[ROM][5.0.2] crDroid [UNOFFICIAL][2015.03.21]
  • 23 Antworten
PeterImmel
crDroid (Official Support page) / crDroid Google+ Community von Cristiano Matos
xda-Thread
Download:
AndroidFileHost
(Gapps)
Screenshots | crDroid Android
Funktionen:
  • Nav bar tweaks (on/off toggle and custom dimensions);
  • Battery text mode (from cm);
  • Battery icon options (from cm);
  • Media scanner behavior on boot;
  • HSPA + icons on status bar;
  • SlimRoms heads up customization;
  • Traffic metter on status bar;
  • Gesture lockscreen;
  • Gesture anywhere (launch apps and activities from custom gestures);
  • Weather display on expanded status bar;
  • Wakelock blocker;
  • Left handed navbar option;
  • XuiMod toast animations;
  • AOKP custom system animations;
  • App circle sidebar;
  • CPU info overlay option in development settings;
  • [Connect/disconnect notification support;
  • Long click support on quick settings;
  • Screen recorder;
  • Animated rotation tile;
  • Wake up on plug;
  • Development shortcut;
  • Performance settings from CyanogenMod;
  • Clock and time clickable in expanded status bar;
  • Notification ticker;
  • Quick unlock;
  • PIN keypad shuffler;
  • Custom lockscreen shortcuts;
  • Answer calls with hardware home button;
  • Status bar clock tweaks (right, center or hide clock with many dates formats to show. Custom colors included);
  • Notifications counter;
  • Volume keys wake the device;
  • Ability to hide the alarm clock icon from status bar;
  • Dialer Lookup;
  • Profiles form CyanogenMod (new merges and lollipop style);
  • Protected apps (using trebuchet launcher);
  • Filter spam notifications;
  • CyanogenMod SuperUser;
  • Clear all button in recent panel with custom option (hide, top right or top left);
  • Disable search bar in recents;
  • Privacy guard from CyanogenMod with new Superuser access through it!!!;
  • Ability to hide superuser status bar icon;
  • Quick settings pull down with one finger (right, left or off);
  • Smart pull down;
  • Configurable 0, 90, 180 and 270 degree rotation;
  • Toggle to not allow quick settings on secure lockscreen;
  • Brightness control through status bar;
  • Double tap status bar sleep;
  • Data activity indicators;
  • Call blacklist support;
  • Increasing ring tone;
  • In call vibrations;
  • Advanced reboot menu;
  • Option to hide adb notification;
  • Screen shot quick delete with confirmation;
  • Long press back to kill with configurable timeout;
  • Volume button custom actions (skeep track, wake screen, adjust sound and keyboard cursor control and swap volume buttons);
  • Less frequent notifications sound;
  • Advanced keyboard features (auto rotation with timeout, disable full screen, selector notification, show enter key, volume key cursor control);
  • New Eleven music player and AudioFX from CyanogenMod;
Installation:
1. crDroid & Gapps (PA-Gapps zum Beispiel) herunterladen
2. In die Recovery neustarten
3. Wipe Data / Cache / System & Dalvik Cache
4. crDroid.zip installieren
5. Gapps.zip installieren
6. Neustarten
Wie siehts mit bugs und der Akkulaufzeit aus? :)
Akkulaufzeit: Ich bin sehr zufrieden....(benutze den XPerience-Kernel)
Bugs: Ich hab keine. Aktuell berichten einige User auf xda, dass das Moto G keinen Standort findet, wenn auf "Nur Gerät" eingestellt ist. Aber ich glaube, Cristiano Matos ist dran...
Reaktionen: peterpopel
Hat glaub ich echt potential die ROM vor allem hover ist ja cool xD...
Gibt es das bei anderen ROM auch?
so, jetzt der Startbeitrag auf Deutsch.
Ich hoffe, so noch mehr für diese Rom begeistern zu können.
Reaktionen: Randall Flagg
Heute ist Build 17 erschienen.
Ich hab im Startpost mal die Screenshots entfernt und ein Video hochgeladen, das die Rom ein bisschen vorführt....
die stabilste ROM aller Zeiten ist mittlerweile bei Build 21 angekommen...
...und muss auch mal wieder gepusht werden ;) sorry
Customisable location tile (native from cm but it’s a good feature)
ist eines der neuen features, das ich sehr begrüße.
Dirac HD sound support (go into DSP manager)
dürfte was für die sein, die viel Musik hören.
läuft GPS bei jemandem von euch?
hab zur zeit zwar Paranoid Android drauf hatte aber noch nie bei einer CR GPS :/
Hab auch schon versucht die NON-HLOS.bin zu flashen!
ich hatte nie Probleme mit GPS.
Ich muss aber auch dazu sagen, dass ich mittlerweile immer gleich den XPerience-Kernel drüber flashe, wenn ein neues crDroid Build erscheint.
(wegen dt2w vor allem)
selbst mit xperience tut sich nichts..
hast du zufällig bevor du crdroid geflasht hast, ein downgrade zur factory rom gemacht und hast kein GPS Fix gemacht?
Ich hatte das Problem mal.
das kann sein..
ich hab schon öfters gelesen dass leute zu stock geswitcht haben nur für einen gps fix.
aber ohne data wipe wird das nix oder?
bzw mach ich generell auch format /system
Ja zu stock geht nur mit Wipe.
Normal muss system nicht gelöscht werden.
ja genau.
funktioniert gps bei dir mit anderen ROMs?
Wenn ich das richtig verstanden hab und der nicht durchgeführte GPS Fix in der Stock Rom das Problem ist, dürfte GPS in keiner ROM funktionieren....
Ansonsten liegts wahrscheinlich an was anderem
so, das heutige Update ist, finde ich, eine Erwähnung wert:
crDroid-4.4.4-20141029-OFFICIAL-falcon -> Download
– Synced with all CyanogenMod sources (build date);
– Dynamic system bars from AOSPA;
Dynamic system bars wurde vom Paranoid Android Team "erfunden".
Man kann jetzt also einstellen, dass sich die Statusleiste und/oder die Navigationsleiste farblich der gerade ausgeführten App anpasst.
ich finds toll!!!
so, wohl eines der letztes/das letzte crDroid-Build basierend auf KitKat:
crdroid-4.4.4-20141122-falcon
(Gestern hat Cristiano Matos das erste crDroid-Alpha-Build für das Nexus 5 basierend auf Lollipop veröffentlicht.)
Hallo zusammen.
Bin seit gestern mit der crDroid unterwegs und muss sagen, dass sie mir sehr gut gefällt.
Aber ich hab ne Frage. Benutzt ihr einen anderen Kernel? Wenn ja, welchen?
Ja ich benutze den DK Kernel v. 2 - läuft super
Einzige was mich hier an der ROM noch minimal stört sind das Handling der lockscreen notifications, ist bei lollipop doch besser gelöst. Ansonsten rundum happy Paket :)
RAM management ist auch der Hammer - music + game ohne probleme möglich + browser tabs werden nicht geschlossen.
:thumbsup:
So, hab den thread hier mal von 4.4.4 auf 5.0.2 "hochgehieft".
Ich hab crDroid Lollipop jetzt seit etwa Anfang Dezember laufen. Läuft echt super. Bei der aktuellen Version(15. Januar '15) muss man beachten, dass man einen anderen Kernel flashen muss, wenn man eine (auf Dauer) funktionierende Kamera haben möchte. CyanogenMod hat da irgendwas verpfuscht und crDroid basiert ja darauf. Den Kernel findet ihr im AndroidFileHost-Ordner(siehe Startpost).
Reaktionen: Cua
Habe bisher nur die Screenshots gesehen. Nun mal 2 Fragen : Kann man das Einstellungsmenü auch mit schwarzen Hintergrund einstellen? Dieses Weiß ist auf Dauer sicher lästig, Lässt sich die Rom gut personalisieren, ohne zusätzlich xPosed zu installieren?
Sunny
Sunny
Sunny
DrRammel
DrRammel
DrRammel
DPX
meistadieb
