[Rom] Android Open KANG
  • 410 Antworten
*Eingangspost geändert*
genial :) nutze build 15 + GlaDOS 2.7
Sent from my Nexus S
Bin jetzt auch mit der 15 hier gelandet.
In den Euroskangs und in den Alfas von Kalim fehlen mir doch einige Einstellmöglichkeiten.
Läuft prima, smooth, keine Lags und sehr akkuschonend.
Bei mir mit dem Matr1xv14.
Neues Update ist seit gestern raus..
milestone 2 - January 10
Added toggle icons (thanks to MDJ & Virtuous)
Added custom hex input when picking a color for anything in RC
Added scrolling toggles for the alternate button style (thanks to ZB!)
Changed the way the statusbar drag handle works slightly so it is still centered when you lower your LCD density
Fixed init.d
Fixed clock not being allowed to be pure white
Update!!!
build 16 - January 12
WIPE REQUIRED WITH THIS BUILD DON'T COMPLAIN JUST DO IT
YOU MUST ALSO FLASH THE GAPPS PACKAGE!
Freshly re-written navigation buttons, completely re-arranglable/toggle-able!
New toggle-able quad lock screen option
Lock screen's SMS shortcut can be customized to an app of your choice (defaults to stock sms app)
Added volume wake option
Added volume long press to skip option
Added LED torch toggle
shortened nav bar animations a little
updated alternate toggle layout
tons of butter butter butter yes!
16a: include superuser
16a: smaller size due to not including files that are being flashed with gapps
Update!!!
build 17- January 13
fixed bluetooth drainage bug fixed lockscreen bootloop
new long press home action in ROM Control currently does nothing!
disabled landscape to avoid FCs in ROM Control for now added some padding for toggles (layout was slightly off before, yw OCD people) updated gapps package (includes updated G+ and stops my keyboard from being overwritten with Google's) - be sure to use the updated one
lad grad Build 17 :D Was ist Matr1x von dem ihr die ganze Zeit redet?
Ein Custom Kernel. Einfach mal im Thread nachschauen. Dort gibt es genug Infos dazu..
kann ich einfach auch über clockwork flashen? Muss ich was beachten? Ich würd jetzt mit titanium sichern dann wipe dann rom installieren dann gapps und dann den kernel und dann reboot. so kay?
Sagt ich kenn mich mit den kang´s nicht mehr aus. Jetzt muss ich einmal nachfragen: open kang ist das "Original" und die Kangy-Rom ein Mod davon? Habe ich das so richtig verstanden?
Ich habe mal testweise Kangy 6 geflasht, und nun open kang 17. Letztere hat ein paar features mehr, aber nennenswerte Unterschiede konnte ich nicht ausmachen. Habt ihr Unterschiede in Performance und Akkuzeit feststellen können oder ist eine Rom so gut wie die andere.
Ich selbst hatte recht lange die CyperGR laufen, ist halt CM mit den kang-features ("hybrid"). Diese Rom lief für mich vergleichsweise am besten, zumindest die Performance betreffend. Aber egal, ich bleibe mal bei der 17er hier, gefällt mir, wieder was neues auszuprobieren. Nur der Unterschied zwischen den Kangy´s würde mich brennend interessieren. Im web kann ich kaum nachsehen, muss ja ständig flashen :D
Ich blick das auch langsam nicht mehr,
bin weit davon entfernt ein Kang-Experte zu sein.
Das "Original" scheinen die Euroskang Kangs zu sein,
die werden wohl von nem Robot zusammengeschraubt,
so wie dann später bei den CM-Nightlies.
Euroskank CM Kangs - crespo
Da gibt es dann viele Funktionen noch nicht.
Nun gibt es einige Devs, die diese Grundversionen weiterentwickeln.
Was nu genau das RootsWiki "Android Open Kang Project" ist, weiß ich nicht.
Mal hat die eine Variante mehr Funktionen, mal die andere.
Man kommt ja mit dem Flashen nicht hinterher, ich habs aufgegeben
und bleibe erst mal bei den Kangy v's.
Reaktionen: flying fox
Neues Update!!
build 18 - January 17
  • bug fix: recents key sometimes not working
  • bug fix: toggles will restore original state on reboot (if they don't auto-hide)
  • bug fix: torch revamp, works great now! (Zaphod-Beeble)
  • bug fix: alternate layout will now center if there's nothing to scroll (Zaphod-Beeble)
  • bug fix: added mdpi & hdpi images for lockscreens (should fix crespo reboots) (Whitehawkx)
  • bug fix: nav bar not being spread apart like stock
  • bug fix: volume wake not always working
  • bug fix: camera effects should be working
  • added: battery bar with charging animtation and color option (CM and a little me!)
  • added: option to disable battery icon
  • added: sync toggle
  • added: octo lock screen (with 3 configurable apps) (Whitehawkx)
  • added: option to enable 180 degree rotation (CM)
  • added: ability to hide nav bar on lockscreen
  • added: google dns servers by default
  • added: built in performance/init.d configuration (thanks to Kejar & company)
  • includes awesome init.d settings
Reaktionen: blur
Ich mache hier mal mit der 18 weiter,
da meine Kangy-Installation zuletzt zuviel Akku zog.
Der erste Eindruck ist sehr gut,
es geht voran, schon wieder ein paar neue Features.
:thumbup:
Die 18 ist das Beste was ich auf dem Telefon bis jetzt drauf hatte.
Gesendet von meinem Nexus S mit Tapatalk
hatte eben ein hartnäckiges Problem mit Maps.
Wollte updaten: Paketdatei ungültig.
Das hatte ich schon lange nicht mehr ;)
Vielleicht bin ich ja nicht der Einzige:
Umgewidmet zur User Apps -> und Maps gelöscht
Maps ließ sich nicht mehr installieren.
Market Doctor laufen lassen Neustart:
Erst nach nem Wipe von Cache und Dalvik durfte ich die neueste Maps-Version holen.
EDIT:
Wer dann noch ne Verknüpfung von Maps zum Google-Konto braucht,
z.B. für eigene Layer,
muss in Titanium Maps zur Systemdatei deklarieren.
Gibt jetzt v19, ein kleines Update.
Changelog build 19- January 17 [OCD Edition]
[*]fix nav bar alignment with 4 buttons enabled
[*]really fix recents button sometimes not working
[*]init.d scripts disabled by default
[*]fixed octo/quad lockscreens not working with Lightflow
[*]don't show torch activity in recents window after using it
Danke für die Info. Auf jeden Fall ist diese Rom ein Hammer. Mit dem letzten update weiß ich gar nicht, was ich mehr will. Lockscreen, Status bar, sämtliche Einstellungsmöglichkeiten, einfach wow. Jetzt weiß ich nur nicht, ob ich dem speedy-5 noch eine Chance geben oder beim Matr1x bleiben soll. Mist, das Geflashe will nicht aufhören :D
