[ROM] CyanogenMod 7 für das Milestone (CM7) - Gingerbread
  • 86 Antworten
und hier der changelog zu der Version:
7.2.4 (2.3.7) 23.10.2012
- the bad GPU performance on low CPU freq fixed via workaround during init (temporary insmod of stock pvr driver)
- updated kernel:
-- we're now on 2.6.32.60 (thanks to Skrilax_CZ)
-- new interactive governor backported from jellybean (with input-boost feature activated by touchscreen events)
-- camera helper buffer (allocated during boot) reduced by 6MB (thanks to alef78) > more free RAM available
-- optional 5 point multitouch fixed
-- fixed usb tethering (only in the 2nd uploaded 7.2.4 build - sorry for the confusion)
- bootinfo hacks could be removed thanks to new 2ndboot update by Skrilax_CZ
Download: https://github.com/downloads/nadlabak/android/cm-7.2.4.-umts_sholes.zip
Reaktionen: Mais, Alosha, TheSpiritof69 und 3 andere
7.2.4a (2.3.7) 03.11.2012
- overclock: vsel entries restored to proofed values
- 2ndboot: updated pre-built binaries
-- a fix instead of a workaround for the GPU performance, proper ATAGs passing (thanks to Skrilax_CZ), etc.
- Music.apk: fixed music playback resume after a phone call (thanks to Danny Baumann)
Download: https://github.com/downloads/nadlaba...mts_sholes.zip
Reaktionen: LeoHart, fipsy, Mais und 4 andere
7.2.4c (2.3.7) 11.12.2012
- kernel: increased DAC fifo size to 16384 to reduce the chance of audio drop-outs
- fix unwanted lcd-backlight activation by camera button while the screen is off (was related to the light sensor workaround that allows to use camera button to provoke sending of light sensor data without waiting for ALS interrupt)
- better handling of Basband Processor panic (by maniac103) - instead of immediate reboot like in stock firmware, user is notified and can choose to postpone the reboot (e.g. when he's got some work to finish first). Note about the reason of reboot is displayed after restart.
- workarounds for some motorola RIL issues that cause occasional data connectivity problems (by maniac103)
- build: in-line kernel building
- optional swap activation on boot via /system/etc/init.d/12swap
-- requires swap partition present as third partition on sdcard
-- swap size (in kB) is determined by persist.sys.swapsize property
-- no persist.sys.swapsize property defined or set to 0 means no swap activation
example how to set persist.sys.swapsize property in terminal:
su
setprop persist.sys.swapsize 16384
https://github.com/downloads/nadlabak/android/cm-7.2.4c-umts_sholes.zip
Reaktionen: LeoHart, Otandis_Isunos, fipsy und 4 andere
7.2.4d (2.3.7) 27.12.2012
- add built-in call recording option; no beeps every 10s during call recording any more
- wifi: disable 802.11n support by default (HT_Enable in tiwlan.ini) to prevent stale data connections when using certain N routers
- kernel: reverted doubling of the DAC fifo size to 16384 (to prevent audio drop-outs) as it caused broken audio playback in certain games
- fix /system/etc/init.d/12swap script
in case you're wondering why the new build is not uploaded to github as before, see https://github.com/blog/1302-goodbye-uploads
Download:
CM7.2.4d: Dev-Host - cm-7.2.4d-umts_sholes.zip - The Ultimate Free File Hosting / File Sharing Service
gapps: Dev-Host - gapps-gb-20111216-signed.zip - The Ultimate Free File Hosting / File Sharing Service
Reaktionen: kliroland, fipsy, -FuFu- und eine weitere Person
7.2.4e (2.3.7) 30.12.2012
- call recording: fix recording for calls with asterisk in phone number
- fix typo in /system/etc/init.d/12swap script
- use better way to implement 'Disable Dock Observer' option (fix issue 637 - Issue 637 - cyanogenmod4milestone - Starting up phone while plugged in docking-station "stalls" auto-rotation, stays landscape. - Issue tracker for Milestone CyanogenMod port - Google Project Hosting )
CM7.2.4e: Dev-Host - cm-7.2.4e-umts_sholes.zip - The Ultimate Free File Hosting / File Sharing Service
Reaktionen: GigaTom, hellfire, kliroland und 2 andere
7.2.4f (2.3.7) 10.03.2013
- the libaudio that allows beepless call recording has been made optional, because some users reported BP panics on incoming calls
-- you can enable it under Device settings > Experimental libaudio (the change requires reboot)
-- the experimental libaudio received new binary patch that may (or may not) fix the BP panics (testing and confirmation from users is needed)
- several additional fixes done to the call recording code
- added CPU stats kernel module
- the moto RIL data connectivity workarounds introduced in 7.2.4c can be optionally disabled by ro.telephony.ril_class=motow3gplain in /system/build.prop (the default value that includes the workarounds is "motow3g")
- ringer audiofocus fix (by maniac103)
Download: Dev-Host - cm-7.2.4f-umts_sholes.zip - The Ultimate Free File Hosting / File Sharing Service
Reaktionen: basian mile, Fatal1ty666, Gutt und 6 andere
