[ROM][[AOSP] Apex Custom Batteries, Network ADB, + MORE
  • 11 Antworten
Müllstein
Müllstein
Da ich noch keinen Thread hierzu gesehen hab erstelle ich einen.
This is a crespo build of my maguro ROM found here:
[ROM][GSM][AOSP] Apex v1.0.2: Custom Batteries, Network ADB, + MORE (2/1/12) - xda-developers
Apex rides again!
This is a generally stock ROM with mods chosen to add to functionality without detracting from the Ice Cream Sandwich experience that Google envisioned. I built this ROM from AOSP, merged in mods from CM9, AOKP, GummyNex, RootzBoat, and other ROMS, to create what I feel is a perfect mixture of stock feel and helpful customizations.
I had a lot of fun building, testing, and running this ROM. I hope you all enjoy it as much as I do!
Features
  • Built from AOSP source code - synced 12/31/2011
  • Stock look and feel with useful mods
  • Customizeable Lockscreen (2/4 targets, custom app for SMS)
  • Customizeable Notification Pulldown Widgets
  • Customizeable Search & Menu Softkeys w/ color control
  • Customizeable batteries (%, circle, bar, miui bar)
  • Customizeable Trebuchet Launcher (from CM9)
  • T9 Predictive (smart) dialer
  • Built in Perfomance Settings (a la SetCPU)
  • Rooted and busybox preinstalled
  • Facebook sync enabled
  • Advanced Power Menu w/ reboot and screenshot options
  • All apks deodexed/zipaligned/optimized
Credits
  • Google: for creating ICS and the AOSP
  • birdman: for CMDA build, proprietary files help, helping me fix camera effects
  • kejar31: helping me with the gapps, APM, auto restore fix, and more
  • CyanogenMod: Trebuchet launcher, back button app killer, T9, and more
  • paulobrien/romanbb: facebook sync fix
  • romanbb: nav bar color, sms custom app picker, volume controls, and more
  • rascarlo: custom boot animation and wallpapers
  • imoseyon: kernel pointers and UV control fix, provided kernel
  • jrummy16: Performance settings
  • xoomdev: navigation bar settings, clock controls, and more
  • syaoran12: customizeable batteries, miui bar, and more
And anyone I may have missed, thank you!
Changelog
v1-0-2
(common)
Added option to change carrier text in notification pulldown (reboot required)
Added gesture templates in Messaging app
Fixed volume stepping in applications while volume music controls were enabled
(maguro/toro)
Updated kernel to 3.0.18 imoseyon v1.8.0
v1-0-1
(common)
Sped up navigation bar key glow animations
Long press link in Browser now has an added 'Open in Incognito Tab' option
Fixed volume long press down music control waking up the phone
(toro)
Fixed GPS wakelock preventing some users from achieving deep sleep
Fixed busybox install script (it didn't install on the last build)
v1-0-0
(common)
Name changed to Apex -- it was about time!
Cleaned up customizations menus -- no more clutter in Settings main menu
New battery styles -- Stock, Stock w/ offset % (romanbb), Bar % (Gummy), Circle Battery, Hide Battery
MIUI bar battery -- 1 pixel bar representing battery percentage, color changeable
Color picker now includes HEX (for nav buttons, battery bar)
Rotation Options - 0, 90, 180, 270
Volume Wake -- cooperates with volume music controls
ADB Over Network -- wireless adb
Trebuchet update -- tons of animations
New boot animation by rascarlo
New wallpaper app w/ user submissions
(maguro/toro)
Updated Kernel to imoseyon latest 1.7.1 (modified ramdisk for network ADB)
(crespo/crespo4g)
Touch to focus in camera
Removed Nav Bar customization options
The remainder of the changelog can be found in the 2nd post
Requirements
  • GSM Nexus S
  • Clockwork Recovery
Screenshots
Instructions
  • Wipe data and cache! Just wipe cache and dalvik if coming from an earlier build.
  • Flash ROM file
  • Flash my GAPPs file immediately afterwards prior to rebooting.
  • Reboot
  • Profit
Quirks
  • Flashlight and 2G/3G Toggle do not work
  • Battery types sometimes don't change (just toggle back and forth until it does)
  • MIUI battery bar requires a screen toggle (on/off) to update after an orientation change
  • Using a nonstandard DPI will cause the softkeys to be off-center
Things to be aware of
  • Network ADB requires a ramdisk change -- if your kernel doesn't support it, please contact the dev!
  • If Facebook picture sync is not working after contacts have synced, please clear the application cache and data, sign in again, and it will sync.
  • Please allow the phone some time to sync initially (calendar, picasa, bookmarks, etc.)
  • If market auto restore gets stuck, a reboot should fix it
Downloads (hosting provided by Goo-Inside.me)
bigxie_crespo_Apex_v1-0-2.zip
signed_GAPPS-IML74K-010112.zip
c69411f679c082ebbfa5a2fb96e5f58e bigxie_crespo_Apex_v1-0-2.zip
56f817c0b597d8fc797dd28e71225734 signed_GAPPS-IML74K-010112.zip
All crespo builds
Source Code
bigxie -- Bitbucket
If you enjoy my work, consider buying me a beer :)
Donations FabDroid
Ich hab die ROM noch nicht ausprobiert, werde dies aber schnellstens nachholen, nach dem was ich auf xda so gelesen hab.
Leute ihr müsst die Rom unbedingt ausprobieren! Sie ist ein wahrer Traum. Vollste Empfehlung!
Was ist denn daran so toll? :p
Hast du einen vergleich zur Kangy o.ä.?
Ich hab davor die Kangy verwendet und Apex hat genauso viele Einsellungsmöglichkeiten aber eine viel bessere Performance.
Gleich mal ausprobieren. :D
Und wie läuft die Rom lohnt sich der Umstieg vom kangy Rom?
Gruss
Tony
Gesendet von meinem Nexus S
Gruss
Tony
Wahrscheinlich Geschmacksache. Hatte gestern nebenbei einmal ein paar Roms probiert, unter anderem wieder einmal CyberCR und eben diese hier - nach ersichtlicher Euphorie in diesem Thread.
Sehe von der Performance her keinen wirklichen Unterschied zu Kangy 11, und Codename Android (mein Favorit) hebt im Vergleich zu dieser hier ab - zumindest auf meinem Nexus. Aber Erfahrungen sind unterschiedlich. Im Quadrant Score (welcher bekanntlich ja nicht so viel aussagt) schnitt bei mir diese Rom (mit Abstand) am schlechtesten ab - dieser "Abstand" war aber im daily use nicht wirklich wahrzunehmen.... für mich letztendlich aber auch kein Grund ersichtlich, zumindest von CNA zu wechseln.
Reaktionen: .Tony.
[ROM][4.0.4][IMM76I] Apex v1.1.2: Back with a Vengeance! (5/8/12)
Changelog
v1-1-2
(common)
Updated to 4.0.4. IMM76I base
NEW Kernel built inline with ROM
Updated notification power widget drawables, fixed torch toggle
NEW Lockscreen customization - customize up to 4 additional targets (5 total inc. unlock) w/ activities and icons
Updated T9 dialer - no more slowdowns and crashes
Updated Trebuchet launcher - more mod options, adjustable homescreen grid size
Updated Messaging - support for emojis, custom vibration settings, and more
NEW Quick unlock - enable to skip pressing OK after typing in PIN/Password at lockscreen
NEW Device Control App - control screen colors, enable presets, and more low level mods
Updated GAPPS package - using goo.im "official" package, no more update/signature mismatch issues
(maguro/toro/toroplus)
NEW Navigation Bar customizations - pick and choose order, number, etc, with tutorial
Updated leanKernel to 3.5.0 stable
(crespo/crespo4g)
NEW CyanogenMod 3.0.31 kernel - OC up to 1400MHz, Voodoo support, deep idle, BLN
[ROM][4.0.4][Crespo] Apex v1.1.3: Features Keep Pilin' On! (5/13/12)
Changelog
v1-1-3
(common)
Bluetooth: AVRCP support for many players, MAP support
NEW Option to unlink ringtone & notification volumes (Sound Settings)
NEW Option to customize volume panel: single, expandable, expanded, none (Sound Settings)
NEW Quiet hours feature to set time span where phone doesn't interrupt you (Sound Settings)
NEW Statusbar brightness control: hold finger on statusbar and move to adjust brightness (Misc. Tweaks)
NEW Dialer advanced settings: vibrate on connect/disconnect, 45s, call waiting, option to turn on/off T9, hit name to dial
Fixed 2G/3G toggle
Updated NavBar: code cleanup, added big menu button option, button color option, option to hide navbar via APM
Updated leanKernel to 3.6.0: Linux kernel 3.0.31, gamma control, and more
(toro/toroplus)
NEW LTE toggle
(crespo4g)
NEW Wimax toggle
Schöne Bootani bei Apex :D:D:D
Nutze seit längerem die Slim ROM (aktuell 3.6). Wie schneidet denn diese hier dagegen ab? Die Slim läuft ja schon extrem gut und flüssig und hat ne Menge Einstellungsmöglichkeiten?
Läuft recht gut und sauber habe sie mal diese Tage getestet !!!!
  • lagloose
lagloose
forb'S
forb'S
forb'S
Hectic
AdO089
AdO089
