guenter1
Stamm-User
- 355
So viele lesen hier wohl nicht mit. Das wird sich hoffentlich legen, wenn es eine offizielle CM 14(.1) geben wird.
Quelle:Squid Kernel r18
I have a new kernel build for you. Apologies for the delay, I have just had a very busy past few months. This build doesn't bring any exciting new features, but given the long interval since the last release and the sheer number of commits in it from the security updates and harpia support, I decided to bump the major version number.
Be aware that today's r18 release is still MARSHMALLOW ONLY. A Nougat compatible version will be coming soon (along with CM14.1 for devices that haven't yet received it from me).
N008 schrieb:Hoffentlich wird das nicht zu unübersichtlich mit all den ROMs von verschiedenen Maintainern…
Official CM14.1
Official builds will come once I verify everything is up to standard and approve the builds. I have had limited free time over the last few months, but I'm going to try to get things in order this week. While I can't promise anything right now, I'll probably be moving nightlies over to CM14.1 some time before the end of this month.
Lenneth schrieb:- Die Galerie funzt bei mir nicht, das Prog hängt, jedoch nicht das Gerät. Wurde afaik ja schon geschrieben und man kann Alternativen (?) nutzen
