[ROM] CyanogenMod 7 für das Milestone (CM7) - Gingerbread
  • 86 Antworten
Changelog:
7.1.1 (2.3.7) 24.11.2011 KANG
  • fixed issue of some Gameloft games (and possibly other apps) hanging during sound engine initialization
  • fixed lockscreen calendar view to be able to display also the event description
  • the most specific Milestone options (keyboard, logger etc.) moved to Device settings (from CyanogenMod settings)
Download: update-cm-7.1.1-Milestone-KANG-signed.zip
Google Apps: gapps-gb-20111122
Reaktionen: Nikolas22, etet, Cela und 9 andere
7.1.2 (2.3.7) 13.12.2011
https://github.com/downloads/nadlabak/android/update-cm-7.1.2-Milestone-KANG-signed.zip
Changelog:
- fixed recurring events in lockscreen calendar widget
- fixed possible egl surface creation failure (in PewPew game and possibly other apps); reworked egl config selection
- added optional revamped ring lockscreen style
- fixed bugreport service (left shift + del), report files are stored in /sdcard/bugreports/
- added /etc/powervr.ini for some PowerVR SGX tweaks
- internal storage changes:
-- dalvik.vm.dexopt-cache-only disabled by default
-- return back to 07app2ext moving also dalvik-cache to sd-ext
-- lib2ext script (and support for it in installd) newly included. It is not active by default. It can free huge amount of space in /data by transfer of applications' native libraries to sd-ext. Make sure you have enough free space (at least 100MB-200MB) in /sd-ext before you enable it. To activate it, run "su" and then "lib2ext 1" in terminal on phone. The libs will be moved during the next boot.
- etc
Reaktionen: powercon, Regy, mango und 10 andere
Ist die gleiche Version bzw sogar Datei.
7.1.4 (2.3.7) 19.01.2012
- native wifi tethering finally works (proprietary 3G Mobile Hotspot removed, no dun apn dependency anymore)
- new 'Holo' ring lockscreen style
- internal: switched to init built from source, wifi: switched from system/wlan/ti to hardware/ti/wlan
- other things I can't remember now ;)
- note: 7.1.3 skipped to distinguish from the intermediate version used as base for the last HO!NO! Mod
https://github.com/downloads/nadlabak/android/update-cm-7.1.4-Milestone-KANG-signed.zip
Reaktionen: Enkidu, diggi, wembley und 17 andere
[ROM] CyanogenMod 7.1.5 (Android 2.3.7)
7.1.5 (2.3.7) 21.01.2012
- ics animations (including rotation) backported to gingerbread
- renderer updated with rotation support - proper playback of videos with orientation hint
- adhoc disabled in tiwlan.ini (may help few people with wifi issues)
update-cm-7.1.5-Milestone-KANG-signed.zip — CM 7.1.5 (2.3.7) odexed; md5: 9830a9e48c4873300e4d9d33d03509c7
Reaktionen: Aretho, WillowVine, Monzta1988 und 10 andere
update-cm-7.2.0-RC0-Milestone-KANG-signed.zip — CM 7.2.0 RC0 (2.3.7) odexed; md5: 57ab27a78129aff0204d0631348c0c46
7.2.0 RC0 (2.3.7) 17.02.2012
- wide screen video recording now captures in 848x480 resolution (was 720x400)
- two way call recording is now possible (recording has to start after the lines have been connected, not sooner)
- UMTS baseband (2100/900 vs. 2100/1900/850) can be selected in Device settings, the selection will persist even after future system updates (please do not use the baseband switching via Open Recovery anymore)
- fixed in-call and SIM PIN unlock screen layouts for landscape orientation, e.g. for phone in CarDock or DeskDock
- additional information about call can be indicated (e.g. that an incoming call has been forwarded, that the call is on hold on the remote side...)
- workaround for broken proximity sensors - camera button can be used to generate fake 'proximity far' event
- many other important fixes and improvements
note: CMWalpapers and Androidian and Cyanbread themes are not included anymore as more space in /system was needed for the libraries that enable the higher quality video recording. Themes and wallpapers can be installed e.g. from market separately.
Reaktionen: wuerfel, schrimpi, Boogie und 15 andere
Reaktionen: motoroller, wuerfel, Aretho und eine weitere Person
CM7 Testversion mit custom kernel (Infos: xda-developers - View Single Post - [ROM] CyanogenMod 7.2.1 (Android 2.3.7) [20120901])
changelog:
- Kernel Samepage Merging enabled
- ZRAM (compcache) can be enabled under CyanogenMod>Performance settings (will be active after reboot)
bekannte bugs:
- because of yet unknown reason, the device performance is limited until the phone first enters a deep sleep after 2ndboot,
so you should let the phone sleep first while the usb/power is not connected, after every boot.
Since the first successful suspend, the device performance is restored to normal till next reboot.
anmerkungen:
Please note that the kernel and other files are stored in /data/2ndboot, so you will need to reinstall the ROM if you do data wipe or it won't be able to boot.
Download: Dev-Host - cm-7-20121007-UNOFFICIAL-umts_sholes.zip - The Ultimate Free File Hosting / File Sharing Service
Reaktionen: motoroller, wuerfel, -FuFu- und eine weitere Person
Eine weitere Testversion mit Custom Kernel
Download
Changelog:
- charge_only_mode now works
- BP panic is now handled correctly
- 2ndboot files are now stored in /system/etc/2ndboot
- kernel and modules updated
- upstream updates merged
- DSS tearing elimination turned off toincrease fps rate
Reaktionen: motoroller, hellfire, thisismespam und 4 andere
CM 7.2.3 mit Custom Kernel (2.6.32.59)
Download
Changelog:
- 2ndboot: update prebuilts with L2 cache fix by Skrilax_CZ (=> Das System läuft auch nach dem Booten flüssig und nicht erst, nachdem es vorher im Suspend Mode gewesen ist)
Reaktionen: 4711, gromicx, wuerfel und 6 andere
coolzero3389
  • coolzero3389
coolzero3389
coolzero3389
coolzero3389
coolzero3389
coolzero3389
-FuFu-
LeoHart
