[ROM] Froyo-Mod für das Milestone
  • 8 Antworten
thedoginthewok
thedoginthewok
Stamm-User
97
Das hier soll der Download & Info Thread zu "The FroyoMOD" von 89luca89 von XDA Developers sein.
Info:
Dieses Rom basiert auf den offiziellen AOSP Sources in Verbindung mit den proprietären Teilen des Systems ( signierter Kernel), die der Bootloader vorraussetzt.
Weitere Infos bitte der Quelle entnehmen. Ich editier hier noch ne Übersetzung rein, wenn ich Zeit hab.
Download:
v2.5.0
Changelog:
89luca89 schrieb:
Changelog 2.5.0
Scrollable power widget --> now with TORCH LED AND MUSIC CONTROLS! (play forwar prev)
NEW Gallery2D (faster and prettier)
Revisitation of FroyoMOD Extras
-Removed SpareParts options not working
-Added possibility to REORDER power widget
-Added possibility to allow light decarese (in automatic brightness)
-Extra settings cleared and added Bootsound on/off
Bugfixing (should have no bugs now)
Updated Proprietary Motorola Apps, added "Audio Effects"
Removed Crystal talk from PhoneMOD (if yoou want it, switch to stock phone.apk)
-Added SimToolkit
MUCH memory tweaking
Resolved Notification iussues, Graphical glitch, vibration during a call
removed memhack
revisited overclock
Removed keyboard shortcuts, reduntant with the tools of the rom!!
Changelog 2.4.0c
Fix bug permission Google Maps
Fix missing FileManager
Fix FC Android Terminal
Fix build fingerprint (ora vedrete tutte le app da market)
Fix Problem with some applications
apply it without data wipe ONLY IF you come from another Froyomod version!
Changelog 2.4.0b
bugfix release
fixed devtree "write_raw image"
fixed stuck at welcome screen
cleaned the Rom from useless lib/apps/icons and ecc...
Changelog 2.4.0
Updated AOSP Froyo 2.2.2!
updated files proprietary + baseband
MODIFIED SCRIPT INSTALLATION:
NOW will be flashed automatically the bpsw.img devtree.img!
Fix memory leak! Now you can have up to 70mega free after boot (you can easily get 100mb free too with a taskkiller !!!!--> I DO NOT RECOMMEND TAST KILLERS)
Adjusted the overclocking to improve battery consumption ... (maybe remove the overclocking version of the prox)
Small grains:
Back to the Origins!! Back to the disturbing dancing banana as bootanimation! xD
Included (in place of the originals) live wallpapers of the Release 2.3.2 of nexus S
Anleitung:
1. Zip-Datei Runterladen
2. OpenRecovery installieren (Ich empfehle Androidiani.)
3. Zip-Datei in den Ordner /OpenRecovery/updates kopieren
4. Full Wipe machen. Dazu im OpenRecovery "Wipe Dalvik", "Wipe Cache" und "Wipe Data/Factory Reset" auswählen.
5. Über OpenRecovery flashen (Menüeintrag heißt "Apply Update")
Quelle:
[ROM-AOSP][12/02/2011] The FroyoMOD v2.5.0- Fast and smooth!! And more Reliable!
Letzte Änderung:
Update
Reaktionen: Alosha, dacki, AudiA3 und 12 andere
[ROM-AOSP][2011-03-21] The FroyoMOD v2.6.0- Smoother, better looking!
2.6.0 Changelog
New Arab Kernel with RARE DSI errors and better management of resources
New icons for the power widger, prettier and fingerfriendly!
New JIT option ON / OFF in Froyomod Extra Settings
App FasterFix included to improve the GPS fix!
GPS Management Revised
Memory Management Reworked! Quick and smooth!-> This took a little time to optimize
Uppate Google Apps
Uppate DPS manager and sound effects (both now work! and give a scary sound quality !)
UPDATE CAMERA, taken from the last edition of SapphireMOD with icon "Video" and more options!
INCLUDED video player Motorola in combo with the gallery 2D-> Fixed bug with NO VIDEO 2D gallery [/ B]
New graphics for the File Manager!
Downloadlink: http://www.multiupload.com/45KWTGIPAX
Reaktionen: kassi, Alosha, dacki und 6 andere
Original-Thread auf xda: http://forum.xda-developers.com/showthread.php?t=815595
[ROM-AOSP][27-04-2011] The FroyoMOD v2.7.0- Many steps forward!
2.7.0 Changelog
aGPS and GPS PROBLEM FIXED THX TO NADLABAK!
Fix DSI errors ON by default
New Memory managment THX TO Zeppelinrox!
New 3D Gallery MOD With MotionGestures!
New AOSP 3D Launcher with 7 homescreens (avaiable also in 2D!)
Fixed Ext partition mounted too late (thx nadlabak for the tip)
FIX Light decrease BUG
ADDED AutomaticLights Level in FroyoExtras (from CyanogenMod)
NEW icons for PowerWidget THANKS TO SATANSHARK on Androidiani forum!
Make More Room in /system (to avoid problems with future installations)
New packs of overclock, Keyboards and Apps
Udated themes and Added new themes from the fantastic sileshn and anime16!!
DOWNLOADS
Multiupload.com - upload your files to multiple file hosting sites!
Und noch andere Sachen sind dazugekommen:
KEYBOARDS
Many of you may have different tastes regarding keyboards, so I decided to provide you some alternatives
http://dl.dropbox.com/u/25106916/App...oyo_update.zip
This is The stock froyo AOSP keyboard!
http://dl.dropbox.com/u/25106916/App...ead_update.zip
This instead is the Gingerbread one, used by default in the ROM
http://dl.dropbox.com/u/25106916/App...ola_update.zip
This is the Motorola Blur keyboard fully with voice command FULLY working!
http://dl.dropbox.com/u/25106916/App...HTC_update.zip
This is (instead) my favourite one:
HTC Sense keyboard with fully working voice commands!
Of the 4 keyboards, Motorola and HTC one have Prediction test ALSO ON HW KEYBOARD;
On HTC you have to "tap" on where you want to write before starting typing if you want predicition to work, motorola have ONLY HISPANIC AND ENGLISH DICITONARIES!
OVERCLOCKS
As I read many times that maybe someone want to save battery, another want to have lighting speed, and another one have FCs caused by the overclock...i decided to provide you several possibilities:
550/400/350/250/125mhz Normal voltage
700-500-400-350-250mhz Normal voltage
800-500-400-350-250Mhz Normal Voltage
900-600-500-350-250Mhz Normal Voltage
1100-800-550-350-250Mhz Normal Voltage--> For HIGH PERFORMANCES!
550-400-350-250-125mhz Ultra Low Voltage
700-500-400-350-250Mhz Ultra Low Voltage
800-500-400-350-250mhz Ultra low Voltage
900-600-500-350-250Mhz Ultra Low Voltage
The Ultra Low Voltage (ULV) packs are for anyone want to have high performance with lower battery impact! BUT WARNING! NOT ALL PROCESSORS CAN HANDLE THOSE VOLTAGES!
So in case:
Overclock_1000-750-500-350-250.zip
This is the one used by default in the Rom
SYSTEM APPLICATIONS
To make more room in /system partition, I had to remove the swithcable apps via "froyomod extras", so I will give you the choice via this post:
Launcher 2D
This have automatic rotation and 7 homescreens
Launcher 3D
Have 7 screens enabled, is used by default in the Rom!
Honeycomb Music
This beautiful player is by default included in the ROM!
Music MOD
This is the Music Mod, provided also in Cyanogen and in many other mods, have a LOT of features and good loking widgets!
Music Stock
This is the stock Music player in official Froyo by MOTO, this have the particularity to use the "Now Playing" screen as lockscreen during the media playing!
STOCK PHONE
This is the Stock Moto Phone.apk, it has Crystal Talk and works 100% well
BUT:
Has some glitches caused by the fact that it's not tought for an AOSP framework, so if you want Crystal talk you have to live with them!
Phone MOD
Used by default in the rom, A LOT of features, it's here if you want to revert back
Gallery 2D
This is the new gallery 2D introduced while ago, based on QuickPic and with blazing velocity
Gallery 3D
This one is an all-new gallery 3D, faster and with MOTION GESTURES:
You can ENABLE/DISABLE IT BY PRESSING VOL-DOWN;
PULL CELL DOWN TO ZOOM IN, UP TO ZOOM OUT
TILT LEFT/RIGHT TO SCROLL THE PHOTOS!
FIXES
By default, Froyomod 2.7.0 has DSI FIX enabled BUT:
It will make the phone a little slower in the scrolling and graphic performances, and can create some screen tearing in long scrolling and some other gliches
if you DO NOT want to live with them:
REMOVE FIX DSI
So you will have DSI errors and kernel panic (that are rare but present with arabic kernel) but better performances overall
If you want to Reapply it:
FIX DSI ERRORS
__________________
Reaktionen: Alosha, dacki, siegie65 und 16 andere
RELEASED 2.8.0!
2.8.0 Changelog
Autoboot OR: add recovery command creation
1% step battery (thanks kabaldan and GoodWin!)
Lock Home in Memory
New Memory Managment
New Overclock
Add selection of silent mode with volume control
Add a long press option to the status bar widgets to open the corresponding settings!! (THANKS radadev on GitHub!!)
Wifi icon will bring to Wifi Seings
Blutooth icon will bring to Bluetooth settings
Data/Newtwork/AirplaneMode button will bring to MobileData settings
Brighness/Rotation/Screen Timeout will bring to DisplaySettings
Sync icon will bring to Account Settings
Gps/Lockscreen will bring to Gps and Security settings
AudioMode button will bring to Audio Settings
Flashlight button will bring to the Flashlight App!
Buttons Are now Chooseable!! (Thanks Cvpcs)
Allow disabling of dock observer
Add the possibility to swap the volume keys in landscape mode (Thanks againg kabaldan for both!
Flashlight app+Button
AttributeCache clear (again Master Kab xD)
Slide notifications during swipe-to-clear (This is VERY Nice and Wonderful effect
THanks evancharlton From GITHUB!!)
Gallery 2D AOSP By Default --> Faster, lighter and AOSP! xD
Music STOCK By default
Launcher 2d AOSP By default, smaller memory print!! Faster!
Fix FC In Edit Other Levels
Fixed Overheat
Fixed Not-so-ok overclock
PACKAGES:
Now included the AOSP 2d gallery
Added also AOSP 3d Gallery
Added MIUI Camera or Stock chooseable!! (FOR WHO WANT ALSO WIDESCREEN CAMERA!!
Added MIUI Music
Hope you like it!
For the themes, maybe Next week, you'll have the Original theme...
for now...
http://forum.xda-developers.com/show....php?t=1080371
Use those amazing works!!
Hope also that Anime16 and sileshn will upgrade their themes also!
Enjoy!!
download und infos:
Reaktionen: Alosha, dacki, duddle und 11 andere
RELEASED 2.9.0!
2.9.0 Changelog
NEW---> Now using GOLAUNCHER (cause i like it :p xD) IF YOU DO NOT LIKE IT, INSTALL YOUR OWN FROM MARKET OR FROM DOWNLOAD SECTION!!
CTR on and off animation from gingerbread (Beautifull altought not very useful xD But still beautifull no? xD) Thx to doixahn!
I/O Optimizations (very improved performance in some bench from me)
CPU optimization (at compile level)
Memory Optimization:-> When big apps like camera or maps are opened, the home will be killable as any app, otherwise with any other app open, the home is still unkillable
Other memory Optimizazion-> Removed dead code from source
Battery 1% and 10% chooseable in FMextras->Extras, requires reboot
Fixed Over 100% charging with 1% steps (showing 109% for example) Thx to kabaldan!
Added also DsiFix.ko from kabaldan! (Thx!)
Reworked Power widget, Icons are now able to be of any dimension and shape (rectangoular or square), removed toggle in the botto, this will be parts of future icons, so it can be easly themable
removed the scrollbar and overscroll in power widget scrolling.
Download-Link:
Hinweis:
Bei der o.a. Version kommt es oft vor, dass der Screen nicht total abschaltet und ein schwaches Grund-Leuchten besteht (im abgedunkelten Raum erkennbar). Dafür gibt es folgenden Fix:
http://dl.dropbox.com/u/25106916/BACKIGHT_FIXv2.zip
Bitte beachtet, dass durch diesen Fix allerdings der schöne "Gingerbread - on/off-Effekt" verloren geht. Frei nach dem Motto: "Alles kann man nicht haben" (nocht nicht).
Diskussionen zu diesem ROM bitte nur hier: froyo-mod-fuer-das-milestone.html
Reaktionen: Alosha, dacki, Milestone_Poweruser und 6 andere
RELEASED 2.9.1 !
2.9.1 Changelog
Fix apps FC (forgot to put permissions and a part of Gapps in framework ç_ç)
Fix No-video Player in AOSP gallery2d (used by default)
New Interactive governor backported from 2.6.38 kernel (thx Nadlabak)
New 5 points multitouch kernel Module (thx nadlabak)
Modified 08KernelTweak--> Now it says to the system that we do not have an hdd but a flush disk! So it will move faster! ;D thx Dorimax from HD2 forum!!
Reworked I/O e memory managment
Fixed Backlight bug removing the CRT animations
OPTIONAL CRT ON/OFF
There will be an addon downloadable...IT MAY provoke BACKLIGHT BUG!
If you have it, use the roll-back addon, or if you want to convive with it its ok xD BUT DO NOT COMPLAIN ANYMORE ABOUT THE BUG
Made also ROm a litter Lighter in Ram, to speed things up! ;D
Download-Link:
Reaktionen: Alosha, Calsonic, barani und 5 andere
2.9.2 Changelog
NEW Gingerbread Text Handler in Froyo! -> see screenshot http://i52.tinypic.com/ay1zbd.png (thx Achotjan!!)
NEW ICONS in Statusbar PowerWidget! (Beautifull
Thx mblaster4711!)
Included Fix WIFI
INcluded DSI Fix v2.2 (thx nadlabak!)
Included Fix Fro Blinking Leds
Reworked Overscroll effect to have a more natural feeling
Updated GoLauncher to latest release
Reworked a little the Tweaks for I/O and kernel
Tried also to resolve the Sleeping iussues!
Diskussionen zu diesem ROM bitte nur hier: https://www.android-hilfe.de/forum/...ssion-froyo-mod-fuer-das-milestone.54022.html
Reaktionen: Alosha, Golfer, schnubbie und 7 andere
2.9.3 Changelog:
Package manager optimization
EGL set to use HW accelleration (thx kabaldan)
Framework optimization
WPA Supplicant fix (thx Kabaldan)
Updated to new kernel and modules
Updated GoLauncher
revised location.cfg and build.prop to reduce GPS logging, stop useless log deamon
Rom completely batch-optipngized consume less space on disk and ram
Download: Multiupload.com - upload your files to multiple file hosting sites!
Diskussionen bitte hier: https://www.android-hilfe.de/forum/...ssion-froyo-mod-fuer-das-milestone.54022.html
Reaktionen: Alosha, beginner, -alpha- und 5 andere
Froyo-Mod-Version 2.9.3 ist die letzte, da der Entwickeler 89luca89 auf Grund von Zeitnot nicht mehr daran arbeitet. Hier nachzulesen.
Reaktionen: wuerfel, Alosha und -FuFu-
coolzero3389
  • coolzero3389
coolzero3389
coolzero3389
coolzero3389
coolzero3389
coolzero3389
-FuFu-
Varroc
Varroc
