[ROM][10 DEC][ICS ITL41F] NexusBeam HD - v2.1.1 | Clean,Smooth and Fast!
  • 120 Antworten
mike.bee
mike.bee
NexusBeam HD
NexusBeam 4.1.0
Hi guys, today i am announcing a brand new ICS based ROM for the Nexus S.
The ROM is using the latest stock Android 4.0.3 IML74K firmware and works very smooth! The UI feels very fast because Google implented HWcomposer in the latest build and this gives you overall speed improvements.
Screenshot time!
As you can see on the screenshots above, the stock ROM looks and feels great. Here is a Features list of the ROM:
Rom Features
-Android 4.0.3 (Ice Cream Sandwich) - official Samsung Nexus S GSM firmware IML74K
-Android 4.0.3 IML74K updater-script
-Stock kernel (linux 3.0.8)
-Removed software (CPU) rendering - full PowerVR SGX 540 (GPU) rendering
-This is an improved version of stock ROM - no visual changes!
-Very fast, clean & stable!
-Multi-language (WWE)
-Full Arabic and Hebrew languages support! (ICS feature)
-Fully optimized and tweaked
-ROOT (SU + SuperUser Permissions - Thanks to ChainsDD)
-Newest BusyBox
-RAM optimizations
-Speed optimizations
-Battery auto-calibration script
-Bloatware applications removed
-All system applications updated to latest available
-Zipaligned (Improved RAM management)
-Zipalign on boot (for user applications on data partition)
-Fully de-odexed
-init.d scripts (BusyBox run-parts) support
-Signatures hack
-Excellent battery life!
-..and many more!
Issues:
- Face unlock is pretty slow and doesnt recognize your face that well.
Download link [ROM]NexusBeam v4.1.0: Multiupload.com - upload your files to multiple file hosting sites!
Changelog und Downloads in den folgenden Posts.
Original XDA Thread
Reaktionen: crisb2411
Hallo Freunde,
hier eines der perfektesten ICS ROM's für euer SNS.
Schnell, stabil und echt stark. Bitte wiped alles mehrfach
vor dem installieren.
Download ROM
UPDATE ZIP zum entfernen der OnScreen Buttons
Features:
Code:
Rom Features
-Android Revolution HD™ 1.3.1 (GalaxyNexus rom) base
-Android 4.0.1 (Ice Cream Sandwich) - official Samsung Galaxy Nexus GSM firmware ITL41F
-Android 4.0.1 ITL41F updater-script
-steve.garon | SG-11UV 2011-12-04 ICS Kernel
-Newest BusyBox
-RAM optimizations
-Fully de-odexed
-Signatures hack
-..and many more!
Issues:
- Video codecs
Changelog:
Code:
NexusBeam v2.0:
- Fixed Audio in Calls
- Fixed Microphone in Calls
- Fixed video-recording
- Speed improvements to kernel
- Some bug fixes
- Probably fixed some WiFi related issues.
NexusBeam v1.1:
- New lib's for Nexus S
- New kernel
- Fixed Camera (still photo's)
- Fixed Facelock
- Added Google Maps.
Screenshots:
Benutzt zum übertakten das Tool NSTools / Mirror
Will dich nur darauf aufmerksam machen das es einen Thread zu dieser ROM schon gibt. Siehe HIER
Reaktionen: Nexus S
Sorry :D Ich war schneller xDD
mike.bee schrieb:
Original XDA Thread
Habe es gerade versucht zu testen, hing aber am android Bootlogo fest. bei xda meinte ein user, dass es am kernel liegen könnte. Also einfach mal einen anderen flashen, falls bei euch das selbe problem auftaucht. Ich mach mich jetzt erstmal auf ins bett :D
Also das Problem hatte ich auch, als ich direkt nach dem flashen den "no onscreen keys" mod geflashed habe. Wenn ich zuerst die Rom an sich geflashed und dann ein mal gebootet habe, gings dann auch mit dem mod.
Aber irgendwie ist die ROM ein bisschen laggy im vergleich zu anderen ICS ROMs. also bei mir zumindest. Und apps wie "Gnar Bike Trial" funktionieren auch nicht (funktioniert bei der Drew Garen ICS).
Aber ich lass sie jetzt mal drauf bis morgen.
ja habs dann auch so gemacht und es hat funktioniert
.Tony. schrieb:
Lustig.....
Hier ist es aber übersichtlicher, :):)
Getippt vom Nexus S
na dann erfreu dich an diesem thread. Hab eigentlich bloß alles aus xda kopiert :)
Schön dass es hier auch Humor gibt! :D
Wie sieht es aus mit den apps, sind die alle kompatibel?
Getippt vom Nexus S
Hi
Link für die update zip geht nicht!
Getippt vom Nexus S
Reaktionen: Nexus S
Hat schon jemand versucht NStools aus dem Market zu installieren? Bei mir kommt die Meldung, dass die App nicht kompatibel sei.
Bei mir gings! Ich Habs auch aus dem market!
Habe das Problem, dass bei der Beam 2.0 die normalen Buttons immer mitleuchten. Ist das vielleicht eine Einstellungssache oder habt ihr auch dieses "Problem"?
Edit: Habs gefunden. In NS Tools den Backlight Dimmer runter gesetzt. Mit der Off Funktion hatte es nicht geklappt.
danke für den hinweis druzil, dass gleiche problem hatte ich auch mit dem backlight, ansonsten finde ich diese rom sehr gut.
jedoch kann ich nicht alle apps aus dem market installieren, liegt dieses an der rom oder allgemein an android 4.0?
Manche apps sind noch nicht kompatibel.
Wie installierst du? Aus einer backup-app, die in den market verlinkt?
Bei mir ging es ohne Probleme. Im market danach gesucht, gefunden, installiert und geöffnet.
wiesi_at
richyg
forb'S
forb'S
forb'S
kripparon
kripparon
