[ROM][13.04.2012] Brainmaster's CM9 & Black CM9 v2.0
  • 140 Antworten
brainmaster
brainmaster
Brainmaster's CM9 & Black CM9​
This ROM is based on Kalim's CM9 ROM (Thanks Kalim for letting me use it as a base for this MOD) and since I'm on it, I'll try to update it when the Kalim updates his ROM.
The ROM is themed with the Black Infinitum theme (thanks Razer) and contains my tweaks specially customized for the CM9 - can't be found anywhere else.
Inverted ICS Gapps are included.​
Installation:
Full Wipe needed:
- Go to Recovery: mounts and storage, and format /system, /data, /boot, /cache partitions (DON'T use my ROM Wiper tool, it doesn't work on CM9).
- Install the ROM.
Changelog:
Build v1.3:
- Initial Release
- Based on Kalim's CM9 v5
- Black Infinitum theme with Inverted 17.03.2012 Gapps
- Apex Launcher, Nova Launcher included
- Supercharged
- Brainmaster's Tweaks Special CM9 Edition
Build v2.0:
- Based on Kalim's CM9 v6.0
- Optimized Tweaks
- Added FaceUnlock and few Live Wallpapers
- Battery MOD included
- Black CM9 few more changes
Build v3.0:
- Based on Kalim's CM9 v7.0
- Few more Optimizations
Download:
Brainmasters CM9 v3.0
MD5: 8938084187deea571051093e080a4a55
If updating from v2.0 - Just flash, no need to wipe!
Brainmasters Black CM9 v3.0
MD5: e9c2ac009ecd317efe1375134c0e3364
OTA Updates:
If you want to get the notification for the new ROMs, updates over the Internet or Addons, Themes, Patches and Apps, you need to install this app. I also refer to this app as ROM Utility in my posts.
Reaktionen: Revollt, Psygen, flying fox und 3 andere
Addons:
- Stock CM9 Kernel for returning when flashing another kernel.
- Stock ICS Gapps - 17.03.2012. Install these if you want to keep the theme but don't want to have inverted Gapps.
- Inverted ICS Gapps - 17.03.2012. Already included in ROM. Includes inverted Calendar, Email, Gallery, Genie Widget, Gmail, Keyboard, MMS, GTalk, Market, Voice Search, Play Store and YouTube.
- Google Play Music - 4.1.513. It removes CM9 Music and installs Google Play Music.
- Minimal Icons Theme - install these to get the look like on the Screenshot.
- Minimal Launchers Theme - install these when updating the launchers. Launchers need to be installed as system apps.
  • GooglePlayMusic.4.1.513.zip
  • Minimalist_Launchers_CM9.zip
  • Minimalist_Icons_CM9.zip
  • CM9.v5.0.KalimochoAz.Kernel.zip
Reaktionen: flying fox und WxK
Benchmark - v1 with the stock kernel and stock speeds.
Default wallpaper:
Reserviert 4.
brainmaster schrieb:
Brainmaster's Black CM9​
Installation:
Full Wipe needed:
- Go to Recovery: mounts and storage, and format /system, /data, /boot, /cache partitions.
- Install the ROM.
Changelog:
:scared::scared::scared:
Warum nicht dein ROM-Wiper
Hat Probleme mit dem CM9 ROMs.
Bei mir bisher nicht.
Wer, wie auch immer. ;)
Ganz ehrlich? Dein ICS mit dem CM9 4.0.4 Kernel, was willst du mehr?
Der neue Kernel hat deinem Stock-ROM einen ordentlichen Schub gegeben.
Bringt dein Black CM9 nur Farbe/Design?
Wie läuft die ROM?
Halt CM9. MMN besser als Stock. Aber auch Geschmackssache.
pwner1144 schrieb:
Wie läuft die ROM?
Sehr gut.
Auch schön stabil? :)
Gesendet von meinem Nexus S mit Tapatalk
Kein circle battery? :crying:
v1.2 added - fixed issues with the gapps and market
Default wallpaper in post 4.
Also nach einem halben Tag testen:
- Apps Restore (TitaniumBackup) funktioniert nur teilweise
- Theme ist geschmackssache
+++ Soo smooth wie keine andere Rom !!
PS: Kann man bei dieser Rom das Standard-ICS Theme irgendwie wiederherstellen ? Ich komm mit dem ganzen schwarz nicht ganz klar.
EDIT: v1.1
EDIT: v1.1
Leider nicht, dass ist der Sinn der Sache - die Thema.
ok, das ist ein bisschen Schade ..
Ist das Restore Problem eigentlich schon gefixt ? Weil wie ich auf XDA gelesen habe, gibt es dort ein paar mit dem selben Problem.
Ich habe das Problem das ich nicht telefonieren kann. Kommt immer wieder der Fehler "Leider wurde Kontakte beendet"
Gesendet von meinem Nexus S mit der Android-Hilfe.de App
Du bist nicht alleine mit dem Problem ;)
Contacts App Patch for v1.2 in the OP - Contacts not inverted until I figure what is going on.
Reaktionen: frajo
Adinoid
Bodo
Bodo
brainmaster
Cubelix
Cubelix
forb'S
forb'S
forb'S
