[ROM-AOSP GRJ22] Oxygen-2.1.6 (Latest gingerbread, clean & simple) (Update: 06.07.11)
  • 107 Antworten
O
Olli24689
Gast
Original-Thread bei xda-developers.com
About
Oxygen is an AOSP source built ROM (ie. not a mod of any sense based ROM), it's minimal, it's superfast and mostly bugfree.
As Oxygen is not a mod/port of CM or any other ROM and may not be to everyones liking, it's minimalistic and basic but I'm open to ideas and suggestions for improving the ROM.
Features
  • Android v2.3.5 (GRJ90) built from AOSP
  • Linux kernel v2.6.35.x
  • Minimal Google apps
  • Superuser
  • Busybox
Additional features
  • Adhoc wifi network support
  • Advanced power menu with reboot options
  • Customizable overclock settings
  • Customizable status bar power widget
  • Download any file type
  • Enhanced auto backlight settings
  • Facebook contacts sync
  • Headset Icon
  • HSPA Icon
  • Improved widget picker
  • Long press back to kill mod
  • Modified Launcher2 with quick uninstall
  • Optional battery percentage
  • SIP calling over 3G
  • Text reflow when zooming
  • Track change with volume buttons
  • Various other tweaks and features
Installation
A wipe is required when first flashing Oxygen, however, unless otherwise stated, no wipe is needed to upgrade between versions.
  1. Download update-oxygen-xxx-signed.zip to your sdcard storage on your HTC Desire
  2. Boot into ClockworkMod Recovery through whatever method you choose (ROM Manager, Power + Volume Up, ADB etc...)
  3. Back up your existing installation
  4. [First flash only] Use the volume keys and power button to select Wipe Data
  5. Select Install Zip from SD Card
  6. Find the update-oxygen-xxx-signed.zip file you downloaded earlier
  7. Scroll through all the No's and hit Yes, install update-oxygen-xxx-signed.zip
  8. Wait for the installation to finish
  9. Select Reboot
  10. After initial reboot, reboot a second time and you're all set
Downloads
I'm not responsible for any damage what-so-ever done to your phone, as with any ROM, you accept this risk.
Downloads are available below.
update-oxygen-2.2.2-signed.zip
Donate
Android development is a hobby for me, the Android community has been good to me and I enjoy what I do, I don't do it for any personal gain or gratification so if you like Oxygen and would like to show appreciation for the time and effort me and other people have put into it then I would very much appreciate it if you could donate to the 'childhood leukaemia' charity I support, you can donate via Paypal or by card/cheque, thanks for taking the time to read this and thanks for donating if you choose to .
Donate via Cancer Research UK
Credits
A big thanks to the following people, I couldn't of done any of this without you guys.
thalamus / schiznik / killkennys / tufkal
Additional thanks also goes to the following people who have made Oxygen possible.
Cyanogen, CM Team, jazzk, st0kes & everybody who has donated
Changelog
2.2.2 [25/08/2011]
  • Added black theme option to Messaging (requested by alot of users)
  • Added HD video recording to Camera (only for the SGS II at this time)
  • Added many new options to the Camera (courtesy of CM and CAF)
  • Added SMS split option to Messaging (this is to help users on CDMA networks)
  • Fixed Launcher2, now restarts on theme change
  • Fixed pinch-to-zoom in Gallery3D on the HTC Desire (may help with other older devices also)
  • Merged OxygenSettings into Settings
  • Reverted back to the old Android Market (the newer one was causing lots of problems for users)
2.2 [02/08/2011]
This is just a minor update to v2.1.5, there is only 2 changes, a minor bug fix due to a copy/paste fail on my part and a new screenshot feature ported from CM.
Screenshots can now be taken without the need for 3rd party applications, to take a screenshot, hold the power button and select screenshot, a screenshot will be taken and saved to your sdcard.
2.1.6 [05/07/2011]
  • Added screenshot to power menu
  • Fixed long press back to kill/ zoom button control
2.1.5 [04/07/2011]
  • Added 3 new predictive dictionaries
  • Added option to turn zoom buttons on/off
  • Added t-mobile theme chooser (no themes are included by default, download them and find them yourself)
  • Fixed shutdown bug when battery is low
  • Fixed signing signature boob
  • Removed updater
  • Reverted haptic feedback settings to stock values
  • Reverted oom killer settings to stock values
  • Updated kernel to netarchy v1.3.5
2.1.4 [18/06/2011]
  • Added CPU overclocking support to OxygenSettings
  • Added GRJ22 Google Apps incl. Talk2
  • Added option to hide status bar power widget indicator
  • Added support to constantly increase/decrease screen brightness depending on light conditions
  • Added support for Bulgarian & Croatian in LatinIME
  • Fixed bug which stopped some services restarting
  • Fixed call delay bug
  • Fixed wallpaper chooser Launcher2 bug
  • Fixed extra flashlight settings for status bar power widget
  • Fixed shutdown menu whilst in the lockscreen
  • Removed test keys
  • Signed release with custom keys to fix major Android security flaw
  • Updated APNs list
  • Updated busybox to v1.19
  • Updated su binary
Old changlog available here
Wichtige Oxygen-Links:
Twitter: @adamg_xda | Website | Issue Tracker | Wiki | Github
Gerade frisch gesehen, war eines der beliebtesten ROMs für das HTC Desire und wird nun seine Fortsetzung auf dem Nexus finden. :)
Reaktionen: frajo
Ich hab es jetzt vorhin raufgespielt. Es ist wirklich superschnell und vor allem eines: Kompakt! Keine Google Apps die irgendwie Performance fressen oder sonst was. Und endlich brauche ich das Gerät nicht wie bei anderen ROMs üblich, zu übertakten damit man etwas vom Geschwindigkeitschub merkt.
Bin mal gespannt wie es sich im Dauereinsatz schlägt. ;)
Mfg
Tapatalked with my Oxygen Nexus S
Neue Version mit Theme manager und weiteren Änderungen, ua. Update des Kernel erhältlich.
Kannst du ein Link für die neue Version geben oder ist das diese 2.1.4?
AdamG schrieb:
Latest test build: here
Changes:
T-Mobile Theme chooser now included (no themes are installed by default, you will have to find them)
Lowered haptic feedback to stock value
Lowered oom killer settings back to stock value
Updated kernel to netarchy 1.3.5
Hier der direkte Link zum Testbuild.
Hab nun auch Oxygen laufen. AdamG hat bereits Version 2.1.5 fur die nächsten Tage angekündigt. Man darf also gespannt sein :)
Habe mit dem letzten Testbuild in 11 Stunden bei wenig Nutzung, Internet & Sync an, smartass gerade mal 18 Prozent verbraucht. Denke kann man mit zufrieden sein.
Auch wenn ich mir weniger gewünscht hätte^^
Mal sehen, wie sich das 2.1.5er schlägt :)
Ist ja immer die Frage was man synct :)
Die Standard Google apps , G+, K9 (3 Konten via imap idle), gReader, Weather bug (4 widgets) jede Stunde. Twicca alle 10mins dazu dann noch Whatsapp, GTalk, BatteryGraph und Watchdog Lite als Service komme ich auf 1.5% im Idle pro Stunde.
Sehe erstmal keine Veränderung mit 2.1.5, wobei auch nicht soviel geändert wurde im Vergleich zum Testbuild.
Wenn ich mir deine Services anschaue, scheint bei mir nen richtiger Fresssack bei zu sein.
Das einzige, was bei mir synct sind Docs, Kontakte, Gmail, Picasa und Kalendar, von den Apps nur FancyWidget alle 2Std. sowie LP-Facebook-Widget jede Stunde.
Naja, mal abwarten. Die neue Version hat den Netarchy eingebaut, der war bei der Testbuild noch nicht drin glaub ich. Vllt. ändert sich da nochmal was.
wie sind denn die Erfahrungen hinsichtlich der Stabilität? Gibt es sporadische Abstürze?
Vielen Dank und viele Grüße
Handymeister
In der Testversion habe ich in etwa einem Monat 3x den Pin-Bildschirm gesehen, zweimal während des Browsens, 1x aus dem Idle. Keine ungewollten Reboots. Meine Ruckler die ich ab und an habe kommen eher vom Govenor als dem ROM denke ich.
Gesendet von meinem Nexus S mit der Android-Hilfe.de-App
Reaktionen: Handymeister
Ich verwende das ROM zwar erst 2 Tage, läuft aber recht stabil.
Hatte 1 spontanen Reboot, als ich die Voodoo Control App installiert und Musik laufen hatte. Ansonsten läuft es mit dem Governor smartass recht stabil - auf jeden Fall reagiert es schneller als CM7.
Lediglich als ich mal das OC bei 1,4GHz ausprobiert habe, ist mir das System mehrmals hintereinander abgeschmiert. Da ich beim normalen Gebrauch aber keinen OC verwende ist das mMn zu vernachlässigen. Kann es auf jeden Fall weiterempfehlen.
Na das hört sich doch ganz gut an :) Die Abstürze könnten am Kernel liegen, bzw. an den Fertigungstoleranzen der CPU. Bei mir läuft das Stock ROM seit Wochen auf 1,4 Ghz stabil.
Dann kann ich das ROM ja mal testen...
Handymeister
Es lohnt sich ^^
Denke es liegt am Kernel. Beim CM7 konnte ich auch die 1,4GHz halten ohne Abstürze. Der eingebaute Kernel liegt in Version 1.3.5 vor, wobei die letzte offiziell stabile Version 1.3.4 ist. Wie auch immer - das Teil rennt selbst mit einem GHz gut :)
So werde dann auch mal wieder zu Oxygen zurückkehren. Seitdem ich CM7 am laufen habe schwindet mein Akku in Null Komma nichts. Dabei hab ich relativ wenig installiert.
Werde berichten wie sich die neue Version bei mir schlägt. ;)
Mfg
Tapatalked with my Nexus S
2.1.6 verfügbar!
Die neuen Oxygen-Builds sind von nun an odexed, d.h. sie sollten schneller booten.
Außerdem sind zukünftig alle Informationen zum Oxygen-ROM im Oxygen Forum zu finden.
2.2.1 verfügbar.
