[ROM] [4.4.4] [UNOFFICIAL] Mahdi-Rom
  • 10 Antworten
PeterImmel
Ich weiß: Das ist jetzt schon die dritte ROM, die ich hier poste. Eigentlich dachte ich, dass es nichts besseres als crDroid gibt. Jetzt gibt es aber seit zwei Tagen die Mahdi-Rom. Weil ich so begeistert von dieser bin, möchte ich sie mit euch teilen:
Alberto97(xda: Stand: 13.08.2014) schrieb:
timthumb.php
Code:
[CENTER][B][COLOR="Red"]Your warranty is now void.[/COLOR][/B]
I am not responsible for bricked devices, dead SD cards,
thermonuclear war, or you getting fired because the alarm app failed. Please
do some research if you have any concerns about features included in this ROM
before flashing it! YOU are choosing to make these modifications, and if
you point the finger at me for messing up your device, I will laugh at you.
A lot.[/CENTER]
Download Link HERE
Mahdi Theme: HERE
Installation instructions
Installing Mahdi-Rom for the first time, or coming from another ROM:
-Requires Unlocked Bootloader & CWM (or another custom recovery)
1) Place ROM & Gapps in your virtual SD
2) Reboot in Bootloader Mode
3) Go to "Recovery" (Vol -) and confirm (Vol +)
4) Select (Vol +/-) "Wipe Data/Factory Reset" and press Power button | For a clean
5) Select (Vol +/-) "Yes - Wipe all user data" and press Power button _| installation
6) Select (Vol +/-) "Install Zip", "Choose zip from /sdcard"
7) Go where you placed the ROM zip, select it and confirm
8) Re-do 7 and 8 with Gapps zip
9) Now "reboot system now"
- Don't restore system data using Titanium Backup!
Upgrading from an earlier version:
- Copy the ROM ZIP to your SDCard
- Boot into Recovery
- Flash the ROM zip from SDCard
- Reboot
Settings menu
Sound
- DSP Manager (Music Effects)
- Quiet hours
- Ascending ringtone
- Volume panel timeout
- Less frequent notification sounds
- Control volume adjust sound
- Launch music app on headset connect
- Control safe headset volume
- Power connect notification control
- Apollo as Default Music App
- Volume steps
- Volume rocker music controls
- Volume default
- Volume adjust sound
- Reorient volume buttons
- Safe headset volume
- Power sounds
Display
- Advanced auto brightness control
- Advanced wallpaper control
- Full rotation control including lockscreen
- Screen record with audio
- Notification LED Control
- Battery LED Control
- Wake up device on plugin/unplug
- Double-tap to wake
- Adaptive backlight
- Screen color
Security
- Variable size pattern unlock
- Pin keypad shuffler
- Lock before unlock
- Privacy guard
- Blacklist
Languages & input
- Auto keyboard rotation
- Disable fullscreen keyboard
- Selector notification
- Volume key cursor control
Developer options
- Advanced reboot
- Enable Quickboot mode
- ADB over network
- Development shortcut in recent apps list
- Show cpu info
- Change device hostname
Themes
- Dark-UI
- CM11 theme engine
Customization menu
Navigation
- Hardware button options
- Disable hardware buttons
- Pie Navigation
- Navbar Options
Status bar
- Clock and date customisation
- Battery customisation
- Battery bar
- Show battery status percent
- Notification count
- Network speed indicator
- Statusbar brightness control
- Double tap to sleep options
- Immersive mode
Panel settings
- Notification drawer options
- Background style options
- Quick pulldaown
- Smart pulldown
- Show smaller tiles
- Flip tiles
- Tiles and layout options
- Dynamic tiles
Notifications
- Heads up
- Enable notification reminder
- Lock screen notification options
- Peek
Multitasking
- AOSP recents
- Slim recents
Power menu
- Profile switcher
- Immersive mode
- Screenshot
- Screen record
- On-The-Go Mode
Lock screen
- Targets customisation
- Battery level on lock ring
- Slider Torch
- See through settings
- Style customizations
- Maximize widgets option
Animation control
- Screen off
- Toast
- System
- Listview
- Scrolling
- Keyboard
- Progress bars
Shake Events
- Shake sensitivity
- Keyguard
Driving mode
- Incoming call
- Read new message
- Battery full indicator
- Connect charger
- Disconnect charger
- Clock
- Date
- Music Track
- Notification
- Read new notifications
- Included apps
- Less frequent speak notificatons
-HERE
-DEVICE TREE
-HERE
-Mahdi-Rom (Mahdi786) Without this awesome DEV we would not have what you see here! Make sure that any donations go to this DEV!
-dsmitty166 for OTA and helping build this amazing ROM!
-Mouzey for his Custom Boot Animation 2 HERE Preview HERE
-Cyanogenmod
-Paranoid Android
-Slim ROM
-Omni ROM
-ChameleonOS
XDA:DevDB Information
Mahdi-Rom 2.7, ROM for the Moto G
Contributors
Alberto97, dhacker29, razrqcom-dev-team, Intervigilium, Team Mahdi
ROM OS Version: 4.4.x KitKat
ROM Kernel: Linux 3.4.x
Based On: AOSP
Version Information
Status: Beta
Created 2014-08-12
Last Updated 2014-08-12
In Verbindung mit dem The-Green-Machine-3.0.0-cmvariants.zip - Kernel ein absoluter Traum.:thumbsup:
Reaktionen: Mammutjäger und joshua1996
Also erstmal ist esmeiner meinung nach gut, das du hier ein paar Interessante Roms postest. Werden hier ja nicht so viel vorgestellt:D Also ruhig noch mehr Posten.
Dann hätte ich noch zwei Fragen, die wären, läuft die Rom gut?
Und wie ist die Akkulaufzeit?
Meine Begeisterung ist in der Schnelligkeit und Ausdauer begründet. :tongue:
Hatte bis jetzt ca. 4-5 Roms auf meinem Moto G und mit keiner läuft es so gut.
Und GPS sieht auch gut aus ;)?
Funktionieren tuts. In der Praxis habe ich es bisher aber nur mit Google Maps angewandt.
Wie gut, weiß ich nicht.
Ist das gut? (Screenshot wurde nicht unter freiem Himmel gemacht, sondern in einem Dachgeschoss.)
(GPS: Einstellung: Nur Gerät
Reaktionen: peterpopel
Bin auch seit ca. 2h auf Mahdi-Rom. Läuft richtig gut mit dem smooth-scrolling-Mod und dem Green-Machine Kernel.
Bisher keine so Feature-Beladene Rom gesehen die so gut läuft. Beim einrichten hatte ich allerdings 2x für 10sec neun Freeze, sonst alles Prima.
Akku kann ich noch nix zu sagen, hab mit 39% gelfasht und nach 45min DOT war der Akku dann auf 27%. Scheint also OK zu sein, wird sich aber wohl noch einpendeltn
Smooth scrolling mod? Was macht der? Hab davon nie vorher gehört
Flüssiger wird es bestimmt sein, denke eher weniger das eine zip zum DL freigegeben wird die rein gar nichts bewirkt ^^ Ich probier die Rom dann auch mal aus.
Zips die nix bewirken habe ich schon mal gesehen, nur beim Xperia U damals. Ist halt genauso wie manche auf init.d-Scripts, V8-Supercharge zu Akku sparen oder untertakten.
Muss man einfach gucken, habe den Mod aber auch schon 10min nach dem flashen drauf gemacht, also weniger subjektiv.
Was den Akku angeht, ich bin jetzt bei 38% und habe grade mal 1h 20 DOT. Über Nacht im Flugzeugmodus 2% verbraucht und in 10min dannach auf einmal 15% weg...
Entweder pendelt es sich in den nächsten Tagen ein, oder ich werde wieder auf Paranoid Android wechseln, da kam ich immer auf min 3h DOT, egal was für ein gebraucht. (und wirklich viel habe ich jetzt nicht mit Mahdi gemacht, Whatsapp/Google+/Facebook, 10min Telefonieren und permanent WLAN)
Bei 12h habe ich aus versehen auf Verlauf-Löschen gedrückt sodass die 5h nicht stimmten.
Sunny
Sunny
Sunny
DrRammel
DrRammel
DrRammel
DPX
meistadieb
