Adinoid
Enthusiast
- 1.104
Update v20 DOWNLOAD & CHANGELOG & BUGTRACKER!
Changelog
- new customizable lockscreen shortcuts
- pick your apps/shortcuts from ROM Control
- shows app icon on lockscreen
- long press on toggles to bring up settings menu (on the buttons, not text)
- new on/off icons for toggles/correctly spaced
- battery bar revamp
- animations while charging
- mirrored-center style for OCD folks
- ability to place it on your nav bar
- WebOS recents window toggle
- fixed volume wake and volume skip controls not playing to gether nicely
- ROM Control app revamped for tablets (no real affect for phones, but it looks nicer!)
- init.d scripts removed (init.d support still there)
- increased stock browser tab limit to 64
- added ability to disable boot animation
- added ability to disable bugmailer
Download it in the builds section. Remember to flash gapps!
after flashing build 20, you need to go into lockscreen settings and set an app for your second lockscreen icon or you'll only have the unlock icon!
