Fix problem setting ringtone, setting the ringtone is not displayed correctly
  • Quick fix in music pressing to return to music control interface, the menu displays the wrong information
Backup:
  • Optimisation of complete theme backup logic
  • Optimisation of online (Cloud) backup tips returning more useful error messages
Browser:
  • Optimisation of the default navigation page background and colour theme support system
  • Quick access to the first screen to optimize the two-state effect of site thumbnails
  • Access database fix leaks
System:
  • Fix problems with Bluetooth switching on / off, paired and connected devices are not visible
  • New MIUI Forum attachment support, push to phone to download (requires Xiaomi account to function)
Update Manager:
  • Optimisation of notification bar information, streamlining of details
Download Manager:
  • Optimisation of download only using Wi-Fi prompts and popup dialogues
My Changelog:
- Replaced Google Talk 1.3 with version without video chat (DeepIdle Bug)
- Mostly Bugfixes
Downloads:
1.11.11 Brainmaster MIUI ROM
1.11.11.MULTI Brainmaster MIUI ROM
