[ROMs] iceandfire (Froyo + Gingerbread)
  • 70 Antworten
sk92le
sk92le
und wieder etwas Neues für uns Meilensteiner ;)
[ROM] iceandfire V1.0 [10.12.24]-Milestone - xda-developers
It is built from cyanogen port from kabaldan. Synced on 19/1/11
Changes (19-1-11)
Updated from nadlabak sources
New kernel
Battery life fixed finally
wifi scan=150
new theme (thanks to loveboatcaptain)
Changed gingerbread launcher (replaced with the real one)
memhack script added
new keyboard added
LED notification light fixed (can be changed from CM menu)
adb added (checking required)
themed facebook,etc
DSN fix added
Fully zipaligned
new bootanimation
Fix GPS google servers
Changes (2-1-11)
Re-sync with latest nadlabak resources
Kernel updated
battery life fix
wifi.supplicant_scan_interval = 100 (saves battery life)
mot.proximity.delay=250
includes miui music app (Thanks to miui and lalit79)
battery top charge level fixed
updated WLAN driver
updated Gingerbread theme
under-clocked from 950 Mhz to 900Mhz (Performance same)
Removed some more bloat-ware (apps) - increases performance!!
Mods and tweaks-
AOSP Music/MusicMod 1.75.2 Built from Eliot Stocker source
ADBD-on boot
DSN-Fix
Reboot Menu in PowerMENU (with reboot to recovery, normal or bootloader)
Dalvik heapsize: 40m--dramatically improves performance!
windowsmgr.max_events_per_sec=60-> scrolling is smoother!
Hacks in media_profiles.xml(thanks to 89luca89):
Hack recorder at 30fps
hack bitrate audio / video
Camera Hack ---> Compression set to 100 (no compression) and increased memory footprint, the picture gains! (And thanks to the new gallery seems a different story!)
4 POINT MULTITOUCH SUPPORT FOR MILESTONE- abilited by a little hack in build.prop
media_profiles.xml adjustments (safer high camcorder profile h264 bitrate) + small camera fixes (sounds etc.) (thanks to kabladan)
- small agps fix (issue 295) "
- multitouch.distinct defined (fix Google Maps 5.0 rotation gesture etc.) "
- bluetooth discoverabilty timeout configurable (thanks H.Czedik) "
- modversion change to easily distinguish current build "
- etc.
- AAC and AMR Wideband audio encoders are finally working! "
- additional video quality camcorder profile added - "middle" (customize it in /etc/media_profiles.xml) "
- Camera app - fixed encoder change from UI not being used until camera reinitialization, camcorder shortcut added "
- adjusted smartass governor defaults "
BOOT SCRIPTS (thanks to 89luca89)
The script that will start to boot, are located in the /system/etc/init.d, and are simple script with no extension (info for whoever want to add / edit the script)
1-Sysctl-support tweaking the kernel! instead of creating a script where you write tweak using "sysctl-w" now using "sysctl-p" reads the sysctl.conf file in /system/etc
2-Memhack-displacement Dalvik cache in /cache, a lot of free space in /data and in combo with the app2sd Froyo, almost does not feel the need of app2sd (with ext2)
3-KernelTweak-Tweaking much things
zpa Zipalign automatic all-System apk to boot!
4-Overclock-overclock the cpu
_adbd_during_boot-adbd to boot the adb shell directly as root! (updated)
Comes with original gingerbread 2.3 theme!! (Credit to me)
Removed lots of bloat-ware to make it fast and smooth!!
Lots of other tweaks under the hood!!
Installation:
-Use Androiliani Open Recovery. Download the file for it, put it in the /sdcard (i.e. root of your SDCARD) - Download the latest iceandfire image. Put it in the /updates/ of the Open Recovery folder on your sdcard. - Open normal recovery [different versions have different methods of opening Normal Recovery and Bootloader (SOMEONE ADD?) and choose "apply update.zip". You will enter Open Recovery. - MAKE A NANDROID BACKUP if you are leaving a different ROM or if you are leaving a ROM in which you made LARGE changes or installations and you are uncertain of the stability of the coming ROM. Keep a copy of the NANDROID backup away from you phone, on your computer. - data wipe/factory reset is highly recommended when you are upgrading from another rom/firmware. Just wipe Dalvik and Cache (from Open Recovery). - use OpenRecovery Apply Update menu to install the zip copied to /sdcard/OpenRecovery/updates - the included RIL files are for the European frequencies, if you are in Canada, US, Lat Am or Thailand, you will need to replace them to get 3g working - if you are in France, you should replace ro.product.brand=MOTO_RTEU with ro.product.brand=MOTO_RTFR in /system/build.prop (the ap_gain_france.bin will be used then)
Important:
Please, use the new OpenRecovery 1.46 for installation.
The Androidiani OR has been updated to be based on 1.46 (in version 3.3), so it's recommended too.
Non European radio files can be installed from menu in Androidiani OR.
Download-
Code:
http://www.multiupload.com/5T2GHA2FVL
Google Apps should be download from here-
Code:
android.d3xt3r01.tk/cyanogen/gapps/gapps-hdpi-20101114-signed.zip
New market (2.2.7) for iceandfire rom (Thanks to HO!NO!)(I did a little modifications to his market update)
Download this update file new_market.zip and traditional_market.zip
copy them in openrecovery update folder
Go Settings > Applications > Manage applications and click on the Running tab.
click on Google service framework, Force stop it and clear data and cache
go back in all tab and click on market, do the same (Force stop clear data and cache.
reboot in recovery
install traditional_market update
wipe dalvik cache and cache
reboot
open market (accept User Agreement) close program (do not wait for program to open)
reboot in recovery
install the new market update
reboot
and now you should have the working new market 2.2.7!
Code:
http://www.multiupload.com/8D15P4WBIQ
http://www.multiupload.com/QA9BJHOS90
Theme pack-
Note- Install ADW launcher to use these.
Package includes-
1. tron
2. gingerbread
3. gingerbread blue
4. MIUI
5. Symbian
Ill Update more when i get'em!!
http://www.multiupload.com/YVQF4UQRCI
Hast du's schon ausprobiert? Wenn ja, wäre ich über ein paar Screenshots sehr erfreut!
noch nicht... ich hau es mir gleich drauf ;)
Moin! Und, schon getestet? Tut es?
Moin!
Würde mich auch interessieren. Bitte mal feedback geben :)
laut changelog nichts besonderes oder habe ich was übersehen? der gibt multitouch an doch war das im letzten cm6 doch auch auf 4 oder nicht. in meinen augen lohnt sich das nicht weil man das alles selber machen kann.
Sind doch in dem original Thread zu sehen ... :huh:
Es ist in meinen Augen ein Mix aus FroyoMod und CyanogenMod ...
Ich bleibe ersteinmal dabei, denn laufen tut es auch ganz gut vom Speed her,
ich bin mal auf die Akkulaufzeit gespannt welche ich jetzt beobachten werde.
Sind diese FroyoMOD und Cyanogen-Menüeinträge beide mit drin?
also Cyanogenmod ist auf jedenfall bei Einstellungen drin und FroyoMod kann ich dir nicht sagen, ich hatte FroyoMod noch nicht im Betrieb
Ja dann soll er die hier posten. Ich bin bei XDA devs nicht angemeldet...
der hat das 2.3er theme eingebunden wegen des aussehens.
[OT]
Und dann soll er Dir die Arbeit abnehmen, nur weil Du keine Lust hast Dich bei XDA an zu melden!??! Warum ... ??? Die Bequemlichkeit anderer muss man ja nicht auch noch fördern ... :glare:
[/OT]
Kannst es einfach ueber dein cm6. Patchen, so hab ichs gemacht und bis auf etwas andere slides als im gingerbread theme und ne bischen andere farbgestaltung der bar seh ich jetzt kein unterschied mal akku testen.
Gruss
was ist eigentlich 4 Point multitouch kann man dann 4 Felder des Displays berühren?
Multitouch tester app im market mal runterladen, also auch mit cm6 hatt ich nicht mehr als 4 gleichzeitig, sollte mal mein 2.1.36 nandroid und da mal testen aber ehrlich gesagt is das mir nicht wichtig es sei du nutzt ne musickeyboard app z.b. und willst nen accord greifen und spielen dazu ;-)
Aber da waeren 4 points dann auch nicht ausreichend ;-)
Ist für FIFA und Co ;) also hats wer drauf?
Hast du mal die 2 seiten gelesen?
"original" roms haben max. 2 bei multitouch eingestellt ;)
aber man kann es selbst umstellen, auf was auch immer man will :D
die build.prop öffnen und den wert anpassen:
ro.product.max_num_touch=4
standard ist wie gesagt 2, 4 sollte bei den meisten reichen, aber wer will kann auch 6 oder 8 einstellen, oder 10 :D aber naja, ob man es braucht ist ne andere frage
FuFu
Es funktioniert bei mir nicht, es gehen höchstens 2.
