[ROM] CyanogenMod 7 für das Milestone (CM7) - Gingerbread
  • 86 Antworten
Changelog (noch nicht offiziell):
7.1.0-RC14-11.08.24 (2.3.5)
- Improved graphic performance by disable the software graphic render, only use the hardware render, also some application does not compatible with software graphic render
- Change kernel & stock modules from SHOLS 5.27 to SHLA 5.15
- Latest DSI-fix module (v2.51)
- Camera is going to support timer feature
- Store dalvik-cache of both /system and /data apps on /cache mtd
- Fix market downloads location to be directed to standard /cache/download, but bind mount it to /data mtd, or (if ext partition is present) to /sd-ext
- Remove logger redirection to cache (cache is dedicated to dalvik-cache)
- Some other fixes (code cleanup, translation)
Downloadlink: https://github.com/downloads/nadlabak/android/update-cm-7.1.0-RC14-11.08.24-Milestone-signed.zip
Google Apps: http://cmw.22aaf3.com/gapps/gapps-gb-20110729-signed.zip
Reaktionen: Enkidu, Aretho, flash2000 und 6 andere
Changelog:
7.1.0-RC14-11.08.29 (2.3.5)
- Android Market download to the SD card Ext partition if existed
- LED notification setting fix
- Disable camera shutter sound by checking the option in Settings-CyanogenMod setting-Sound
- new DSI/MMC-fix v2.6
- etc.
Downloadlink: https://github.com/downloads/nadlabak/android/update-cm-7.1.0-RC14-11.08.29-Milestone-signed.zip
Google Apps: http://cmw.22aaf3.com/gapps/gapps-gb...729-signed.zip
NEW (29.08.2011) update for OpenRecovery (1.46) to support ext2/3/4 filesystems: http://code.google.com/p/cyanogenmod4milestone/downloads/detail?name=OR1...
- it includes new mmcfix kernel module
- ext4 modules for ext2/3/4 support
- tune2fs binary for easy ext2 > ext3 conversion directly in OR console
Reaktionen: Enkidu, Alci, MiJo und 3 andere
Reaktionen: Mais, MiJo, DroidLeo und 10 andere
Gibt einen neuen RC...
CM 7.1.0 RC15 (2.3.5)
https://github.com/downloads/nadlabak/android/update-cm-7.1.0-RC15-11.09.10-Milestone-signed.zip
Changelog:
7.1.0-RC15-11.09.10 (2.3.5)
- native USB Tethering (for both Windows and Linux): thanks to grandiose work by Skrilax on mot_usb kernel module (depends on updated Skrilax's symsearch module)
(preliminary - work on usb stuff still continues)
- DSI/MMC/NAND fix v2.61: disabled duplicated nand suspend/resume calls to get rid of the
'nand_resume called for a chip which is not in suspend_state' messages (thanks to Elektroschmock for the link to patch that solves very similar mxc_nand issue)
- TI wlan kernel module compiled from source with backported wpa2 fixes from tiwlan .144 version (thanks to Tanguy Pruvot for the backport). It should fix some wpa2 issues, at least with OpenWRT routers. Feedback is welcome.
- added options to limit max CPU frequency when screen is off and when phone is in car dock
(When the phone is in car dock it can easily overheat as there is usually: heavy navigation app running, gps in use, battery charging, 3g in use, sun shining directly at phone behind front car window. All this together can lead to battery temperature rising above 50C at which point the charging is automatically stopped to prevent battery damage and you can end up with phone battery empty after some time despite phone being connected to charger. So the CPU freq limit for car dock is there to help with this temperature issue.)
- option in Camera advanced setting to mute focus beep
- CMStats not removed anymore: I'm interested how many umts_sholes (i.e. Milestone) totals will be seen at http://stats.cyanogenmod.com
- added misc translations, Slovak keyboard etc.
Reaktionen: Mais, MiJo, Syrabane und 13 andere
changelog CM 7.1.0 RC15 (2.3.5) - 11.09.12
- fix custom selected cpufreq governor not restored after boot (issue introduced in 11.09.10)
- first step to resolve in-call dialpad landscape issue: http://code.google.com/p/cyanogenmod.../detail?id=596
- other small changes, few translations added
Reaktionen: Mais und DeinXsicht
Neuer Build:
7.1.0-RC15-11.09.14
Changelog:
11.09.14:
- fix Exchange sync wakelock issue - occasionally happening no sleep after Exchange sync
- fix wifi signal strength indication
- ignore 'lock home in memory' option when in car dock
- some minor translations added
Downloadlink:
update-cm-7.1.0-RC15-11.09.14-Milestone-signed.zip
Reaktionen: niknase, Mais, Carbon und 8 andere
Changelog:
7.1.0-RC15-11.09.21 NIGHTLY (2.3.5)
- the most important change is that the Google Maps NetworkLocationService (designed to be constantly running since gmaps 5.1.0) won't be kept in RAM anymore, unless Google Maps really need it.
NIGTHLY
As there is currently ongoing work on some patches in upstream and official 7.1.0 RC2 release is near, I decided to release this one and possibly next few builds as nightlies, as it's clear that there will be new updates soon.
On the other hand, some changes I've made are rather important, so I wanted to deliver it soon.
In regards to stability, there's no difference between RC or nightly I upload. It's just named differently, that's all .
The recommended version to use is always the latest present here: https://github.com/downloads/nadlabak/android/update-cm-7-09212011-NIGHTLY-Milestone-signed.zip
Google Apps: http://goo-inside.me/gapps/gapps-gb-20110828-signed.zip
[updated talk.apk] - http://goo-inside.me/gapps/gapps-gb-...alk-signed.zip
(apply gapps-gb-20110828-signed.zip and then gapps-gb-20110828-newtalk-signed.zip)
Reaktionen: niknase, mr bo, wuerfel und 9 andere
Reaktionen: moviecut, Zepp und -FuFu-
Reaktionen: RobK, Aretho, 7thdiamond und 5 andere
Neuer Build:
7.1.0-11.10.12 (2.3.7)
Changelog:
- odexed build (main purpose is to gain more space in /data - only /cache/dalvik-cache is used, /data/dalvik-cache is empty), be sure to wipe both cache and dalvik-cache in OR when updating
- various fixes
Downloadlink:update-cm-7.1.0-11.10.12-Milestone-odexed-signed.zip
///EDIT///
Changlog eingefügt
Reaktionen: moppelg, androbikes, gabel und 10 andere
Changelog:
7.1.0.1 (2.3.7) 21.10.2011
  • DSPManager service made stoppable again, by global DRC option
  • system fonts are now stored in otherwise unused /cdrom block to make more space in /system (CMWallpapers can be included again)
  • optional unlock by keyboard slide
  • many fixes; among others: EAP (WLAN) lost password issue, possible system crash caused by lockscreen calendar events display, possible system crash by ring lockscreen, fixed bluetooth AVRCP 1.3 responses, possible DSPManager FC while editing EQ...
  • updated power_profile.xml
  • dalvik.vm.dexopt-cache-only property reintroduced (enabled by default); those whose app's dalvik-cache won't fit to /cache block can set it to 0 in /system/build.prop
  • kernel tweaks included (in /etc/sysctl.conf)
  • versioning changed according to new upstream style
Download: https://github.com/downloads/nadlabak/android/update-cm-7.1.0.1-11.10.21-Milestone-signed.zip
Google Apps: Multiupload.com - upload your files to multiple file hosting sites!
(apply gapps-gb-20111012-signed.zip first and then gapps-gb-20110828-newtalk-signed.zip)
Reaktionen: moppelg, androbikes, raba und 10 andere
Reaktionen: moppelg, gromicx, androbikes und 18 andere
Changelog:
7.1.0.3 (2.3.7) 10.11.2011 KANG
  • support for secondary hw keyboard character map (russian, hebrew, arabic); when enabled, it can be toggled by menu/lang key on hw keyboard
  • support for russian hw keyboard layout with swapped 'search' and 'menu/lang' keys
  • multipress feature for entering alternate characters on hw keyboard (currently for cs, da, de, es, fi, fr, hu, it, nl, no, pl, pt, ro, ru, sk and sv). Future contributions of sets for other languages are welcome, see https://github.com/nadlabak/android_frameworks_base/commit/06e8f2e21ad9f...
  • keyboard features are configurable under CyanogenMod settings>Input (but it will be moved to Device settings in the future)
  • Motorola specific AudioEffect replaced by newer AudioEffectSettings (fixes fx settings for speaker not restored after reboot), accessible from DSPManager menu
  • added Compass Calibrator (Settings>Device settings)
  • lockscreen can display both alarm and calendar events together
  • important fixes to omap specific stagefright issues (multimedia)
  • Market should no longer crash because of locale
  • many other fixes
Download: https://github.com/downloads/nadlabak/android/update-cm-7.1.0.3-Milestone-KANG-signed.zip
Reaktionen: TexasHol, Resix, raba und 9 andere
Changelog:
7.1.0.4 (2.3.7) 12.11.2011 KANG
  • graphic rendering optimizations (opaque views, opaque in skia, surfaceflinger)
  • fix for concurrent access to dnsproxyd socket that could lead to loss of data connectivity
  • fix for non-animated unlock transition
  • updated battery bar
  • support for retail Russian keyboard
  • added preliminary Cyrillic (phonetic) key char map
  • added multipress set for Slovenian (thanks to kv1dr)
  • option to disable boot animation (5-6s shorter boot time)
  • downloads bind mounted to data block if there's no ext partition on sdcard - to help with low space in cache block that some people experience
Download: update-cm-7.1.0.4-Milestone-KANG-signed.zip
Google Apps: gapps-gb-20111111
Reaktionen: TexasHol, helixrider, rara_bb und 9 andere
7.1.0.5 (2.3.7) 13.11.2011
- video recording fix
- keyboard: revised handling of multipress for cyrillic/russian key char map
- keyboard: 200ms multipress interval added
- keyboard: Lithuanian multipress set added (thanks to rokasjasonas)
Download: update-cm-7.1.0.5-Milestone-KANG-signed.zip
GApps: gapps-gb-20111111
Reaktionen: doanb666, 7thdiamond, flash2000 und 7 andere
7.1.0.7 (2.3.7) 21.11.2011 KANG
- camera: added possibility to focus during video recording (via focus key - half pressed camera key)
- keyboard: ability to set multipress language independently from locale
- keyboard: additional German multipress set where sharp s can be entered by double press on B key (instead of S key, as double ss is quite common in German)
- media: fix broken playback position in several audio players (MortPlayer Audiobook, DoggCatcher and others)
- fix possible system crash caused by lockscreen calendar events display
- fix for non-animated unlock transition
Download: https://github.com/downloads/nadlabak/android/update-cm-7.1.0.7-Milestone-KANG-signed.zip
Reaktionen: NanDroider, Dormitor, kllar und 11 andere
